Got my rs3 diffuser on
discostu49 Mar 1, 2014
  1. discostu49
    discostu49 Active Member
    598
    132
    43
    Ironborn and P40 THN like this.
  2. JJ.Foulds
    JJ.Foulds Well-Known Member
    1,263
    176
    more pics pls, one straight looking it far a bit further away? :p
  3. discostu49
    598
    132
    43
    uploadfromtaptalk1393707228407.jpg uploadfromtaptalk1393707257123.jpg uploadfromtaptalk1393707281675.jpg
    AdriansS3 and Av4nt like this.
  4. (Dan Crook)
    (Dan Crook) Member
    87
    That looks epic! The RS3 only fits the sport back doesn't it? :( ..
    discostu49 likes this.
  5. discostu49
    598
    132
    43
    Thanks, no it fits any s3 lower spoiler so would fit 3 door
  6. manor13
    manor13 Active Member
    726
    110
    43
    quality what years yours? trying to get something for my 2006 SB
  7. discostu49
    598
    132
    43
    Mine is a 2006 model
  8. manor13
    726
    110
    43
    perfect whats the part nos and cost? easy to fit DIY
  9. discostu49
    598
    132
    43
    I just called the dealers £97 for the s3 lower spoiler and £194 for the rs3 diffuser £50 to spray the spoiler and I fitted it myself, easy to fit give me a shout if you get it and I will talk you through it
  10. MorkC68
    MorkC68 Stationary
    171
    27
    I do like the look of the diffuser!
  11. s3_trev
    s3_trev Northern Ireland Gold Supporter Audi S3 Team Brill Red
    1,866
    644
    Nice. You planning to sort out that arch gap at the back??
  12. nil538
    nil538 Active Member
    499
    66
    Looks good mate
  13. discostu49
    598
    132
    43
    Arch gap ? If your referring to the height I had just had it jacked up as had to take the wheels off so rear was a little higher for a bit but the cars on eibach pro springs however Im no happy with the look and want lower all round so will see how it looks after I put on 19"s
    s3_trev likes this.
  14. JJ.Foulds
    1,263
    176
    have u got bigger than normal exhaust holes?
  15. manor13
    726
    110
    43
  16. manor13
    726
    110
    43
  17. discostu49
    598
    132
    43
    The exhaust is a magnaflow so yes bigger holes 3" exit
  18. discostu49
    598
    132
    43
    That link for the eBay item looks like it's a mould or a copy so might be different fitting can't see how tho,
  19. discostu49
    598
    132
    43
    Yes it was Perth Audi any dealer can supply tho, they call the s3 part lower spoiler I called it a valance and as for the rs3 part just give them a reg of a rs3 and there is only one diffuser which comes gloss black , I looked at replicas and moulds but the original Audi ones all the holes and clips are perfect was doubtful for copies
  20. Mindak
    Mindak Active Member
    799
    130
    43
    Do these take much to fit, I have a 2007 s-line sportback?
  21. Icey
    Icey Member
    121
    13
  22. discostu49
    598
    132
    43
    nah its pretty easy to do i just jacked it up and popped off the rear wheels took off the inner arch liner and had access to the screws that release the bottom lip there is only one screw each side that is a bugger to get to so had to pop the rear bumper a bit bit that just pulls away from the rear quarter panel, thought i was going to have to take the rear bumper off but didn't need to, i did it all by myself in an hour and i work in an office so that should explain the hardness level.
  23. discostu49
    598
    132
    43
    from that angle i would say that it would fit but would get a second opinion if i were u
  24. InvincibleA3
    InvincibleA3 Member
    163
    Hi mate , referred to your thread and looking good :)
    Just like your rear bumper , just to clarify , take of my rear splitter on current bumper and attach the diffuser and valance and no modifications required ?
  25. Ironborn
    Ironborn English...not so good
    1,179
    227
    I heard it's not a straight fit for 3 door cars, some mods have to be done to make it fit.
  26. discostu49
    598
    132
    43
    Yup no mods needed, it clips off easy, I found it easier once I had uncliped the actual bumper from the rear arch I thought I'm going to need to remove the rear lights but didn't need to unclip the bumper that far up it's really just the sides at the rear arch, and as stated there's a screw each side behind the wheel liner that holds the spliter to the bumper it's a bummer to get to but with the arch unclipped you can slip your hand down to it, yiy can see it when you stick your head under the car but it's impossible to unscrew it from underneath as the screw faces down you will see what I mean
  27. discostu49
    598
    132
    43
    The s3 diffuser is one size fits all I'm pretty sure
  28. InvincibleA3
    InvincibleA3 Member
    163
    Il give it ago if I'm there when he does it , but I think il leave it in body shops hand lol
    In terms of the valance , you have the one with more fins , will this one fit too
  29. discostu49
    598
    132
    43
    Yes the one in this pic is the standard s3 one was made for the valance I have the rs3 one where u need to trim the valance but only parts that you can't see
  30. discostu49
    598
    132
    43
  31. InvincibleA3
    InvincibleA3 Member
    163
    Do you have the part number for the one in the pic ?
    I've got :
    8P4 807 434 G 1RR or 8P4 807 434 F � Valance
    8P4 807 521 K � lower Outer Bit
  32. discostu49
    598
    132
    43
    I don't have the part Numbers to hand at the moment I'm afraid
  33. InvincibleA3
    InvincibleA3 Member
    163
    No problem , il just call audi tomorrow and il order both the valances in as well as the diffuser , hopefully that should work
    And take a pick
    Thanks for your help mate :)
    Just need to find a roof spoiler now and side skirts
  34. Muzza80
    Muzza80 Well-Known Member
    699
    337
    oops double post...
  35. Muzza80
    699
    337
    That's not an S3 lower rear valance they have sold you mate it's an RS3 one.
    The S3 lower valance section needs a lot cut away from it to allow the RS3 rear diffuser to fit properly, I know as I fitted one to my S3 Sportback.
    I'm also almost certain the RS3 diffuser only fits a Sportback S3 rear lower valance (with the modification I mentioned above) or an RS3 valance like you have, but not sure either of these fit a 3 door, the bumpers are a different shape.
    Could be wrong but would suggest 100% clarification for 3 door people before going shelling out £300 on bits.
  36. discostu49
    598
    132
    43
    There is only one valance I bought it and cut it and fitted it all myself without the use of a bodyshop was one long cut that was all just to remove the center section
  37. InvincibleA3
    InvincibleA3 Member
    163
    That's exactly the rear valance and diffuser i want , is that trim (silver/white) standard or did you paint it ?
  38. discostu49
    598
    132
    43
    That's the same as mine but with the lip painted silver
  39. Muzza80
    699
    337
    I'm about 99.897654% sure there's a proper RS3 lower valance that fits the RS3 rear diffuser properly without cutting, I'm sure I came across it in etka when I was looking before fitting mine.
    I never realised you had cut yours, fair enough, easier off the car I bet :)
    My strip is painted the proper matt alu paint the RS3 alu styling pack bits come in.
  40. discostu49
    598
    132
    43
    Don't think there is the I gave the dealer a rs3 reg and the valance associated to the rs3 is the same as the s3 they cut the rs3 valance at the factory, my mate had his off his rs3 when he damaged it and you can see it's roughly cut
    Muzza80 likes this.
