Grooved Discs +/-
chrisa4quat Nov 23, 2006
  1. chrisa4quat
    chrisa4quat Active Member
    970
    Hi all,
    I eventually went for 19's on my a4, prob is my discs look tiny, and i think that they're ****, will putting same size discs but grooved on make a difference, or should i be looking at bigger?????
  2. C_Audiboy
    C_Audiboy Vroom Vroom
    822
    Grooved will probably look even more pathetic - I'd definetely be looking at bigger discs!
  3. kris_tdi
    kris_tdi Member
    164
    if its a b5 go for the 312mm upgrade, it will cost you about £60 extra to do as all you need is the caliper carriers from an s3/tt then get the discs from a b6 3.0 quattro, standard pads.
  4. chrisa4quat
    970
    ok, sounds good any idea where i can pick some up??????
  5. chrisa4quat
    970
    plus are they just straight swap???
  6. raca4
    raca4 New Member
    22
    I recently bought new upgrade parts, I paid Just over £120 inc Vat and Div for two VW/Audi 312mm carriers form Vagparts, good luck if you can find a 2nd hand TT pair, I looked for weeks with no luck, Once carriers have been changed the stock calipers and pads should fit with new 312mm disc, thats what I am waiting to do when the weather is not so wet.
  7. Mark 1.8TQ
    Mark 1.8TQ New Member
    yes straight swap, got mine second hand for £60 off here couple of years ago.
    While your changing them it is also worth getting the new style brake disc shields (if yours is a pre facelift) this help with the poor wet weather braking.
  8. AwesomeSarah
    AwesomeSarah Member
    726
    Hi
    Yes the 312 brake upgrade is pretty easy
    Just need the caliper carriers
    Red on the Anni golf ones will fit too or green from the Octavia vRS
    Then go for some sexy discs
    http://www.awesome-gti.co.uk/zerosixty.html
    They are HOT ;)
    sARAH
