Guide to retrofit footwell lights front/rear
johnnevett Feb 16, 2014
  1. johnnevett
    johnnevett Member
    245
    19
    Hi all,
    This is my guide to retrofit footwell lights front and rear to a Audi A4 (B8 chassis)
    This is the way I chose to install the lights and will accept no responsibility for any damage/ injuries caused by following this guide, others may have different ways to do this, so please use this as a guide only
    Ok, so I ordered the kit from RobinA3, a member on here, which was made up following measurements I gave him as this is the first A4 her has made the kit for. The kit was made to a very high standard and arrived very quickly.
    Tools I used were:
    Flat head driver to prise fuse covers off
    Torx T20 bit
    8mm socket
    Torx T50
    Rigid cable to fish cables under carpet and behind centre console
    Insulation Tape
    The kit:
    So this is how I chose to do the install:
    I started by removing the drivers fuse panel cover
    And removing the piece of trim below the steering wheel which was held on by 3x 8mm bolts
    Once the bolts are removed the panel will just pull loose and then the OBD port will need to be unclipped to fully remove the panel
    And then removed the glovebox by removing the passenger side fuse panel cover and there are 6x 8mm bolts in total holding in the glove box, 3 inside, 2 below and 1 behind the fuse cover
    The glove box should now pull out and unplug the brown plug to completely remove
    once these are removed you will see the route for the cables to run behind the centre console
    I then remove the trims on the bottom of the door that run towards the centre of the car to run the cables to the drivers and passengers seats for the rear foot well lights
    Next to make life a lot easier the front seat should be removed with the T50 torx bit but I couldn't for the life of me get these out so decided on a different way
    Under the seat you will see this black cover, remove this
    Then with a rigid bit of cable, I used a piece of twin and earth (im a spark ha ha) I fished this between where the bottom trim was removed and where the black cover was removed
    You are aiming for this under the seats
    and wired
    Re fit the black cover and tidy your cables, I tied them to the existing cables under the seat
    then fit the cables down the side of the car, following the existing cables to the passenger footwell where you need to tape these cables and the ones for the front passenger together and fish them the drivers footwell behind the centre console, again I used a piece of rigid cable
    Repeat this process for the rear drivers side footwell light and you should have all your cables ready to connect into the J519 module in the drivers footwell
    Ok so now the connections
    you are looking for the J519 module which is located in the drivers footwell right up at the top, a real PITA to get too
    you need to remove the row of fuses but just unclipping the them and remove the piece of black air ducting by removing the T20 torx screw
    Once you have located the J519 module you need to find the black plug (D) and the Grey connector
    For the black connector you need to slide out the purple slider and push the pin into slot 14 which is marked on the plug itself, and the cover on the grey plug slides off and the pin goes into slot 17, again all numbered
    find a suitable point for grounding both wires, any bolt should work, sorry forgot to take a pic of this
    Once connected tidy all your wires and refit all trim pieces in reverse to how you took them off and plug all the lights in place
    Now comes the programming:
    09 control module, 07 long code helper, Byte 16 and tick Bits 0,1 and 6
    then in
    56 Radio module, 07 long code helper, Byte 8 and tick Bit 7
    info from here:
    post 70: Retrofit Footwell Lighting - Page 3 - A5_OC
    And Enjoy:
    Hope this helps people out
    John
  2. RobinA3
    RobinA3 Well-Known Member
    1,826
    46
  3. Gillm
    Gillm Member
    110
    What did this cost
  4. johnnevett
    johnnevett Member
    245
    19
    Pm RobinA3 for prices. He supplies the kit which includes everything you'll need to fit this.
  5. desertstorm
    desertstorm Moderator Staff Member Moderator VCDS Map User quattro Audi A4 Audi Avant Owner Group TDi
    5,424
    2,374
    Great Guide,
    Fitted a glove box light to mine Yesterday and it was fairly straightforward, can't believe a car that cost as much as this new doesn't even get a glove box light.
    Will probably be doing this as at some point in the future.
