Group Buy: The Turbo Engineers Hybrid Turbo for Audi S3 8P VAG 2.0 TFSI
Discussion in 'Group Buy / Discount Forum' started by Doogie..., Aug 14, 2014.
  1. Doogie...
    Offline
    Doogie... Active Member
    Jun 30, 2013
    331
    238
    [Aug 14, 2014]
    Group Buy: The Turbo Engineers TTE-420 Hybrid Turbo for Audi S3 8P VAG 2.0 TFSI PRICE UPDATE!!!!
    PLEASE NOTE; ALTHOUGH THIS THREAD IS OPEN TO THE TTE-420 UNIT, OTHER TURBOS FOR OTHER MARQUES BY THE TURBO ENGINEERS CAN ALSO BE INTEGRATED INTO THE GROUP BUY, I.E. THE TTE-400 FOR S3 8P OR ANY S3 8L K03 HYBRID TURBOS. (just ask for details)
    As discussed within another thread, I feel it would be worthwhile to now start consolidating all of the info and details of this group buy within its own dedicated thread for people to put names down and discuss further what the Turbo has to offer.
    This is a fantastic opportunity to purchase a hybrid turbo for the S3 8p marque and with a bargain price if we get enough names to match the highest discount figure. This turbo is the next stage up from stage 2+. Some may say the beginning of stage 3 for a fraction of the price of stage 3 kits
    Si is on the forum should anyone wish to ask him questions on his product.
    Details of the product: (from TTE website)
    CLICK HERE FOR LINK TO WEBSITE
    TTE420+ begins as a brand new standard BorgWarner K04-064 turbocharger that we dismantle and then set about upgrading and optimizing as engineers to create the ultimate TFSI hybrid. No K04 turbine (clipped or not) hybrid can match…
    TTE420+ Turbocharger is in our opinion the final step and our pinnacle power stage for the 2.0 TFSI range of vehicles while retaining the OE unit for Plug & Play fitment.
    Engineered & Enhanced
    The formula to making a TTE420+ starts with a much larger 2871 BorgWarner compressor wheel. Chosen because is highly efficient, new generation type with ultra thin blades, creating extremely high flow for comparative size, giving a compressor map that’s very wide. Yielding a maximum air flow rate of 310 litres a second, compared to a stock 2283 compressor at 250 litres. The Re-Profiled compressor cover is CNC machined to a optimized tolerance to ensure maximum compressor efficiency is given.
    The intake pipe is CNC ported and hand finished to give a smooth transition for the incoming air flow. TTE CNC modify the turbo silencer, removing the baffle internals and fit a new straight through section, removing the restriction and its function as a noise canceling device, and so improving the flow, giving less surge and enhancing the sound.
    A key part and in many ways the heart of this turbocharger for powering the large 2871 compressor and in turn making this unit produce the air mass and huge power advantage over stock and also the competition, is CNC Re-profiling the turbine housing to optimum clearance and fitting a far larger BorgWarner K16 turbine/shaft with a 49mm Exducer and 55mm Inducer, while still keeping the K04 bearing housing, this is not so easy to do. The K16 turbine we use, gives higher shaft torque and much lower back pressure, due to size, trim and geometry, being larger also lowers back pressure and so keeping EGT lower compared to stock K04 turbine or clipped stock types with a 44.5 Exducer and 50mm Inducer other company’s are still using. We also give the K16 Turbine blades a curved clip.
    The clipping of the K16 turbine is a special TTE grinding process to the turbine blade tips. Curved to alleviate stress from process. Clipping reduces blade area thus increasing gas flow and so reducing back pressure and lowering exhaust gas temperatures, allowing safer higher boost level’s. This process also gives a secondary advantage of removing some material, lightening the turbine thus reducing rotational mass improving moment of inertia. Dyno testing of our turbocharger have shown little loss in response vs stock K04 yet huge gains in power and torque.
    Significant attention is given to CNC port and hand finsh the exhaust runners at the flange to match and smooth the transition from head to exhaust runner for maximum gas speed/flow and so improving efficiency to the much bigger K16 turbine and so driving the compressor harder. (Optional at extra cost)
    Performance with Durability
    Special TTE developed in-house high performance motor sport journal bearing system is fitted and 360 deg thrust bearing. Durable at high loads with no loss in transient response.
