JMB-S3
Right I have got a couple of faults coming up a few of them are quite old but I have only recently bought the car and been able to scan it with full VCDS, anyway the faults are below so any help with solving them will be much appreciated.
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8P0 035 192 L HW: 8P0 035 192 L
Component: RNS-E HIGH EU H73 0650
Revision: 03S Serial number: AUZBZ7G0908239
Coding: 0209715
Shop #: WSC 00022 210 90990
VCID: 387B2CD332C3
4 Faults Found:
00878 - Connection to Speaker Front Left
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 250
Time Indication: 0
Date: 2011.11.22
Time: 16:22:53
00879 - Connection to Speaker Front Right
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 250
Time Indication: 0
Date: 2011.11.22
Time: 16:22:53
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 250
Time Indication: 0
Date: 2011.11.22
Time: 16:22:53
02005 - Coding Pin
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 250
Time Indication: 0
Date: 2011.11.22
Time: 16:12:41
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0209715
VCID: 387B2CD332C3
4 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 250
Time Indication: 0
Date: 2011.11.22
Time: 16:22:53
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 250
Time Indication: 0
Date: 2011.11.22
Time: 16:22:53
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 250
Time Indication: 0
Date: 2011.11.22
Time: 16:12:21
02005 - Coding Pin
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 250
Time Indication: 0
Date: 2011.11.22
Time: 16:12:41
Address 03: ABS Brakes Labels: 1K0-614-517-MK60-A.lbl
Part No SW: 1K0 614 517 AD HW: 1K0 614 517 AD
Component: ESP 4MOTION MK60-AT 0102
Revision: 00H14001
Coding: 0021128
Shop #: WSC 06314 000 00000
VCID: 69DDB99739E9
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
J
Coding: 0209715
VCID: 387B2CD332C3
4 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 250
Time Indication: 0
Date: 2011.11.22
Time: 16:22:53
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 250
Time Indication: 0
Date: 2011.11.22
Time: 16:22:53
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 250
Time Indication: 0
Date: 2011.11.22
Time: 16:22:53
02005 - Coding Pin
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 250
Time Indication: 0
Date: 2011.11.22
Time: 16:12:41
Coding: 0209715
VCID: 387B2CD332C3
4 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 250
Time Indication: 0
Date: 2011.11.22
Time: 16:22:53
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 250
Time Indication: 0
Date: 2011.11.22
Time: 16:22:53
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 250
Time Indication: 0
Date: 2011.11.22
Time: 16:12:21
02005 - Coding Pin
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 250
Time Indication: 0
Date: 2011.11.22
Time: 16:12:41
Revision: 00H14001
Coding: 0021128
VCID: 69DDB99739E9
1 Fault Found:
J
