GPS Antenna
khan_1212 Aug 28, 2010
  1. khan_1212
    khan_1212 Member
    46
    Just having a rns-e headunit fitted in my audi a3 2007 sline. Will i need to fit the GPS Antenna to the rns-e unit or could i use the oem gps shark Antenna originally fitted on my car roof?
  2. VWAddict
    VWAddict Member VCDS Map User
    656
    9
    An extension fakra cable to sharkfin will work... but it's EASIER to stick a £10 'puck' GPS antenna up under the dash, behind the instrument cluster.
    Ten minutes, ten quid, versus twenty quid for an extension cable and a couplr of hours of swearing, routing the cable.
    Keith
  3. PaulAr
    PaulAr S3 (8P)
    4,073
    186
    Mine is simply a wire stuffed in the dash behind the head unit.
    Works fine.
  4. sijones
    sijones Member
    160
    Mine came with the RNS-e and it's stuck in a gap between the airvent and dash on passenger side, works perfect and can't be seen...
  5. a3_dan
    a3_dan Member
    588
    +1
