GSM Dash mount...
mdre83 Jul 23, 2008
  1. mdre83
    mdre83 Member
    634
    I'm coming across a vast number of A3s that have the GSM dash mount installed, I'm trying to avoid it as it's a bit of an eye sore but seems to be quite difficult...
    How exactly does this work... is it bluetooth?
    What phones are compatible with it?
    Is there any point in having it if I plan to install the RNS-E?
  2. Dandle
    Dandle Member
    852
    The Audi phone kit always has a cradle attachment that you can fit cradles to to charge your phone and connect the external aerial up. I think it was in 2007 it became an option that if you specced the arm rest the cradle mount could be fitted in there. If you didnt spec the arm rest or the car was made before that was an option then you got stuck with the awful looking dash mount. Phone cradles are available for it but only for very old phones. The system is still bluetooth though and you can pair and use most bluetooth phones without the need for the cradle. The audi phone system intergates with the RNS-E brilliantly and is deffinately worth having both but try and get a car with the cradle in the arm rest.
  3. Shaq12
    Shaq12 Drive it like its hot!
    53
    9
    If the cradle is on the dash, can it be easily removed or is it a case of it leaving massive holes etc??
    C
  4. JohnS3
    JohnS3 Active Member
    3,032
    I've read that it leaves a 10p sized hole.
  5. Shaq12
    53
    9
    Yeah I just read that :scared2: - good old Audi!
    This is the point where GSM Prep becomes an undesirable option and retro fitting sounds like the way to go!! Unless the car is post 07 and has it in teh armrest. We will see
    C
