Guide for Wiring an Ignition Source - (Aftermarket Stereo Fitting) New Addition
Sidhu88 Jun 25, 2012
  1. Sidhu88
    Sidhu88 Active Member
    808
    76
    You sure the remote is connected to the remote switch output and not the powered antenna? Usually identified as white and blue for remote and solid blue for powered antenna
  2. iyrix
    iyrix Member
    458
    12
    all the leads were standard except for supplying the main power. The loom itself supplies the amp, all you need to do is add earth.
    I'm going to take it apart again and see what i can work out.
  3. Sidhu88
    808
    76
    Try earthing it to a new place.
  4. Sidhu88
    808
    76
    FAO Admins: i'd like to revise this guide but there is no option to edit. Help?
  5. Smeds
    Smeds Active Member
    315
    37
  6. Smeds
    Smeds Active Member
    315
    37
  7. Smeds
    Smeds Active Member
    315
    37
    if the stereo turns off when I remove the key do I still need to do this additional wiring? The stereo that I've bought (and broken, but can hopefully fix) has a little canbus box.
  8. Smeds
    Smeds Active Member
    315
    37
    Bump. Any help much appreciated.
  9. Smeds
    Smeds Active Member
    315
    37
    Has anyone had issues with radio signals on aftermarket units? There are two plugs on the standard unit but the adapter only uses one of them.
  10. tilu
    tilu New Member
    Hi!
    Can you use this fuse to take the power to a relay that drives the radio so it comes on and off by the igniton key
  11. TimWills28
    TimWills28 Well-Known Member Team Floret Silver VCDS Map User Audi A3 S-line owners group TDi
    1,221
    669
    CHeck my video for a ignition live...
