Guide for cleaning EGR on a 1.9 TDI....
DALE_AVANT Jan 27, 2012
  1. DALE_AVANT
    DALE_AVANT Member Audi A4 Audi A3 Audi Avant Owner Group Team Brilliant Black TDi
    620
    21
    ....is there one?
    I have done a search and did find a guide of sorts but it does not seem to be specific to the 1.9 and looks a little different.
    Thanks in advance!
    iucle likes this.
  2. A1DEYB
    A1DEYB Well-Known Member
    1,682
    43
    What makes you think you need to clean the EGR out?
    The reason i ask is because i have a 2.0L TDI 140 A3 and sometimes it idles spot on and then others it misses and is very lumpy, i have been told that it could be the EGR valve sticking, are you having this sort of issue?
  3. DALE_AVANT
    620
    21
    It's just next on the list for maintenance
  4. deanski
    deanski wax on, wax off
    369
  5. quattrojames
    14,050
    577
    If you ever need a guide like this then it's always worth looking in the DIY Guides sticky. You might be surprised what's in there!
    If it's not in there then there is an opportunity for you to be an author, and to give something back to the forum community ;)
  6. DALE_AVANT
    620
    21
    Thanks Dean/James. Looks like a grubby job
  7. lgooch
    lgooch Well-Known Member VCDS Map User
    1,160
    156
    Would doing this improve your MPG ? I have a 105 BHP A3 tdi with 70 k on it. No issues but it is probably clogged up
  8. DALE_AVANT
    620
    21
    Does anybody have the part number for the gasket so that I can replace it (not listed on the part numbers thread)?
  9. DALE_AVANT
    620
    21
    EGR Rubber 'O' Ring seal - SN90927302 - £4.04 at TPS.
    EGR Gasket - 069131547D - £2.41 at TPS.
  10. holmefield
    holmefield Member
    440
    20
    I've just done my EGR today, i started off doing the front brake pads and was then intending on doing my B5 spring perches which have been sat in my draw for 9 months !!! we got the pads done then looked into what was involved in replacing B6 with B5 perches and took a deep breath and decided its a garage job.
    Anyhow the upside was since i had a free afternoon as i'd done my DIY on saturday ( as the misses had given me my weekend job list ) me and my dad attacked the EGR........Now can i start by saying for all those that ( like me ) read up about this and then thought i can do that...................well YES you can BUT be WARNED its a VERY mucky job to do and the bolt on the bottom that holds the EGR on when you've got the top two off is an F___IN RIGHT PAIN TO GET OUT, it took us 45 minutes to get this one bolt out.
    Once you've removed pipe after pipe and bolt after bolt the hole thing comes off and YES it will be more gunked up than an 40 a day 50 year old smokers lungs!!!!
    It took me over 30 mins to clean off the hard baked on muck and soot stuff, as for performance difference i've done 10 miles since doing it and it seems the same, not sure whether MPG will be any better or not but now i've done it and whilst sat here looking @ my still quite Black gunked up hands i'd say yes its well worth doing...............
  11. 666markyboy
    666markyboy Well-Known Member
    1,211
    49
    I'll second the mucky bit ..... did mine about a month ago and it's a filthy job, I found it easier to take the whole lot off with the inlet manifold which i also cleaned and strip it on the bench ..... i used oven cleaner and a jetwash to clean it all then when all back together i disabled the EGR from opperating by removing the VAC hose and plugging it,,,,, no need for a blanking plate if the valve dosn't open is there..