    Actuator used is uprated sprung OE unit, fitted with our CNC reinforced clamps for trouble-free operation. This also can also be modified to customer needs and specifications.
    Equilibrium
    Precisely balancing our turbochargers is a key critical factor for longevity and performance. Good balance improves acoustics also. Subsequent great care is taken with all TTE turbochargers with this regard. Component parts are balanced at slow speeds at up to 2000RPM using our single parts machine, then components are assembled and then the CHRA are balanced yet again but this time dynamically in multiple planes at up to 250,000 RPM, using our in-house VSR machine to acquire the ultimate equilibrium. Each and every turbocharger is supplied with a balance test result document for your reassurance.
    Key Points:
    Genuine BorgWarner Housings & Components
    Genuine BorgWarner 2871 Compressor, Highly Efficient Next Gen Geometry
    Optimized Compressor Cover & Turbine Housing Clearances
    CNC Optimised modified boost pipe/silencer outlet
    Port Matched Exhaust Runners (Optional at extra cost)
    Ported Intake Pipe
    Genuine BorgWarner K16 Turbine, Special TTE Curved Clipped Blade Tips
    Uprated & Reinforced Actuator
    Special TTE K16/K04 Reinforced Bearing System
    Dynamically Balanced
    Fitment As Original. Plug & Play
    Designed, Machined, Assembled by TTE in Germany
    [​IMG]72 by Ya Beast......, on Flickr
    [​IMG]TTE400_TFSI_111 by Ya Beast......, on Flickr
    [​IMG]K16-Vs-K04-TFSI-2 by Ya Beast......, on Flickr
    [​IMG]52 by Ya Beast......, on Flickr
    [​IMG]31 by Ya Beast......, on Flickr
    [​IMG]00011 by Ya Beast......, on Flickr
    Simon has confirmed the purchase price as:
    5 names will be £1465 incl free shipping
    10 or more names will be £1395 incl free shipping
    The group buy will run for 4 months, A closing date will be arranged towards the end of the first month so we do not under shoot on potential interest.
    I suggest using the first month to gauge interest within the forum aswell as starting a list for those wishing to make the purchase.
    Its understandable that most may not be able to pull £1400 out of thin air hense the length of this group buy. If it transpires that the desired amount of candidates is met, and all are ready for payment sooner than expected, the group buy may close ealrier than first suggested although this is something that will have to played by ear.
    As for details of payment, this is an area that can be discussed once most of the names are down but i'd imagine that it will be paid straight to Si and he will deal with all individual orders.
    I'd suggest that when most of the names are in we can arrange a deposit to be paid to secure our discount price for the turbos. Again, this will be discussed when we have reached a point where we feel we are almost ready to make the purchase.
    NOTE ALSO; THIS GROUP BUY IS OPEN TO OTHER MODELS OF TURBO FOR AUDI CARS (including the tte-400 turbo for audi s3 8p)
    Any other details I may have missed will be updated in due course.
    Discussions welcome within the thread.
    I'll start the list off:
    Dougie - Re-con option
    #1
  2. LiamS3
    Offline
    LiamS3 Active Member
    May 18, 2014
    126
    62
    [Aug 14, 2014]
    Count me in! Would love to try hit 10 for the 22% off, that's an amazing deal!
    LiamS3 - Re-con option
    #2
  3. Doogie...
    Offline
    Jun 30, 2013
    331
    238
    [Aug 14, 2014]
    Doogie... - Re-con option (if available)
    Liams3 - Re-con option (if available)
    #3
  4. KentKid
    Offline
    KentKid Active Member
    Sep 12, 2010
    176
    71
    [Aug 15, 2014]
    KentKid - Re-con option (if available)
    #4
    Doogie... likes this.
  5. TTE Si
    Offline
    TTE Si Site Sponsor Site Sponsor
    Jul 9, 2014
    243
    134
    [Aug 16, 2014]
    Hi Guys,
    Good to see this happening. With regards to the re-con/upgrades, I can't say we will have (used) exchange upgrades units in stock available but 100% can offer to recondition your own units and upgrade, with a turn around time of 10-20 working days depending on workload.
