Grommet on the left through the bulk head?
Markb Aug 10, 2004
  1. Markb
    Markb Active Member
    2,139
    As subject are there any grommets with other wires or spare grommets through the bulk head as look under the bonnet on the left hand side?
    Mark
  2. neil.c
    neil.c Senior
    567
    IS that left when looking from the front or the back of the car?
    There is a spare grommet on the passenger side behind the pollen filter
  3. CARACTERE007
    CARACTERE007 Member
    319
    umm not sure i just thought it was on the right hand side near the battery?
  4. dunk
    dunk Member
    770
    there is a major gromet going through the bulkhead on the left side. it has lots in it, but its easy to get other stuff through.
    you need to remove the airbox and the glove box, and push a straighened wire coathanger through gently from the engine side - it comes out just under the aircon fan in the passenger well - you can tape cables to the coathanger and pull them through - i just did it to pull through a heavy gauge power cable for an andymac stealth sub - whole job took 20 minutes from start to finish
  5. Markb
    Markb Active Member
    2,139
    I know about the one on the right hand side under the air box and the spare one near the pollen filter.
    I need one on the left hand side at the front. As I am trying to plumb in my boost gauge and the piping is only just long enough.
    Any helpers?
  6. RichA3Turbo
    5,089
    Just by the pollen filter is a rubber plug. I have removed this removed the centre, filled it with wires, replaced the gromet and works a treat. Never have any water on the cabin (and weve had rnough of it recently havent we!!!)
    RIch
  7. Markb
    Markb Active Member
    2,139
    I know about the ones on the right, but what about the left? LOL
  8. RichA3Turbo
    5,089
    if you mean drivers side, then only via the main loom into the cabin... a bit of a pain in te arse to get to!
    Rich
  9. HTC
    HTC Active Member
    3,428
    9
    Remove the wipers and drip tray. On the left you will see a plastic box.
    Open the box and you will see a big opening with wire to the fuse box.
    There is loadsa space here to get stuff through into the car.
  10. Markb
    Markb Active Member
    2,139
    Yeah the drivers side.
    How much of a pain? As I've not looked into it.
    Also is there much space available as I've got to get a pipe with a 12mm bolt on end through.
  11. RichA3Turbo
    5,089
    [ QUOTE ]
    [/ QUOTE ]
    What the hell are you fitting that needs a pipe with a 12mm bolt /ubbthreads/images/graemlins/crazy.gif?????
  12. Markb
    Markb Active Member
    2,139
    [ QUOTE ]
    [/ QUOTE ]
    Cheers HTC you are a star /ubbthreads/images/graemlins/laugh.gif
  13. Markb
    Markb Active Member
    2,139
    [ QUOTE ]
    RichA3Turbo said:
    [ QUOTE ]
    [/ QUOTE ]
    [/ QUOTE ]
    The piping for my boost gauge /ubbthreads/images/graemlins/wink.gif
  14. HTC
    HTC Active Member
    3,428
    9
    [ QUOTE ]
    Markb said:
    [ QUOTE ]
    [/ QUOTE ]
    [/ QUOTE ]
    You're welcome.
    After you have removed the wipers and cover, you'll see how it comes apart. Its kinda obvious once your in there.
    You can get to the stuff from inside if you remove the fuse box cover and then undo the screws and pull out the fuse box under the dash side panel (which just pulls off).
    You might want to remove the lower dash panel to see a bit better too.
    Oh, BTW, completely off topic. Did you see the photoshop pics I did for you on your other thread??
  15. Markb
    Markb Active Member
    2,139
    [ QUOTE ]
    HTC said:
    [ QUOTE ]
    Markb said:
    [ QUOTE ]
    [/ QUOTE ]
    [/ QUOTE ]
    You're welcome.
    [/ QUOTE ]
    I did see these covers when I replaced the pollen filter the other day, but didn't look any further into it LOL
    Yes I did see your Photoshop pics mate /ubbthreads/images/graemlins/wink.gif That is how I wanted it /ubbthreads/images/graemlins/frown.gif
    See my latest threas: http://www.audi-sport.net/ubbthreads/showflat.php?Cat=1,10,15,105,200,900,1000&Board=a3s3&Number=88799&page=0&view=collapsed&sb=5&o=&fpart=1
  16. HTC
    HTC Active Member
    3,428
    9
    Oh yeah, missed that........doh!!
    I've responed to the other thread now.
