GOT THIS FAULT !!
vw754 Mar 27, 2013
  1. vw754
    vw754 vorsprung Durch Technik
    2,345
    58
    00573 - Steering Torque Sensor (G269)
    008 - Implausible Signal
    All ive had done was drivers side cv boot replaced (driveshaft had to come off) as cv would not budge,and had cambelt done.cleared above fault but keeps coming back...........steering assist (44) in vcds.......terminal 15 is on and relay is on.........turned steering left/right multiple times (as stated in ross-tech) all the torque values do change. anything else?
  2. mike foster
    3,967
    See if this helps :- 00573 - Ross-Tech Wiki
  3. vw754
    2,345
    58
    like time since i chatted to you mike.....you helped me last year,anyway,nice to hear from you......il check the fuses under bonnet and side of dash in morning.......all that was done was take track rod end off the hub side in order to take shaft off,dont understand whats happened her.