    Brand New right now today, i've got 10 units in process available did sell 3 of the 10 2.0 tfsi upgrade units yesterday. As im sure you can imagine we always try to hold some stock but really is not so easy as BorgWarner stock is not really available to the trade so to speak....we are allways on back order waiting and same with all others.
    Im always on the look for used units to buy and use for exchange but really these also are not so common and if anyone knows of any at a reasonable price, do put me in contact.
    #5
  6. Doogie...
    Offline
    Jun 30, 2013
    331
    238
    [Aug 16, 2014]
    Would it maybe be an idea to sell you our old units once we have our new units fitted? OR maybe offer some sort of exchange service?
    We buy a new unit and then get a further discount or refund when we send you our old one, I appreciate it wouldnt be as much as the re-con price option but a few people could be interested in that. Would save people having to punt their own.
    #6
  7. RedDejavu
    Offline
    RedDejavu Well-Known Member
    Feb 16, 2011
    1,665
    265
    [Aug 16, 2014]
    I'd get a brand new unit before Christmas time, hopefuly mid November
    #7
    TTE Si likes this.
  8. TTE Si
    Offline
    Jul 9, 2014
    243
    134
    [Aug 16, 2014]
    You could sell/get a refund on your old unit I suppose, I'd offer 400€ so maybe not appealing but I feel fair.
    #8
  9. Dan-Jnr
    Offline
    Dan-Jnr Well-Known Member
    Jun 10, 2011
    1,083
    241
    [Aug 18, 2014]
    Dan-Jnr - New Turbo
    #9
  10. TTE Si
    Offline
    Jul 9, 2014
    243
    134
    [Aug 18, 2014]
    Just to add if any off you are self employed or run a company business with a Valid VAT ID, I can sell to you VAT FREE. So giving a further 19% off any total.
    #10
    Brodster likes this.
  11. Doogie...
    Offline
    Jun 30, 2013
    331
    238
    [Aug 18, 2014]
    Anyone got a business that fancies being the go between?? ha
    #11
  12. turbonutz
    Offline
    turbonutz Active Member
    Jul 2, 2013
    426
    62
    [Aug 23, 2014]
    I am interested in this... do you need to do any engine building work or that or is it as simple as plug and play?
    I think I would opt for the p/x - recon option??
    and there gotta be some company could be go between maybe take a wee "handling fee" for it eh? haha
    #12
  13. Doogie...
    Offline
    Jun 30, 2013
    331
    238
    [Aug 23, 2014]
    I'll do some digging on the "go between".
    As for engine work, if you have stage 2+ hardware (TBE,CAI,FMIC,HPFP) then this is plug and play. No internals needed.
    #13
    turbonutz likes this.
  14. Brodster
    Offline
    Brodster Shark Performance in Scotland Regional Rep VCDS Map User
    Mar 17, 2011
    3,501
    843
    [Aug 23, 2014]
    Guys Im in talks with Dougie and TTE as Im a delaer for them so I may be able to get a better deal for you all. Need to leave it with me so I can get prices set in stone which is slightly cheaper than you've got at the moment and then Dougie shall post up final prices for you.
    #14
    Doogie... and turbonutz like this.
  15. turbonutz
    Offline
    Jul 2, 2013
    426
    62
    [Aug 23, 2014]
    whats story with maps? are ur normal 2+ maps work fine or would you need a custom map done?
    #15
  16. Doogie...
    Offline
    Jun 30, 2013
    331
    238
    [Aug 23, 2014]
    Depends on what company you are with. I have researched APR (who DON'T support it) And REVO who DO support it.
    Its HIGHLY recommended however that to get the best results right accross the board, the best route to take is a CUSTOM MAP from specialist mapping companies. Do a bit of research and find one right for you and your area.
    If you are REVO already then they can re-flash the mod for free, but don't expect the best out of it as there will be lots of variables "off the shelf" maps won't account for in this set-up.
    #16
  17. turbonutz
    Offline
    Jul 2, 2013
    426
    62
    [Aug 23, 2014]
    ahhhh pants looks like im out of this one then :( gutted aswell cus really want it haha!
    actually i will keep eye on this see how it goes i might still dip in ha
    #17
  18. Brodster
    Offline
    Mar 17, 2011
    3,501
    843
    [Aug 24, 2014]
    Im gonna speak to Shark HQ as I can do live data logging with some of the kit I have. If this is sufficient then it will be a case of road test with equipment plugged in and then send it to Shark HQ and they will tweak your Stage 3 Alex. Leave it with me and I shall get back to you.
