Got the S3 and not a good start !! - Help/info needed
L e o Feb 27, 2010
  1. L e o
    L e o Member
    33
    Hi all,the car dealer dropped off my '07 S3 with 20,000 mls yesterday and all was fine,my mate came round last night and had a look and fired her up and let it idle and all was well,today i started it up to go and get some fuel as it was desperatley low and it idles like a pig and just about ticks over,also it revs itself up and down up and down... (up to 2000 rpm and back down) - so filled her up with fuel thinking it may have been because it was so low and took it for a blast but still the same !!
    Anybody suffered this or may know what it is or have any advice ?
    My previous car was an Astra VXR and it never missed a beat in over 2 years,also dare i say it - it seemed more fiesty than the S3 ? Thanks in advance
    A.T.B Leo
  2. thebott
    thebott Member
    211
    Get it back to the dealer...............
  3. RobinA3
    RobinA3 Well-Known Member
    1,826
    46
    whats your location?
    you need to get someone with vagcom to scan the ecu to see what fault codes are recorded
    or get the AA out.
  4. paddy
    paddy Audi=No fault code, no idea
    5,168
    136
    My 3.2 does this and it dosnt have fault codes. Just pray it still does it when the dealer comes or you will end up like me being told its supposed to do that if it dosnt have a code :-(
  5. Lee_R
    Lee_R Active Member
    2,499
    12
    Having driven an S3 and a VXR, I'm with you on the urgency issues! The VXR is like a scalded cat compared to the S3, the S3 actually gets the power down though and is superior in every other way.
  6. Khufu
    Khufu Well-Known Member
    5,704
    31
    erratic idling can often be an air leak. As said, back to dealer. They can check it for a fault!!
  7. thebott
    thebott Member
    211
    An astra VXR v.s S3 ........... come on ...............:no:
  8. N8
    17,163
    718
    Back to the dealer, get it sorted! Nothing worse than your car not running properly! :sorry:
  9. paddy
    5,168
    136
    lo...get it back to the dealer ? what the f*ck do they know. Like i say, if it dosnt have a fault code...there is no fault, period.
    Yea i know its **** but Audi only employ "technicians "............not mechanics.
  10. N8
    17,163
    718
    Nothing :eiertritt:
  11. yahyar
    yahyar Member
    I had a similiar problem when i got my MY09 s3. the revs would search up till 2000rpm. vagcom did show a fault, but audi couldnt fix the problem immediately.
    it turns out it was air leak as the vacuum pipe wasnt properly connected, according to the technician
    this was only discovered after audi replaced the throttle body on a 3000km car - a ZAR8000 job
