guide on fitting facelifts headlights on prefacelifts A3
abdus May 29, 2007
  1. abdus
    abdus Top Gear VCDS Map User
    1,827
    anybody has a guide please...esp the bit of modifying the wing I keep reading about...Thanks
  2. rodenal
    rodenal Active Member
    1,992
    Have a look at the sticky at the top of the a3 section
  3. dantheman1986
    dantheman1986 Member
    262
    need the pics to work tho really
  4. abdus
    1,827
    i went through it....being anewbie, I do find it a bit complicated...I read RichA3Turbo's post again and again, and still trying to figure it out...esp the inner wing bit
  5. abdus
    1,827
    will any facelift headlights fit (with the mods in RichA3Turbo's) or do I need only 2001-2003?
    or simpler, will any light after 2001 fit? wthere it is 2001, 2002, 2003, 2004, 2005, 2006
    Thanks...
    Somebody please confirm
  6. rodenal
    1,992
    2001-2003 - but unless you currently have xenons you dont want S3 ones.
    If you buy the plugs and leads as per the other thread the wiring is quite easy - its just a case of marking where each colour goes to before you cut the wires from the old lights to make your new loom.
    Its quite self explanitory once u have it infront of u
  7. abdus
    1,827
    OK thanks.
  8. abdus
    1,827
    so these should be fine then:
    8PO941003L
    8PO941004L
  9. jcs356
    jcs356 Brum brum
    2,734
    70
    Don't think they will fit - 8P part number means it is the new A3 (i.e. 2004 onwards). You are looking for an 8L part number.
  10. abdus
    1,827
    OK thanks...so it should start with an 8L...
    8L0 941 003 it will be then
    Thanks all.
