Saturday,10,March,2018,20:35:59:07086
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 18.2.0.3 (x64)
Data version: 20180212 DS287.0
www.Ross-Tech.com
VIN: WAUZZZ8X4********* License Plate: A1 TFSI
Mileage: 100600km-62509mi Repair Order:
Chassis Type: 8X-AU21 (8X0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 52 5F
VIN: WAUZZZ8X4******** Mileage: 100600km-62509miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
Address 01: Engine (BK2-CAXA) Labels:. 03C-906-016-CAX2.clb
Part No SW: 03C 906 016 BH HW: 03C 906 016 BG
Component: 1.4l R4/4V TS H07 7768
Revision: LEH07--- Serial number:
Coding: 00250032002401000000
Shop #: WSC 00046 790 00000
ASAM Dataset: EV_ECM14TFS01103C906016BH 001006
ROD: EV_ECM14TFS01103C906016BH.rod
VCID: 66C9A5D6997C637482-8032
4 Faults Found:
5250 - Function Restriction due to Faults in Other Modules
U1113 00 [032] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
4660 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [032] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
4718 - No Communication with Transmission Control Module
U0101 00 [032] - -
4106 - Bank 1; System too Rich at Idle
P2188 00 [096] - -
Readiness: 0000 0000
Address 02: Auto Trans Labels: 0AM-927-769.clb
Part No SW: 0AM 300 050 N HW: 0AM 927 769 D
Component: GSG DSG AG7 403 9061
Revision: 00040034 Serial number: CU501011065045
Coding: 0000020
Shop #: WSC 45986 001 1048576
VCID: 346D0F9E5420C1E4CC-5136
1 Fault Found:
006012 - Clutch 2
P177C - 001 - Tolerance Limit Reached - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 19
Reset counter: 8
Mileage: 100197 km
Time Indication: 0
Date: 2018.02.23
Time: 15:55:10
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AH HW: 6R0 907 379 AH
Component: ESP8.2i front H07 0004
Revision: --------
Coding: 330448E9237100B5CC2C12E7C4D100910D00
Shop #: WSC 00046 000 00000
VCID: 040D9F5E8300B1643C-8050
No fault code found.
Address 08: Auto HVAC (J255) Labels:* None
Part No SW: 8X0 820 043 A HW: 8X0 820 043 A
Component: Klima 1 Zone H12 0050
Serial number: 00000000025401
Coding: 6420080000
ASAM Dataset: EV_AirCondiFrontAU210 006031
ROD: EV_AirCondiFrontAU210_006.rod
VCID: 326109866534CFD4DE-8066
2 Faults Found:
0001 - Motor for Temperature Flap
B108F 07 [008] - Mechanical Failure
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 3
Fault Frequency: 3
Reset counter: 49
Mileage: 100185 km
Date: 2018.02.23
Time: 06:53:05
Voltage terminal 30: 14.2 V
Interior temperature: -1.0 °C
Outside air temperature: -1.5 °C
Temperature flap: specified value-Data: 100.0 %
Temperature flap: actual value-Data: 98.8 %
0051 - High Pressure Sensor
B10AE 84 [009] - Signal below allowable range
Freeze Frame:
Fault Priority: 2
Fault Frequency: 254
Reset counter: 18
Mileage: 96879 km
Date: 2017.11.01
Time: 09:09:49
Coolant temperature: 10.50 °C
Interior temperature: 10.9 °C
Coolant fan activation: specified value: 0.0 %
Engine speed: 876.00 /min
Refrigerant pressure: 1.0 bar
Compressor current: actual value: 0 mA
Outside air temperature: 11.0 °C
Address 09: Cent. Elect. (J519) Labels:. 8X0-907-063.clb
Part No SW: 8X0 907 063 D HW: 8X0 907 063 D
Component: BCM PQ35 M 108 0621
Revision: 00108 AB
Coding: 0E000A2FA007F100201841E021000154537B6C0A01EF4922DC0887830045
VCID: 3D7B2ABAA46A00AC33-8068
Subsystem 1 - Part No SW: 8K0 955 559 HW: 8K0 955 559
Component: RLS H04 0003
Serial number: 11159190
Coding: 02562D
Subsystem 2 - Part No: 8X0 951 177
Component: DWA-Sensor H0 H01 0010
Subsystem 3 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
1 Fault Found:
00897 - Windshield Washer Pump (V5)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 50
Mileage: 100261 km
Time Indication: 0
Date: 2018.02.28
Time: 08:25:36
Freeze Frame:
Term 15 On
Voltage: 14.25 V
ON
ON
Term 50 On
OFF
OFF
Address 10: Park/Steer Assist (J446) Labels:| 8X0-919-475.clb
Part No SW: 8X0 919 475 HW: 8X0 919 475
Component: PARKHILFE 4K H03 0011
Revision: 11001001 Serial number: 37031031406080
Coding: 000101
ASAM Dataset: EV_AU210ParkAssis4K 002006
ROD: EV_AU210ParkAssis4K.rod
VCID: 030F9C428A0EB65C05-8056
Address 15: Airbags (J234) Labels:| 8X0-959-655.clb
