Guide - How to fit a catch can and simplify the PCV system
Westy Apr 20, 2011
  1. Westy
    Westy Well-Known Member
    17,443
    1,105
    Guys, just thought I'd give you al a heads up with the atmos venting. Dont do it under the bonnet! I have now become sick of the fumes and whilst on Bill's rollers I could really see how much is coming out of the vent when the car is on full chat.
    I have just bought 3 metres of 19mm hose so that I can drop down the engine bay,cable tie the hose along the rear brake lines to vent it near the back of the car.
  2. rhubarb4
    rhubarb4 Certified Audi nutter Gold Supporter Team Silver Audi S3 quattro
    1,754
    187
    would it not be better just to vent it back into the tip
  3. Westy
    17,443
    1,105
    Lol. I think you've kind of missed the whole point of fitting a catch can in the first place!
    When venting back to the TIP you are putting oily vapour into the boost system which reduces octane levels in the fuel and therefore stumps performance.
  4. rhubarb4
    1,754
    187
    Just the thought of stinky car is putting me off a bit, how protected from the elements will the filter be in its new place
  5. Westy
    17,443
    1,105
    Filter will be coming off mate, it'll just be a hose to vent the smelly vapour out.
  6. LiveWire
    LiveWire S3X
    329
    My car has a boost leak and I beleive it is coming from the suction pump, (as its covered in oil) I want to remove the suction pump but dont have the ££ to buy a catch tank, so am just wanting to simplify the PCV system without fitting a catch tank.
    My question is what bits will I need to do this? and are there any "how to" guides about?
  7. Sam_
    Sam_ Down under
    3,038
    480
    Yeah, you can. I've done this temporarily until I find a proper way to mount the catch can. It's the same as fitting the catch but keep the valve that looks like this and plumb the bottom outlet to the tip and the other end (visible in this photo) to the breather hoses:
  8. LiveWire
    LiveWire S3X
    329
    I have all the bits to do this now apart from a non returnable valve for the brake servo pipe, what size will I need and where can I buy one from??
    Please can someone point me in the right direction (or even better post a link) :beerchug:
  9. Westy
    17,443
    1,105
    Are you kidding me! There can't be any more info in this thread :)
    Look on eBay for a "boat non return valve" and you'll find one.
  10. steve bain
    steve bain Member
    642
    so was thinking of fitting one but have a few questions. what does it do? where can i buy one? and how do i fit it?
    :p:p
  11. LiveWire
    LiveWire S3X
    329
    Na man not kidding you :)
    It does not say anywhere what size non return valve is required, I have searched Ebay and there are many different size valves! I just want to be sure I get one that will fit. Go on link me to one you know you want to :beerchug:
  12. Westy
    17,443
    1,105
    I'll have a look tomorrow mate. I think I used 13mm silicone hose but could only get a 12mm valve so clamped it really tight.
  13. S3Lol
    S3Lol Member
    422
    Did this today and just reused the one way t-piece as my eBay hadn't turned up yet. It is the most frustrating job I have ever done trying to get it all sorted. Used 15mm outlets with 19mm pipe and just jubileed up tight.
  14. s3schofield
    s3schofield Member
    129
    what if i just forget the catch can and route the breather from the crank and cam case under the car ??
  15. Westy
    17,443
    1,105
    You can just forget the can and dump any small amount of oil onto the ground! You will need to block off the hose on the TIP and you'll also need to ensure that the vapour and oil that does come out doesn't cover any of the underneath of the car, or worse, the tyres.
  16. superkarl
    superkarl MAN OF STEEL
    9,552
    2,449
    bad i dea! the amouont of stuff that comes out is surprising!
  17. rhubarb4
    1,754
    187
    Then I disconnected the brake booster line, leading from the suction pump
    I'm also wanting to cap the brake booster line and just use the 1 vac source for brakes. It works on the AGU and ARZ so no reason it shouldn't work on an AUM right? I used a 1/2" piece of nylon rod and a jubilee clip but have since replaced this section of the brake booster line. Picture of revised piece to be edited in later
    [​IMG][/QUOTE]
    Just a quick question I havent got that arrangement in the first picture mines different this is what I have
    So Do i need to do anything else or have I took off to much and iv replaced the valve with the boat valve so do i not have to block anything apart from the manifold outlet underneath.
    Cheers, Chris.
  18. Westy
    17,443
    1,105
    No mate all that **** comes off. You just block off the hose under the mani and fit the boat valve on the hose before the left of the mani.
  19. rhubarb4
    1,754
    187
    Thanks Neil, all I have to do now is remember where I put the T and 90 bends from Dave cant remember what I have done with the bloomin things grr :banghead:
  20. saul goodman
    saul goodman New Member
    Sorry for bumping an old thread, Im new here
    Was thinking of doing this mod but not sure now and have a few questions.
