Greeen cotton filter, delivery?
davehew Mar 10, 2010
  1. davehew
    davehew 03 1.8T Sport
    25
    How long has it taken for your filters to be delivered? Does anyone know any stockists?
  2. Welly
    Welly VX220 SC Driver :)
    10,696
    130
  3. davehew
    25
    Ah brilliant, so the fittment for the a3 and s3 are the same yes?
  4. badger5
    9,603
    2,061
    in stock with me 1-2 day delivery
  5. Welly
    10,696
    130
    I didn't know you kept them Bill, I'll bear that in mind in future... I'm considering going back to OEM airbox.
  6. finesse
    finesse Active Member
    2,805
    sorry to hijack your thread, what are the benefits of this green cotton / panel filters?
  7. Welly
    10,696
    130
    Well, the listing says for both so I assume so.
  8. davehew
    25
    Ah ok, Badger5 how much posted from yourself? Want one asap really.
  9. finesse
    2,805
    ok following my previous post, how long does a £45 filter last?
  10. Welly
    10,696
    130
    Green cotton claim 100,000 miles..... But I wouldn't use it that long.
  11. JD09
    JD09 I'm not modding, I'm improving VCDS Map User
    3,096
    46
    Better flow rate.
  12. fran-s3
    fran-s3 Active Member VCDS Map User
    1,103
    Guys as we're on the subject of air filters etc (im running standard OEM box with green cotton and drilled, trumped removed and smoothed and I love it!)
    I have a fully enclosed Forge carbon fibre induction kit I'm going to be Ebaying soon hopefully tonight. Basically I fitted it because the way it was mounted/angle it put strain on my TIP which caused my TIP to collapse under full throttle even with my silicone TIP. The TIP collapsed where it starts to angle down 90deg down to the bottom of the engine bay towards the turbo inlet right in the top corner of the bend.
    Apparently you can get special mesh to stop tip collapse but I didn't know that and can't be bothered as I'm happy with OEM now. I also have the cold air feed pipe for it but it got pretty mashed as I managed to feed it through the wheel arch liner through the tiny hole where the original oem air intake is. BELIEVE ME IT'S TIGHT! Had to take the passenger side wheel arch/fender plastic off to feed it through and it needed some flexing to go back on! Anyway as a result the cold air feed pipe is pretty mashed after being removed as you can imagine, but if anyone fancies giving it a go you can bid for it - kits worth over £150 so it could end up being a bargain.
    For the hassle I re-fitted my OEM box... Just thought I'd throw it out there in case anyones tempted can post auction no. later.
    As for the subject of green panel filters isn't there's one in the classifieds brand new right here:
    http://audi-sport.net/classifieds/s...d-new-green-stuff-panel-filter-p646531&cat=15
    GO GET IT!
  13. davehew
    25
    Contacted seller :D
  14. JS1500
    JS1500 Howdy
    1,166
    10
    I tried to contact that seller about that filter a few weeks ago, but received no reply.
  15. 1animal1
    9,978
    not confirmed im afraid James ;)
    the benefit based upon past tests has been longevity, in that you wont have to change it every service
  16. badger5
    9,603
    2,061
    confirmed flow increase over new paper oe filter.. not wow more but more.. and it wont drop off as rapidly like paper filters will as they blind
    100,000km warranty on green filters
    washable and re-oilable
    £43 filter £7 special delivery
  17. 1animal1
    9,978
    hmmmm, sure Glen tested these and the result was the paper offered no restriction and was adequate upto 300bhp
  18. finesse
    2,805
    hmmm might just get one of these filters
  19. 1animal1
    9,978
    i think you should, you sound like you should :)
