Gotta Crack In My Sump!
sparkyork Aug 16, 2014
  1. sparkyork
    sparkyork Member
    61
    Hi all gotta s reg 1.8t that's got a tasty oil leak. I've been spraying with cleaner and found a crack in the sump near the plug, gonna go breakers yard, do other audi or vw have same sumps and gaskets or sealant etc
    Any tips welcomed
  2. A3-Lee
    A3-Lee Active Member VCDS Map User
    938
    226
    43
    Search Volks bits on google new sump is 25 quid they also sell the sealer or look on ebay at the seller
  3. VAG-Slag
    VAG-Slag Well-Known Member
    1,773
    410
    I also recently suffered a "crack" in my sump, literally around the plug! lol
    No gasket available, any RTV sealant should be good, use it sparingly though! . . Worth mentioning that some earlier 20vt sumps don't have a hole for the oil level sensor. Make sure you know which one you're buying!
  4. sparkyork
    sparkyork Member
    61
    Crickey that is a crack!
    Mines only about an inch long, but don't know if it's the main cause of oil leakage, I get a lot from above the rear of the engine, I'm wonder if at speed the oil could be spraying out of the crack and swirling around the rear? I've also got a split breather hose at the front which also sprays on to the fan! Don't think mines got the oil sensor
  5. A3-Lee
    938
    226
    43
    The ones without the oil level sensor hole still fit and you can get a sensor blank for a tenner
  6. A3-Lee
    938
    226
    43
    I have taken this picture also with 4 different sumps gets annoying after smashing 4 lol
  7. sparkyork
    sparkyork Member
    61
    Didn't manage to find a sump but did find a proper dipstick tube and charcoal filter pipe.
    What's ppls thoughts on a crack in the sump causing oil behind engine but higher than were the crack is?
  8. <tuffty/>
    21,885
    4,204
  9. sparkyork
    sparkyork Member
    61
    Cheers tufty, wonder if a retro fit is poss for a oil sensor. Think the crack is bigger than I thought needs sorting this week or it'll be bye bye engine!