    Karl.
  6. Gillm
    Gillm Member
    110
    Any info on the glove box light also ? Costs etc like you say it's annoying
  7. desertstorm
    5,424
    2,374
    There is a thread on here somewhere with the info and details.
    This is all you need.
    And one of these
    ADD A CIRCUIT- FUSE TAP - PIGGYBACK FUSE - TAKES STANDARD FUSE | eBay
    The part numbers for the light / wiring and connectors
    light 8D0 947 415
    connector housing 893 971 632 x 2
    repair wires 000 979 133E X 2
    In total the parts were about £20.
    Just a matter of dropping the glove box down about 6 8mm headed small screws. Fitting the light in the hole in the top of the glovebox, chopping the one wire with enough to run to an earth and the other to a supply.
    Just borrowing one of Johns pictures from above. You can pick up an ignition switched supply or a permanent supply with one of the fuse taps I linked to on Ebay.
    You will have to extend the one wire to reach the power as it's not long enough.
    Looks like John has already got something tapped into on these fuses. The bank of brown fuses closest to the camera appear to be ignition switched.
    Karl.
    ScottishA4B9 and JG51 AUD like this.
  8. JG51 AUD
    JG51 AUD Well-Known Member Team Monsoon Gold Supporter Audi A5 Black Edition TDi
    2,295
    1,256
    That's another two things on the to do list, thanks guys. :thumbsup:
    Macdoon likes this.
  9. desertstorm
    5,424
    2,374
    Heres some pictures of the fuse tap in place.
    If you want a switched 12v put it here
    If you want a permanent 12V put it here.
    Karl.
    ScottishA4B9 likes this.
  10. dpaz
    dpaz Active Member Team Tango
    515
    112
    43
    I know Audi now make LED footwell units, can these work with the B8?
  11. ScottishA4B9
    ScottishA4B9 Well-Known Member Team Daytona Audi A4 S-line owners group TDi saloon
    3,005
    763
    Just buy the LED bulbs for the lights. Blue LEDS would look nice for the footwell lights.
    Great guide by the way! It's good to see more of these on the B8 Forum. Although this looks tricker than my bumper and Grille removal. Don't know if I'm brave enough to remove seats and mess around with wires.
  12. t8ups
    t8ups Site Sponsor Site Sponsor VCDS Map User
    2,027
    729
    Yes, if you tell Robin you want the OEM LEd lamps used in the B8's he will make the looms up with them instead.
    Trups
  13. dpaz
    515
    112
    43
    Thanks Trups, very kind of you to refer on to Robin. Do OEM LED's work okay? No weird errors or anything?
  14. dpaz
    515
    112
    43
    If the seat removal is the same as the B8 it's simply just 4x triple hex bolts.
  15. t8ups
    2,027
    729
    Hi.
    I also buy looms from robin so happy to recomend his stuff. OEM LED's work fine, you would need to code that you have LED footwell lights so it stops the canbus check and monitoring. it will be towards the end of the bytes and you just tick it.
  16. t8ups
    2,027
    729
    seat removal is just the 4 bolts, no need to take the seat out the car, just tilt it back.
  17. t8ups
    2,027
    729
    Robin Does a glove box loom kit also for B8 cars that came without, PM him for pricing.
    Trups
  18. ScottishA4B9
    3,005
    763
    Anybody up for a group buy on a combined footwell and glovebox light kit?
  19. johnnevett
    johnnevett Member
    245
    19
    I'd be interested in a glove box light kit.
  20. JG51 AUD
    2,295
    1,256
  21. Gillm
    Gillm Member
    110
  22. RobinA3
    1,826
    46
    I have just made this glove box light kit up for John to try out - the kit will be plug and play ready to go. Once I get the go-ahead from
    John that the kit is all ok then i can supply them to other members (I prefer to know that the kit is 100% ok before I sell them). Price wise the kits will be £25 posted.
    JG51 AUD, johnnevett and ScottishA4B9 like this.
