Gops' Subtle mod thread
Gops Apr 11, 2012
  1. jojo
    28,998
    3,651
    I can't wait to have a go G! :racer:
  2. Andrew@A.L.D
    3,879
    617
    Looking forward to how my Haldex sandwich bias will be like?
  3. Gops
    3,198
    666
    I'm defo looking forward to that! I'm sticking it 50/50 first, then half open/close for 70:30. I think that'll be a good daily.
  4. badger5
    9,599
    2,060
    you saw my comment Gops re your haldex.
    if I cant turn it off I cant map your car
  5. Gops
    3,198
    666
    Yes bill, the haldex can still be turned off via the fuse or connector, the sandwich plate only limits the fluid to the haldex making it more rear bias I think. It's totally adjustable so I can revert it to stock anyhow! :)
    badger5 likes this.
  6. Andrew@A.L.D
    3,879
    617
    Vert true
    No need to worry Bill
    badger5 likes this.
  7. Gops
    3,198
    666
    i will look into this.. Ill see if the DP should require it. From what I can remember it was the early DP's that were abit small? But I will defo see to that!
    thanks bud! Looking forward to it too! :)
    lol thanks nick! Your build made me want to get some power! I think stage2 just isn't enough to keep with modern cars! Like to push the boundaries but still be safe! Although I want this turbo to do very well, I also want it to be healthy and long lasting, to me that's more important!
  8. Prawn
    11,667
    3,665
    I think if recent results are anything to go by you should be looking at 330+ for sure.
    I know Dan created the turbo to be a 'baby' hybrid, but it seems the larger turbine on stock sized compressor has really changed things! the 11 blade wheel design in yours should be pretty interesting, and the special housing has to be a good thing too!
    All points in the right direction that's for sure!
  9. Gops
    3,198
    666
    It does look that way! Totally depends on the build of the car, ill log the car when it's been Run in and see the theoretical power it's running! Got some 550's going in when it's being mapped by bill so hopefully it won't max out like Russ's did. Testing is key, I've said to Dan and bill, they can have the car for testing whenever they please as it will be benefiting everyone :) ill be driving my mums lovely 1.25 fiesta that I actually couldn't hit 60mph! Gonna put some v-power in that bad boy.. Lol
  10. S3 Rav
    S3 Rav Well-Known Member
    2,825
    30
    Good effort gops! Going to be mental!!
    Gops likes this.
  11. Broken Byzan
    13,237
    466
    Corrected for you :jump:
    Gops likes this.
  12. Gops
    3,198
    666
    Can you imagine that fiesta with a k04!
  13. Gops
    3,198
    666
    cheers Rav! Will be good when it's finished! Was meant to do it all myself but couldn't get any more time off (that I was meant to have!!) so it's going in to Jody's to have majority of the work done! It was too late to book it in to bill by the time I found I couldn't have the time off and he was so busy anyhow, just about got some time for mapping, wideband and wmi! Thankful to Jody for putting up with me and all my pestering emails and calls lol! Going in tomorrow, will be trial fitting the sandwich plate too.
  14. Andrew@A.L.D
    3,879
    617
    Gops i'm going to call the sandwich plate a Haldex bias plate
    chaz20vt and Gops like this.
  15. Gops
    3,198
    666
    Well I have an update! The cars in, already stripped the rear haldex and gearbox out ready for its new one.. But when I dropped it off, they had only started. Still I had a chance to test fit the new haldex bias plate by Andrew! Very very easy to fit.. From what I can see there is no modifications needed but will update that once the haldex unit is on the car itself. It doesn't seem to hot anything as its only near the prop shaft doughnut so should fit ok.. So without further due...