    Would it not be better to take the feed to hockey puck from the top of the catch can - less chance of any oil getting into TIP??
    if the oil is getting caught before the TIP, is there much benefit in venting to atmosphere?
    Also read a sticky thread from tufty on fitting a Jetex filter. He mentioned fitting a catch can underneath the air box. Are there any advantages in fitting it here instead of fixing it to the bulkhead?
  21. Westy
    17,443
    1,105
    The picture I did above is for the saikomichi catch can where the outlet is the bottom pipe from the can as it's a baffled can.
    I started venting to atmos due to the fact that even with the can, small amounts of oil deposits still made their way into the TIP which can cause a mess and reduced performance.
    There's no real benefit of fitting the can in any particular place. It's a tight engine bay so fit it wherever you find easiest to drain it.
  22. Gops
    3,198
    666
    Just a quick question.. I might have missed this, when you vented to the atmos, what did you do to the piping that connects to the TIP? I noticed the hockey puck was deleted but didn't that vent to the tip?
  23. Westy
    17,443
    1,105
    Block up the TIP with a bung. I bought a bung off eBay ;)
  24. snow demon
    snow demon New Member
    In the diagram at the beginning of the tread it shows the puck sending air to the valve cover during no boost to provide the crankcase with fresh air through the internal passage in the head. When the catch can is set up venting to the tip through the puck is it sending air during no boost through the catch can into the valve cover, and at times possibly the lower breather since there is no longer a pcv valve down there to stop it?
    I actually have a 2000 A4 (apr stage3) with no port on the valve cover, Im considering changing to a vc with a port for my catch can set up, and understanding this better will help me decide how i want to go about this. I have been reading alot of conflicting info on the need to have vacuum on the crankcase and provide fresh air to it as well, even though since my vc has no port, I guess audi thought the crank case didn't need fresh air, unless it is somehow going through the lower breather, which I thought only vented the gases.
  25. Mattyyy
    Mattyyy Member
    46
    I've got an APY, I was wondering if there's anything drastically different from this guide that I should watch our for when doing this?
    I've got oil coming out of dipstick holder (broken :p ) - as I guess there's no where for the pressure to go because my breather pipes have collapsed, so might as well replace the pipes with this. :)
    Thanks!
    Matt
  26. rmpreto
    rmpreto Member
    50
    That is a very useful thread Westy, if you don't mind could you please post a picture of your engine bay without the engine cover, after all work is done, just to make sure I understood everything right!
    cheers!
  27. S3_Olly
    S3_Olly Full Throttle
    275
    i have just ordered my Saikou Michi can from america, could anyone tell me if you can get Red oil grade hose as thats what all the other pipes in my engine bay are upto now and all should be when i have tidied the whole engine bay up.
    cheers olly
  28. S3_Olly
    275
    cheers olly
  29. jezzy
    jezzy Member
    768
    I have an apy nothing different mate( except the piece that comes out of the oil filter housing fell apart, new one 28 quid)
    if you vent to the atmosphere, no fresh air to the crank case or valve cover?
  30. Westy
    17,443
    1,105
    I'm sure somewhere will do red oil grade hose but I've not looked round as the plain black stuff was good enough for me.
  31. S3_Olly
    275
    Managed to order some this afters so when that arrives I will be cracking on with removing half of the **** in the engine bay.
    Is there anything else you recommend doing in the engine bay apart from the N249 bypass.
    Thanks Olly
  32. ShaunS3
    ShaunS3 Yorkshire & Humber Rep. Regional Rep VCDS Map User
    1,178
    215
    Right,
    Just incase you are all still confused....i have done a revised diagram of Westy's PCV system as he is too lazy to revise it :)
    I hope this will make things alot clearer and easier to understand.
  33. jamieA3
    jamieA3 Member
    150
    very useful mate, not doing this whole job myself but am replacing my old pcv. nice to see paint being used lol.
  34. ShaunS3
    1,178
    215
    No problem pal.
  35. rmpreto
    rmpreto Member
    50
    it looks great!
    one last question at the "U" shape servo pipe what we should do add there? is that a one way filter?
  36. <tuffty/>
    21,560
    4,044
    Not on an S3... the check valve is near the servo behind the heatshielding
  37. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,825
    107
    This is something i need to do. But what puts me off is the risk of doing it wrong and ending up with either a presurised ( spelt wrong i think) engine or even more leaks from the system.
    I looked at AITP for somebody with the bonnet up and the mod done so i could see it first hand... but i didnt manage to see one.
  38. <tuffty/>
    21,560
    4,044
    You going to ADI? I'll talk you through it... its well dead easy :)
  39. The Doctor
    The Doctor Well-Known Member
    1,394
    189
    I'll be at ADI and have installed the Saikou Michi can so can show you there if interested.
  40. superkarl
    9,552
    2,449
    yayyyy projects for ADI.
    lets see if we could do a turbo swap for someone between us all!
    damo.h likes this.