  23. Anthony566
    Anthony566 Active Member
    732
    111
    43
    +1
  24. Crazyfool
    Crazyfool Lead boot
    1,068
    199
    Oh yes, great idea...one for me please!
  25. Point_Audi
    Point_Audi Vorsprung durch Technik Staff Member Moderator VCDS Map User Gold Supporter Team Tornado Audi A5 Black Edition S-line owners group
    1,381
    958
    Yep i would be interested also!:)
  26. Anthony566
    732
    111
    43
    Is anyone offering a full lighting kit ??? glove box, foot wells and doors ? as I would like this.
    Ah I see RobinA3 is ill drop him a PM and see if he does the door kits as well ...
  27. RobinA3
    1,826
    46
    I can supply the following lighting kits:
    Front footwell light kit
    Rear footwell light kit
    Door puddle and warning light kit
    Glove box light kit
    Please pm me details.
  28. dpaz
    515
    112
    43
    RobinA3 can you PM me a breakdown of the costs for the 4 lights sets you've listed above. All using the OEM LEDs if possible. Thanks.
  29. ScottishA4B9
    3,005
    763
    Anybody else up for a group buy? I think someone would need to set up an official group buy thread as per forum rules?
  30. antowens
    antowens Car Nut Regional Rep
    845
    275
    How do you remove the bonnet release to get the drivers side sill cover of if that's what its called i cant for the life of me figure out how
    @t8ups
    t8ups likes this.
  31. t8ups
    2,027
    729
    pull the release and hold it, then get a flat head in the side and you will see a clip, pull that out and it will get that off, then behind there is a Philips headed screws holding the panel in too.
    Trups
  32. andyam
    andyam Active Member
    485
    I didn't remove it...I pulled up what I could and then threaded the cable from the back of the footwell down
  33. JoeriAudiA4
    JoeriAudiA4 New Member
    Hi john,
    I just finished my installation (only front lights) with a kit from Robin and installed it with your guide since i have a A4 B8
    And they are not working..
    Just so you know for coding i can't go into 56 Radio module because i have a other mmi.
    I needed to go into the hidden menu and put some settings on.
    + When i got the option to check footwell lights front and rear i only checked front since i don't have rear installed. Maybe i need to check to both ?
    Also i'm not so sure if i did it correctly here is where i put the red wire in:
    http://postimg.org/image/4lh8l751r/
    number 14
    and the other wire i bolted on ground
    Is there anything i did wrong so they are not working ?
  34. RobinA3
    1,826
    46
    I have just checked and you have used the wrong connector.
    For the front footwell lights you need to go into the grey plug into pin 17.
    The rear footwell lights use the black plug into pin 14.
  35. JoeriAudiA4
    So today i was going to use vcds to check the box i have the rear footwell installed as well,
    since i plugged in my front footwell in pin 14 ..
    But again i'm getting a problem. Error 31: Request out of range
    I have tried many things but nothing seems to work.
    I can deactivate everything or only check bit 6
    Yesterday i only checked bit 0 and 6 but this doesn't seem to work today either..
  36. andyam
    485
    I was supplied by the site sponser a kit to connect the front and rears together and just use pin 17. I too could not activate the rears via vcds
  37. JoeriAudiA4
    I don't know for sure but could it be that in pin 17 there is already a cable connected ?
  38. JoeriAudiA4
    Everything works fine now.
    For people who didn't understand where the pins need to be.
    - (+) Front foot lights T32a (gray connector) pin 17
    - (+) Rear foot lights T17L (black connector) pin 14
    - (-) Bold on to chassis.
    For people with a mmi 3g / plus the vcds coding in 56 Radio module is not going the work, this is only for the mmi basic. This can be activated through your hidden menu.
  39. andyam
    485
    How did you get around the VCDS issue?
  40. JoeriAudiA4
    The VCDS issue was resolved by installing the front foot wells correctly.
    I only checked i have installed the front footwells and not the rear..
    I'm not sure but i think you need a sort of closed circuit so the module can get a good response from it.