    First thing I did was make sure that the thread was closed fully:
    Then I marked this position with a green marker as closed to the left. I also set the lock nut and marked the thread between the lock nut and the big knob thingy so that If I ever lose the positioning, I can refer that the locknut was x turns away from the knob and that the thread is closed when the green markings line up to the left as such:
    Next was a half way turn which was 2 and a half turns from closed
    And again I green marked this, this time to the right
    Then a further 2 and a half turns (which takes the markings back to the left) is fully open
    Now already I can suggest that it would be better to have the inside thread stop when the hole is fully closed, instead it'll keep going in.. Only because for reference reasons it'll be simpler.. But this is totally fine! You will have to set the lock nut every time you adjust the bias, but as long as you mark on the thread as I've done here (not the best pic)
    Then you will know that if I set the lock nut at that mark, and fully close it lining the markings to the left, it will be full 50/50. There's probably a better way but I just chose to be complicated :)
    Here's some pics on how it looks fitted.. Best thing to do is use some elastic bands, fit it to the haldex unit with both gaskets and pop an elastic band around it so it doesn't fall apart. Then position it, and loose fit the bolts so you can then cut the elastic band and full tighten the haldex.. It's worth it since your saving loads if cash on a performance controller so no complaining lol!!
    I will get better pics with it on the car to show clearances but I'm confidant it will fit with no problems..
    Westy, StaceyS3 and Andrew@A.L.D like this.
  16. Andrew@A.L.D
    3,879
    617
    Look forward to your review of how it drives
    Gops likes this.
  17. Gops
    3,198
    666
    Should have it by the end of the week to drive hopefully! Can't wait :)
    chaz20vt likes this.
  18. Gizmo20VT
    Gizmo20VT Active Member
    294
    Edit: Any idea how the rear diff clutches would handle this mod?
  19. Andrew@A.L.D
    3,879
    617
    it increases oil pressure that engages the haldex clutch, not really recommended running it with full or half bias for long periods of time so if you want you can go back to standard just twist of the knob anti clockwise 5 turns and you standard.
    the haldex runs a temp sensor so if it gets to hot it shuts down but I'm also working on a oil capacity increase mod to help keep it cool
    the design of the haldex bias valve is waiting for a patent
    StaceyS3, Gizmo20VT and kwistof like this.
  20. Gizmo20VT
    294
    Well done Andrew, seeing that I cant sell my old diff + controller here in SA might just use it for the 50/50 mod :D
  21. Andrew@A.L.D
    3,879
    617
    If you have a damaged controller then this can compensate until you get a replacement controller.
    jojo likes this.
  22. Gops
    3,198
    666
    Right guys sorry for the lack of updates.. It's been abit rocky here and there which I will explain later..
    Picked the car up today after it has been ran in.. Seems nice and fine. Sounds like the cams are abit noisey bit I dunno if that's down to the ST exhaust valves or not.. On the way home from midland vw and the car seems like it's boosting like mad! N75 is turned off and it was flying!! I got abit concerned so I relaxed abit. Then I paid on the m6 toll, accelerated and it popped loudly from the exhaust! I pulled over immediately and checked everything was ok Which it seems fine, no smoke, no oil just timing is all over the place! Seems like the AGU pistons are having it's effect so I just crawled home after calling bill. I'm taking it in tomorrow early and leaving it with him for a while so will see how it goes.. I hope everything is ok, the garage seemed everything was fine with it? Oh one thing, the DP is rubbing on the prop shaft, I think with the manifold and turbo, the DP has moved across slightly causing the flex to hit the DP.. Not the best but that's relentless for you! I guess with a spacer plate I between the turbo and DP it might just push it over a little and it may be fine then, see what bill says about that. I didn't wanna push the car too much so I can't comment on the turbo, seems nice though! I'm on a night shift tonight and I havnt had a wink of sleep, so I'm sleeping for about 40 mins until a very hectic 24 hours! :|
  23. everard90
    everard90 Member
    37
    it looks like the pin of the new plate looks like it will hit the rear diff rubber doughnut on the last 2 photos or am I looking at it wrong
  24. chaz20vt
    chaz20vt Member
    428
    21
    Any more news gops or a good write up of progress so far
  25. badger5
    9,599
    2,060
    cars here. wmi being fitted and widebanded as I type
    mapping, if everything goes ok should be friday
    Nilz, <tuffty/> and Gops like this.