Part No SW: 8X0 959 655 A HW: 8X0 959 655 A
Component: Airbag10.41 H04 0008
Revision: -------- Serial number: 003JJ000BKL7
Coding: 30314539303330303034554A305238583053
ASAM Dataset: EV_Airba1041BPAAU210 001015
ROD: EV_Airba1041BPAAU210.rod
VCID: 48954B6EF3A8550490-801C
Crash sensor for side airbag: driver side:
Serial number: 3554VRB405V6VQ8CEH9Y
Crash sensor for side airbag: front passenger side:
Serial number: 3575HRB405307OTSE1O%
Crash sensor for front airbag: driver side:
Serial number: 3585HRB405B07OTSDO7D
Rear Impact Crash Sensor:
Serial number: 3515ZRB405102CBCE98-
Address 16: Steering wheel (J527) Labels:| 8X0-953-569.clb
Part No SW: 8X0 953 501 D HW: 5K0 953 569 H
Component: LENKS.MODUL 009 0136
Revision: FF010015 Serial number: 20101123300194
Coding: 1984204000
ASAM Dataset: EV_VW360SteerWheelUDS A03004
ROD: EV_VW360SteerWheelUDS.rod
VCID: 3B7F24A2B27E0E9C0D-806E
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 4G0 951 528 C HW: 4G0 951 528 C
Component: E221 - MFL H07 0009
Address 17: Instruments (J285) Labels:| 8X0-920-xxx-17.clb-SRI1
Part No SW: 8X0 920 980 HW: 8X0 920 980
Component: KOMBI H07 0124
Serial number: 00000000000000
Coding: 41DE00
ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04086
ROD: EV_Kombi_UDS_VDD_AU10.rod
VCID: 7CFDE7BEF7F0C9A444-8028
Address 19: CAN Gateway (J533) Labels: 8X0-907-468.clb
Part No SW: 8X0 907 468 A HW: 8X0 907 468 A
Component: GAT 4CAN 1L M H04 0083
Revision: 1C060023 Serial number: 2341C10A05037E
Coding: FBCF0064000100010153
VCID: 438F5C42C28E765C45-8016
Subsystem 1 - Part No SW: 8K0 915 181 G HW: 8K0 915 181 G
Component: J367-BDM H07 0150
Serial number: 00000000009370205330
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042
Serial number: 10327000540011200181
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Component: IMMO H07 0124
Serial number:
Coding: 000002
ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04008
ROD: EV_Immo_UDS_VDD_AU10.rod
Address 42: Door Elect, Driver (J386) Labels:. 8X0-959-793.clb
Part No SW: 8X0 959 793 D HW: 8X0 959 793 D
Component: TSG FA H09 0409
Revision: -------- Serial number: --------------
Coding: 011E02200101120102
VCID: 4E997D7619CC8B34DA-801A
1 Fault Found:
02111 - Motor for Window Regulator
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Freeze Frame:
Fault Status: 00100101
Fault Priority: 3
Fault Frequency: 3
Reset counter: 34
Mileage: 99279 km
Time Indication: 0
Date: 2018.02.01
Time: 08:03:46
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11251
Shop #: WSC 00046
VCID: 2F6700F2EA06E23CB1-807A
Address 52: Door Elect, Pass. (J387) Labels:. 8X0-959-792.clb
Part No SW: 8X0 959 792 D HW: 8X0 959 792 D
Component: TSG BF H09 0409
VCID: 4D9B7A7A14CAB02CA3-8018
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 8X0 035 193 HW: 8X0 035 192 A
Component: RMC Cnct Nav H45 0530
Coding: 01010000008053070023020103010000000000
VCID: 75EBF29ADCDA98EC3B-8020
Subsystem 1 - Part No SW: 8X0 919 603 HW: 8X0 919 603
Component: DU6 Basic H42 0084
Serial number: 9462KR0A0041680
End-------------------------(Elapsed Time: 03:11)--------------------------
www.Ross-Tech.com
4 Faults Found:
U1113 00 [032] - -
U1017 00 [032] - -
U0101 00 [032] - -
P2188 00 [096] - -
Coding: 0000020
1 Fault Found:
006012 - Clutch 2
Freeze Frame:
Fault Priority: 0
Fault Frequency: 19
Reset counter: 8
Mileage: 100197 km
Time Indication: 0
Date: 2018.02.23
Time: 15:55:10
Revision: --------
Coding: 6420080000
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 49
Mileage: 100185 km
Date: 2018.02.23
Time: 06:53:05
Freeze Frame:
Fault Priority: 2
Reset counter: 18
Mileage: 96879 km
Date: 2017.11.01
Time: 09:09:49
Revision: 00108 AB
Coding: 02562D
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 50
Mileage: 100261 km
Time Indication: 0
Date: 2018.02.28
Time: 08:25:36
Freeze Frame:
Term 15 On
Voltage: 14.25 V
ON
ON
Term 50 On
OFF
OFF
Coding: 000101
Coding: 1984204000
Coding: 41DE00
Serial number:
Coding: 000002
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 34
Mileage: 99279 km
Time Indication: 0
Date: 2018.02.01
Time: 08:03:46
Coding: 11251
Shop #: WSC 00046
