Grinding noise when pulling off? (clutch releasing)
Herbsta1c Aug 31, 2011
  1. Herbsta1c
    Herbsta1c Member
    73
    Hi guys n gals
    does any one know what the above could be?
    When i bring out the clutch on my A3 2.0l tdi quattro s line (2005) it makes a very slight grinding noise? this only happens on a ratio of 2/10 so its not that bad but im worried it could get worse and i am just wondering if anyone has ever had this problem and what it could be?
    I have just had a major service from Audi and they couldn't find anything wrong with it? also a major service at 76000 miles - surely more than an oil change and inspection should be done for £269?
    Any help on the clutch problem and thoughts on the service are greatly appreciated.
    Chris ;)
  2. A1DEYB
    A1DEYB Well-Known Member
    1,681
    43
    That's the cost of going to a main dealer, a decent independent garage will do that for around £120.
    Could be the auxillary belt tensioner making noise under load or maybe the fly wheel, don't panic yet, best thing to do is find yourself a good Audi specialist and go from there.
    Generally with Audi main dealers, no fault code found on the ECU means no problems with the car.
    Main dealers don't have mechanics now, they have 'Technicians', they are trained to do the basics to cars and read errors from a fault reader and then throw parts at the car because 9/10 out of ten its warranty work and dealers love warranty work, so they pick out the likely parts which maybe causing the problems and replace them. If they do this with a customer such as yourself who is outside of the warranty period it will cost you thousands.
  3. Herbsta1c
    Herbsta1c Member
    73
    oh blimey - thank your very much for your help AidenUK - i must say i have had nothing but problems with Maidstone Audi. they seriously have stressed me out way too much!
    i really appreciate your feedback. i just don't know any other good Audi dealers round my area that can be trusted.
    i just hope this isnt something huge that needs to be done
  4. A1DEYB
    1,681
    43
    That's your problem ----> Audi dealers, now your car is out of warranty, try to find a good independent mechanic, ask friends and family who they send there cars to. Don't both with main dealer Audi any more as you will spend a fortune.
  5. Herbsta1c
    Herbsta1c Member
    73
    thanks for your advice mate ;)
  6. Herbsta1c
    Herbsta1c Member
    73
    so all in all do you think the grinding noise could be the flywheel?
  7. A1DEYB
    1,681
    43
    No problem. :icon_thumright:
  8. Herbsta1c
    Herbsta1c Member
    73
    has anyone else got an more information on this? or has had this problem before?
  9. A1DEYB
    1,681
    43
    Does the car shudder on idle and if it does, does it go away when you push the clutch flat to the floor or is it still there?
