good mods b5 1.8t
p771 apm Jun 5, 2010
  1. p771 apm
    p771 apm New Member
    hey guys iv just got my self a 1.8t a4 in place of my old 1.8 a4 and i was wondering what the best mods were to do to them with out going over the top
    cheers guys and girls
  2. theviking
    theviking Member
    149
    simple wheels and slightly lowered is a start al down to u really dude
  3. olds_kool
    olds_kool Active Member VCDS Map User
    1,089
    if i was starting from scratch and car was in good mechanical order
    poly snub mount, sika/tigerseal filled gearbox mounts to stop excess movement
    lowering springs and shocks, improve the handling
    bigger alloys, looks and handling
    tt carrier brake conversion or fast road pads
    tt or forge 007 diverter valve
    chip, easy power increase for not much money
    looks wise just avoid a bodykit and you cant really go wrong with bigger o.e alloys
  4. Oranoco
    Oranoco Well-Known Member
    3,787
    344
    About covers it I would say
  5. p771 apm
    p771 apm New Member
    cheers guys and good chips you guys would recomend
  6. phoenixv6quattro
    phoenixv6quattro staylowmovefast
    1,396
  7. Oranoco
    3,787
    344
    Depending on your ECU you may not be able to remap and may require a physical chip. The Superchips I got did exactly whaat is said on teh tin and I recorded an exact 30bhp increase
  8. aragorn
    17,877
    687
    I guess "remap" is one of those terms that gets a bit confusing. In my mind, a remap is the end result. Where as a chip or flash is the method used to do it. Either way you've altered the maps on the ECU, so you've remapped it.
    No 1.8T ECU can be flashed on the B5 afaik, they all need chipped.
    Thats not to say MRC cant do it mind, they did plenty of tuning on the old I5 engines, and they certainly couldnt be flashed.
  9. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    proper geometry set up and check all your front arms for worn bushes.
    tidies up the handling no end.