    #18
    turbonutz and RedDejavu like this.
  19. Doogie...
    Offline
    Jun 30, 2013
    331
    238
    [Aug 25, 2014]
    UPDATE!!!!!!!!!!!!!!!!!!!!
    Mark from BROTEK has come on board to help out sales and provide us with an avenue to purchase from. He has managed to confirm the following deals which are BETTER than previously stated.
    If we can get 5 people to commit to the buy then the price will be £1465 incl free shipping to your door. (thats only 1 more person)
    if we can get up to 10 commits then that price drops to £1395 incl free shipping to your door.
    THIS IS FOR THE BRAND NEW, UNUSED TURBO, not the re-con option which until now would have cost the same in price.
    £1465 for a brand spanking new K04 hybrid is about as cheap as it can possible get, A lot cheaper than the turbo dynamics or owen development options.
    Hats off to Mark for getting involved and making this a better group buy than it already was.
    #19
    Dan-Jnr likes this.
  20. s3_sid
    Offline
    s3_sid Active Member
    Jul 11, 2013
    365
    35
    [Aug 25, 2014]
    I'm intrested just cannt commit at this stage I'm waiting on some customers to pay me also at this new pricing can we sell back out old unit ?
    #20
  21. Doogie...
    Offline
    Jun 30, 2013
    331
    238
    [Aug 25, 2014]
    YES, Simon has offered buying back your stock K04 unit (on the basis it is sound i.e., not damaged in anyway) for $400 (£319)
    So if you sold him your turbo the total cost would only be £1146.
    #21
  22. turbonutz
    Offline
    Jul 2, 2013
    426
    62
    [Aug 26, 2014]
    watching this one while i consider it. seems too good a deal to pass up on.
    #22
  23. RedDejavu
    Offline
    Feb 16, 2011
    1,665
    265
    [Aug 26, 2014]
    Yeah i'm nearly sold just need to see what power output is possible on uk petrol and revo/custom mapping. Does it need new rs4 injectors?
    #23
  24. TTE Si
    Offline
    Jul 9, 2014
    243
    134
    [Aug 26, 2014]
    Yes from my understanding Rs4 injectors and a higher output LPFP is needed.
    #24
  25. Doogie...
    Offline
    Jun 30, 2013
    331
    238
    [Aug 26, 2014]
    Doogie... - New Turbo
    Dan-Jnr - New Turbo
    Kevsin - New Turbo
    I will be at Ecotune on thursday for a power run and some advice on whats needed/can be expected from this upgrade in respects to the LPFP and the RS4 injectors. I'll post more info on thursday.
    #25
    RedDejavu likes this.
  26. LiamS3
    Offline
    May 18, 2014
    126
    62
    [Aug 26, 2014]
    I'm sure the Standard S3 Injectors are good for circa 450hp? I also thought the LPFP was only needed after going above 450hp.. But I suppose you would see maybe slight gains with them
    #26
  27. s3_sid
    Offline
    Jul 11, 2013
    365
    35
    [Aug 26, 2014]
    I thought the rs4 injectors have a bad spray pattern on comparison to the s3 injector and I also thought the s3 was good for 450+
    #27
  28. Doogie...
    Offline
    Jun 30, 2013
    331
    238
    [Aug 28, 2014]
    Righto, Spoke to Campbell at Ecotune Glasgow today about what is needed for this mod.
    RS4 injectors are NOT needed as they aren't as efficient as S3 ones which have been confirmed to be good for over 450hp, Aswelll as them having a totally different spray pattern, Campbell advised ,me that other S3's hes had come in for work with them on, he's taken them off and replaced with the stock S3 ones and seen better results accross the board. The same applies to the LPFP, it is also good for over 450hp, APR's uprated one still uses the stock pump so unless you plan on going for a bigger turbo, these are not neccessities for this K04 hybrid unless, as i said, you are plannning on going bigger in the future.
    What he did advise in, was to change the dis-charge and charge pipes as the stock ones have a pancake/flat spot in them to help with their location within the engine bay. Also, not a necessity but would help increase the power somewhat.
