Guidance for removing and refitting boot trims
jdp1962 Mar 22, 2014
  1. jdp1962
    jdp1962 Grumpy Old Moderator Staff Member Moderator TFSI Owners Group Team V6 Gold Supporter Team Tornado Audi S4 quattro Black Edition s tronic
    8,522
    3,075
    Shortly after I bought my B7 saloon, I had a problem with the fuel flap not unlocking. I tried releasing it with the emergency rip cord tucked behind the boot trim, but that had been snapped off. The only solution at the time (it was a dark Friday night and I only had about a thimble full of diesel in the tank) was for a kindly soul at the nearest dealer to deactivate the actuator, leaving the flap permanently unlocked. I then forgot about and never got round to fixing it. That was three years ago.
    Then today, I found a replacement mechanism, including the rip cord, on eBay, for £20. I snapped it up and it's on its way. I know I will need to remove the driver's side boot trim. What else will I have to remove, and what do I need to look out for?
  2. jdp1962
    8,522
    3,075
    Hmmmm. Should have searched first. Found the answer here.
  3. DieselJake
    DieselJake Well-Known Member
    2,942
    751
    Forgive my idiocy but is this for the trim at the side or part that holds the wheel well in place as I would quite like the wheel well out of mine for storage reasons (assuming it doesn't have any negative consequences on structural integrity).
  4. jdp1962
    8,522
    3,075
    In my case, it's about removing the inner wing trim on the driver's side, so I can access the fuel flap actuator. From reading the guide in the other thread, I think I will need to pop the spare wheel out to access a couple of bolts. When I do it, I'll post pics.
  5. jdp1962
    8,522
    3,075
    OK, well this morning, I had a go at removing the boot trims, and in fact they came off no bother at all. Once I had access to the existing fuel flap actuator, I reconnected the power connector, tested it a few times, and it worked perfectly. I even managed to find the rip cord. It was still attached to the actuator, but was missing its pull handle and had fallen away inside the trim. So I retrieved it, re-located it in its proper palce with the loose end sticking out of the hole at the top of the trim panel for accessing the rear light retaining screw.
    Everything is now back together and the fuel flap is locking and unlocking just fine. If it stops working again, I should be able to yank on the cord with a pair of pliers to unlock it manually in an emergency. When the new one arrives, I'll just hold onto it, and if the old one proves troublesome again, I'll get it fitted at the next service.
