Got a K03(S) installed and want more bhp?
badger5 Jan 9, 2012
  1. badger5
    9,471
    1,988
    Introducing K03 Hybrid plus, aka K03/2283 as I call it.. (made up name btw)
    Its a 2283 compressor, on RS6 turbine, mounted into a K03 fitment type turbo.
    anyhows....... latest dyno after setting up an eboost controller onto our 1.8t lupo (aum engine, with Rods ;) )
    Switchable for mrsB now (its her daily, well was suppoed to be)... 280bhp or 325bhp :think:
    3 settings of boost control now
  2. superkarl
    superkarl MAN OF STEEL
    9,467
    2,421
    wow. what on earth does your other half think of it?!? in a car that size it must be savage!
    so whats the supporting mods for this?
    its a ko4 compressor housing right?
    (gets confusing all the wheel names/specs/sizes and what they'l fit into)
  3. Reesy
    Reesy Well-Known Member VCDS Map User
    3,640
    148
    I am looking at what is next for my tqs.
    I think I no longer need to look.:yahoo:
  4. Paradox1
    Paradox1 Active Member
    1,833
    88
    that's too sick!
    bill can i have it?
    is 325bhp the most it will make? if so that is very impressive but think ill turn it down a bit.more info please!
  5. badger5
    9,471
    1,988
    yea its a k04 comp cover mated to a k03 one (for its outlet), and k03 hotside with RS6 turbine
    essentially a k04 hybrid squeazed into a k03 fitment..
  6. badger5
    9,471
    1,988
    I think 325bhp is its realistic max... EGTs sustained at this level or more will be too high
    egt's i will relog, but at this level they're at remapped staged 2 K04 levels of 920-940'c - hot... Same hot as a lot of S3/LCR run, unknown to their owners!
  7. Paradox1
    1,833
    88
    I see. I have a ko3 spare turbo.isit a case of sending it to you for you to organize the hybrid work and at what cost? what other mods are needed to safely get the best from this setup
  8. badger5
    9,471
    1,988
    rods.
    fuel pump
    injectors to name a few
    i will add a thread in my section on info relating to this....
  9. beachbuggy
    beachbuggy Well-Known Member
    1,931
    201
    Are you planning on building these up yourself or buying them in?
  10. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,184
    Bill, could you please PM me the costings and what you would advise on further supporting mods from what I already have to give me 260 bhp (rod friendly).
    REALLY interested in this, if the costings are cheaper than a second hand K04 setup + mapping.
    What manifold was used for the 325bhp? Please say one of your ported AGU manifolds.
  11. Prawn
    11,502
    3,411
    Been following this on SCN, and as you know already Bill, I think it's awesome!
    That middle line, 280bhp at 16psi, that's exactly what I want from mine! Low linear torque, amazing power at really low boost. Must be incredible to drive in the little lupo.
    is this with any WMI? or just the new FMIC you fitted? Still smallport isn't it?
  12. badger5
    9,471
    1,988
    i am not building them myself no... i leave that for turbo manufacturer. i am busy enough.
    manifold on the lupo is one of frankenturbos. ii do plan dropping on a ported stock manifold when i get a few minutes to compare.
    on the road tonight, damp, it was spinning up a lot... and when i did get a brief bit of open road, it span up in 3rd, snaked in 4th as i overtook a car... i was backing off the throttle to calm it down.. not the conditions to explore. (this was on high boost)
    wmi is on and running. not tuned for it tho (yet) zero timing pull until last of the high boost runs where it did pull a little. it was bloody hot poor thing
    wmi is advised on this hybrid as are rods if exploring the boost
  13. Prawn
    11,502
    3,411
    Which electronic boost controller are you using for this Bill? I assume it's a static controller only, and not linked to RPM or gear?
    I'm looking at the gizzmo MS-IBC, but I've not bought anything yet.
    is this setup using EBC only? or the EBC in parallel with the N75?
  14. badger5
    9,471
    1,988
  15. beachbuggy
    1,931
    201
    Sorry to ask more questions Bill
    Are you using the stock actuator on this? I only ask as I read that nick at r-tech had problems with the stock actuator holding the waste gate closed on his k03s-023 hybrid and he fitted a forged actuator with yellow( what ever rating that was) I assume he did this though as he was running 23+ psi and it struggled against your 16 odd psi. Would that be the case? Also with regards measuring the EGT's did you have to put a port in the housing for this?
    Great piece of kit though, very impressive.
  16. badger5
    9,471
    1,988
    its not a stock actuator no (not 5psi) this one runs 10psi actuator pressure.
    egt's are measured in the collector of the manifold on this one. logged on the dyno.
  17. jcs356
    jcs356 Brum brum
    2,726
    67
    Wow - keep up the good work Bill!
  18. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    That is nuts! Nice one again Bill!
  19. Syvo
    Syvo IF IN DOUBT GO FLAT OUT
    1,338
    22
    where do we sign to get one
  20. Paradox1
    1,833
    88
    bill can you pm me a price for the turbo,fitting and mapping? als what warranty does the turbo come with?
  21. badger5
    9,471
    1,988
    I will post prices in my section shortly
  22. moredoor
    moredoor Member
    160
    That 280 curve is very nice and smooth, nice work Bill. Is the full thread on SCN?
  23. Paradox1
    1,833
    88
    don't think he's posted it yet,I hear he's a busy guy
  24. badger5
    9,471
    1,988
  25. SHUk
    SHUk Once Bitten Forever Smitten =]
    211
    Bill is the rs6 turbo you used this one:
    http://pages.ebay.com/link/?nav=item.view&alt=web&id=321429512189&globalID=EBAY-GB
  26. badger5
    9,471
    1,988
    no
  27. SHUk
    211
    Hahaha, ok which one do I need? Thanks =]
  28. SHUk
    211
    Bill...
    Where can I find specifications?
  29. badger5
    9,471
    1,988