    On another note, my car made 375hp, 386ft.lbs at APR stage 2+ so not bad at all.
    #28
    TTE Si likes this.
  29. TTE Si
    Offline
    Jul 9, 2014
    243
    134
    [Aug 28, 2014]
    I have heard different from tuner to tuner what works best and what's needed.
    But two different customers both have just confirmed needed to change LPFP.
    Not saying ECO are wrong just sharing info as i get it...
    #29
  30. Doogie...
    Offline
    Jun 30, 2013
    331
    238
    [Aug 28, 2014]
    Cool, not to cause conflict, just reporting back what Ecotune has said on it.
    Who ever gets round to doing the mod first can come back and let us know what is definetely needed.
    #30
    TTE Si likes this.
  31. TTE Si
    Offline
    Jul 9, 2014
    243
    134
    [Aug 28, 2014]
    Agree mate. All points you raise ive heard before on LO4XX and 400 Stage turbos. Lets see how things progress
    #31
  32. 114mph
    Offline
    114mph Member
    Sep 5, 2013
    80
    13
    [Aug 30, 2014]
    How does the reCON option work?
    Can I send my own K04 (8p S3) to TTE to have it converted? What would the cost and time frame be, if this is possible?
    TTE Si likes this.
  33. Doogie...
    Offline
    Jun 30, 2013
    331
    238
    [Aug 30, 2014]
    That is possible yes. Simon should be a long in a wee while to answer in full.
    #33
  34. TTE Si
    Offline
    Jul 9, 2014
    243
    134
    [Aug 31, 2014]
    Hi,
    Recon/Upgrade of customers used serviceable unit is really a core part of what we do. Cost is as on website (Recon/Upgrade €1299.00) but if bought in the group buy, the discount applies. Time frame to Recon/Upgrade your used unit is around 10-15 days average..
    Si
    #34
  35. 114mph
    Offline
    114mph Member
    Sep 5, 2013
    80
    13
    [Sep 8, 2014]
    PM sent.
    #35
  36. 114mph
    Offline
    114mph Member
    Sep 5, 2013
    80
    13
    [Sep 8, 2014]
    How much extra is the port matched exhaust runners option?
    #36
  37. 114mph
    Offline
    114mph Member
    Sep 5, 2013
    80
    13
    [Sep 9, 2014]
    Simon has been in contact. Looks like I'll be placing an order soon.
    #37
  38. Doogie...
    Offline
    Jun 30, 2013
    331
    238
    [Oct 7, 2014]
    Right then, This thread has died off a bit so i'm here to kick some life back in to it. I'm unsure as to who is still going ahead with the group buy and who isn't... Can any one who IS still placing an order let us know in a comment.
    I'm as guilty as every one else is, as had a few other things in life to sort out (buying the mrs a new car and trying to find a new house).
    I will be placing my order with Simon this week so hopefully get the turbo within the next week or so. I've got a friend who is an Audi tech fitting it for me and i'm currently unsure about who I am going to get to tune it. Anyone got any suggestions??
    So providing all goes well I should have the work done before december to report back to you all about how it performs on the car for those still unsure of whether it will be a worthwhile upgrade or not.
    Seeing as the group buy has ran a couple of months, anyone wanting to place their order, then feel free to contact Mark at Brotek and he can sort the logistics. And for those waiting to either the end of the month or next month, (providing anyone still plans on buying one at this time) to buy one, I am going to let this thread run till the end of November then shut the group buy down as it will have ran its course.
    I'll post pics of the turbo porn when it arrives at my door..
    Dougie
    #38
    Dan-Jnr likes this.
  39. guile
    Offline
    guile Active Member
    Nov 25, 2012
    207
    91
    [Nov 2, 2014]
    gday chaps, is the group buy still on? i'm wanting to place an order this week so i can collect when i'm in the uk at xmas...
    #39
  40. Doogie...
    Offline
    Jun 30, 2013
    331
    238
    [Nov 2, 2014]
    Get in touch with Simon directly. He will be able to taken an order from you.
    Not sure how much discount this will achieve as most people backed out but im sure if you mention the fact that you are off this forum and haven't backed out the group buy he will give you a cracking deal all the same.
    He came through with mine and gave me a smashing deal regardless.
    #40