  26. Gops
    3,198
    666
    Bill is on a roll! I seen how busy he is, so I fed him with his favourite.. And hopefully everything goes to plan! Can't thank him enough!
    But yeah cars been done, slight rub on the propshaft but I will try and sort that out soon.. I'm gonna ask my dad to make me a spacer plate to move the relentless DP a couple of mm to stop it from hitting the prop.. That's if I can't sort it without..
  27. superkarl
    superkarl MAN OF STEEL
    9,610
    2,481
    Strategic dent. All the best zorsts have them
    kwistof, StaceyS3 and Gops like this.
  28. Prawn
    11,667
    3,665
    heat it, bash it, enjoy it :)
    What exactly is being done Gops?
    Wide band conversion, WMI, and custom mapping of the new spec hybrid?
    Gops likes this.
  29. Broken Byzan
    13,237
    466
    :jump:
    slowcoach3 and Gops like this.
  30. Gops
    3,198
    666
    Haha I will do that only if nothing else sorts it! I'm sure my dad can make a little spacer.. Makes things bit easier! Sometimes I wish I had a DP made from bill, would of been well worth the money! Relentless have caused nothing but problems!
  31. Gops
    3,198
    666
    Yeeerp!! Lets see how the old girl does!
  32. Westy
    Westy Well-Known Member
    17,443
    1,105
    Is it just the standard 3" relentless DP? I sorted mine by moving it over a few mm then used a small jubilee clip on the DP exhaust bracket to hold it in place. Works a treat.
    Gops likes this.
  33. Gops
    3,198
    666
    Will try that westy cheers! Ill have a chance to get under the car this weekend so will play around with it to push it further right. Good news is ill be reporting live at Badger 5 HQ tomorrow :)
    It's been abit of a slippery slope to this point, everything went smooth apart from a few problems with the head, but nothing that couldn't be fixed! Resulting in just the exhaust valves being supertech..
    Had a new gearbox and clutch which might I add, is bluddy lovely! I actually prefer it than the OEM one! Just a better bite gives you more confidence in it! Had the rear trailer bushes changed with the haldex itself and it's planted like never before! Didn't fit the haldex plate as it fouled the prop doughnut so that's back with Andrew to redesign.
    Meanwhile bill and mark have been busy with my car.. Had to pop 2 of my 18"s in with the car as the winter tyres probably aren't rated high enough for the dyno.
    Oh and tuffty's engine is sexual.. Sorry tuffty if you find sex wee on it.. Lol all I can say is.. That turbo...!!!
    Nilz, kwistof, Gizmo20VT and 4 others like this.
  34. s3 Hoggy
    s3 Hoggy Whats going on???
    1,716
    158
    Look forward to tomorrows updates! funny how excited I get about other peoples cars!
  35. chaz20vt
    chaz20vt Member
    428
    21
    I cant wait for tomorrow either ill be watching like a hawke......
  36. Westy
    17,443
    1,105
    Good luck. Can't believe how quickly this build has snowballed from a few months ago!
  37. chaz20vt
    chaz20vt Member
    428
    21
    Popcorn in one hand cuppa in the other and I'm sitting comfortably waiting patiently for some updates :)
  38. Prawn
    11,667
    3,665
    Good luck today matey :)
  39. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Good luck lads...
  40. kwistof
    kwistof South East Events Moderator Regional Rep
    2,434
    538
    Great thinking that ^^^^^
    Good luck today as well, will be keeping an eye out for updates.
    (Just have to say I totally admire the amount of work and changes your making on your S3 with it being around 185k miles IIRC?
    I'm still in a split minds on whether to go rods and tfsi as I'm only round the corner from 200k! lol)
