Grinding noise when steering left?
dplovin Nov 7, 2011
  1. dplovin
    dplovin Member
    416
    ive noticed that recently ive been getting a grinding noise only when steering left round a corner, as far as i know it doesnt do it when stationary just when the wheels are in motion, ill have to have another check to be 100% tho.
    any ideas???
  2. S3-Sandy
    S3-Sandy S3 OFU
    86
    I had the same symptoms. Turned out to be the CV joint, probably worth a look
  3. colicabcadam
    colicabcadam Guest
    95% cv joint - cheap fix - might as well do them both (left and right)
  4. dplovin
    dplovin Member
    416
    cheers guys... dya rekon there easy to replace yourself or is it a garage job
  5. colicabcadam
    colicabcadam Guest
    you could do it yourself - but tracking MAY need to be done after which you wont be able to do..... i'd do it yourself and get the tracking done if you feel it;s out afterwards
    do you feel the grinding through the steering wheel?
  6. dplovin
    dplovin Member
    416
    no you cant feel anything really its just the noise, sounds like to peices of steel rubbing together or sumat like that, like when something needs oiling if you get me
  7. colicabcadam
    colicabcadam Guest
    usually with a CV joint you'd get some kind of feel through the steering wheel - it could be the brake shield rubbing on the discs....
    just get the car up in the air and have a look
  8. dplovin
    dplovin Member
    416
    Ok buddy thanks for the info I'll have a good check over the weekend
