Guide - How to fit a catch can and simplify the PCV system
Westy Apr 20, 2011
  1. AFDanHef
    AFDanHef Member
    75
    I don't know what happened?? The thread was there a couple of days ago. I didn't delete it. Is there any moderator on here that deleted it for some reason?
  2. AFDanHef
    AFDanHef Member
    75
    Soooo .... I don't know what happened to the Group Buy thread but it's gone now. I'm sorry to the couple of members that were interested but I'm ready to buy now and not have to wait to gather a group of interested people. I'm not going to repost the group buy but I will forward the emails to someone if they want to pick it up and go with it.
  3. limbo118118
    limbo118118 LORD
    500
    53
    what do people do who just put a filter on the rocker cover breather like this? im tempted to do it, to try an clean up my bay an remove as much as possible :/ could you just block of the oil breather on the block? plus i know some rocker covers dont even have the breathers...
  4. Westy
    Westy Well-Known Member
    17,443
    1,105
    You'll just end up with a fuel smell inside the car. I started off with a filter and moved to a great big long hose to get those fumes to the back of the car.
  5. *P3nfold*
    *P3nfold* Member
    368
    15
    On the website for Saikou Michi catch tanks Saikou Michi Co. 2013 there seems to quite a few options ranging for $60 plus, which catch can is best. I was looking at the S1-OCC $85 + P&P, what do you think?
  6. LSL
    LSL Luke
    71
    Does anyone know what the ID of the hockey puck to TIP connection is? ARY with 70mm MAF.
    Will save me having to take it all off then fit it again to go buy something to plug it with :laugh:
  7. IrishDave
    IrishDave Active Member
    682
    45
  8. s3clarke
    s3clarke Money grabbing s3!
    677
    35
    all the catch tanks I can find on the bay are only 15mm inlet/outlet :/ can somebody point me in the right direction? cheers.
  9. LSL
    LSL Luke
    71
    I used a 15mm can and 15mm hose up to the t-piece, works fine.
  10. s3clarke
    677
    35
    Cheers pal, have you used some kind of 19mm to 15mm reducer then for the t piece?
  11. LSL
    LSL Luke
    71
    I had bought an adapter but turned out the 15mm hose would stretch over the 19mm t-piece, so I just did that as it's neater and less connections to go wrong!
  12. A3-Lee
    A3-Lee Active Member VCDS Map User
    938
    226
    43
    I have a 15mm catch can on mine and that's fine grae
  13. s3clarke
    677
    35
    i'll look into it then when I change my TIP, probably not a bad idea to do it all at the same time. Cheers guys
  14. Pabl0
    Pabl0 Member
    140
    Ahem... Bored of waiting for the can to arrive so improvised form now, will pick up some synthetic wire wool tomorrow.
    Great guide Westy, very easy and worthwhile.
  15. Vwdan80
    Vwdan80 Member
    100
    i'm gonna be fitting a catch can soon (think original piping is starting to split) and just want to confirm that a one way valve on the servo pipe is not need for an s3?
    Dan
  16. vrbob
    vrbob Thats no Moon, Thats a space station!
    2,375
    171
    Its already got one you are correct :)
  17. Gops
    3,198
    666
    I've vented it to the rear of the car but sometimes I get a wiff of what seems like plastic burning or something, it's not all the time but mostly when I stop.. Anyone else had this?
  18. rhubarb4
    rhubarb4 Certified Audi nutter Gold Supporter Team Silver Audi S3 quattro
    1,754
    187
    What can have you fitted Gops and did you use oil grade hose, as my setup Iv never had a whiff of anything really.
  19. Gops
    3,198
    666
    Yeah all oil grade hosed. Fitted the same can as prawn from eBay. Not quite sure what it is tbh. I need to have a proper look
  20. S3 Rav
    S3 Rav Well-Known Member
    2,825
    30
    Gops make sure you iron out all the problems before I let you loose on mine lol!
  21. carld
    carld Member
    45
    Would doing this without a catch can And venting to the atmos cause any smoking issues on idle? Getting abit of smoke that smells of oil coming out my exhaust. A local garage think its down to the pcv delete
  22. harvey01
    harvey01 Member
    523
    9
    im going to remove all the **** pipe and come of the oil filter pipe in to a tee the of the rocker cover also in to the tee the down to the hockey puck and iver into the tip or down under the car as i cant be ***** with the tank side of things
  23. s3gazz
    s3gazz Well-Known Member
    1,383
    105
    Hi guys carnt seem to find the black pipe on eBay that u all use the oil graded one same as westys iv got blue at min and its changed colour can u help tar
  24. superkarl
    superkarl MAN OF STEEL
    9,570
    2,464
    JudderMan likes this.
  25. Gops
    3,198
    666
    I figured out what it was.. I cleaned the can with some solvent, I guess it didn't all come out so it was that which smelt! Never had a whiff off anything again! Vents to the atmosphere well so all good :)
  26. s3gazz
    1,383
    105
    Thanks Karl pal
  27. harvey01
    harvey01 Member
    523
    9
    has anyone just run the breather pipes into one and run it under the car ?
  28. <tuffty/>
    21,680
    4,107
    They have done but if you took it on track you would get crucified by the other track users... on the road its the motorcyclists that will suffer...
    I am sure you don't need me to explain why :)
    vfr800 likes this.
  29. harvey01
    harvey01 Member
    523
    9
    i ssee mate :salute:
  30. Adam Davis
    Adam Davis Member
    49
    Anyone else not see the issue when venting to tip, i have been reading up on it and cant seem to find a definitive answer. Off boost the standard setup vents through the pcv valve and to the inlet mani, on boost through the hockey puck. But on the simplified setup it has no way of venting off boost if routed to the hockey puck, only when on boost. It needs to be vented to atmosphere. Unless it runs through the small bypass in the hockey puck??
  31. IrishDave
    682
    45
    Quick question as I will be fitting mine soon. When you remove the pipe connecting to the brake booster and blank the pipe to the inlet mani. Could you not run a hose from the inlet mani to the brake booster therefore retaining pretty much the standard system or do I have it all backwards.
  32. Andrew@A.L.D
    3,879
    617
    Just showing off but i've gone from complicated to simplified back to complicated lol
  33. Tim_Attard
    Tim_Attard Active Member
    473
    44
    that looks nice andrew u show off lol, whats the 4 outlets for? wouldnt you only need 2?
  34. Andrew@A.L.D
    3,879
    617
  35. Tim_Attard
    473
    44
    more pics show off ;)
  36. Westy
    17,443
    1,105
    Care to explain what you're up to there Andrew?
  37. IrishDave
    682
    45
    Can anyone answer my question above.
  38. Westy
    17,443
    1,105
    I'm not 100% sure what you mean in your question Dave.
    Just stick to the guide as its tried and tested. The less hose the better in my opinion.
  39. Andrew@A.L.D
    3,879
    617
    I didn't like the stuff on the market. Also running mega boost you do get more than normal blow by so more pressure in the crank case, if you have more outlets in the crank case you have less pressure
    Westy likes this.
  40. Tim_Attard
    473
    44
    think he wants to keep the brake booster connected, you can either blank it off or use a single bit of hose, if you have an aum then its seperate to the pcv anyway so mines still connected tbh makes no diffrence (could be wrong please correct me)
