****Extract from a TechRepublic Computer Magazine ****
Let's say you just bought a Mercedes S550--a state-of-the-art, high-tech vehicle with an antitheft keyless ignition system.
After you pull into a Starbucks to celebrate with a grande latte and a scone, a man in a T-shirt and jeans with a laptop sits next to you and starts up a friendly conversation: "Is that the S550? How do you like it so far?" Eager to share, you converse for a few minutes, then the man thanks you and is gone. A moment later, you look up to discover your new Mercedes is gone as well.
Now, decrypting one 40-bit code sequence can not only disengage the security system and unlock the doors, it can also start the car--making the hack tempting for thieves. The owner of the code is now the true owner of the car. And while high-end, high-tech auto thefts like this are more common in Europe today, they will soon start happening in America. The sad thing is that manufacturers of keyless devices don't seem to care.
Wireless or contactless devices in cars are not new. Remote keyless entry systems--those black fobs we all have dangling next to our car keys--have been around for years. While the owner is still a few feet away from a car, the fobs can disengage the auto alarm and unlock the doors; they can even activate the car's panic alarm in an emergency.
First introduced in the 1980s, modern remote keyless entry systems use a circuit board, a coded radio-frequency identification (RFID) technology chip, a battery and a small antenna. The last two are designed so that the fob can broadcast to a car while it's still several feet away.
The RFID chip in the key fob contains a select set of codes designed to work with a given car. These codes are rolling 40-bit strings: With each use, the code changes slightly, creating about 1 trillion possible combinations in total. When you push the unlock button, the keyfob sends a 40-bit code, along with an instruction to unlock the car doors. If the synced-up receiver gets the 40-bit code it is expecting, the vehicle performs the instruction. If not, the car does not respond.
A second antitheft use of RFID is for remote vehicle immobilizers. These tiny chips, embedded inside the plastic head of the ignition keys, are used with more than 150 million vehicles today. Improper use prevents the car's fuel pump from operating correctly. Unless the driver has the correct key chip installed, the car will run out of fuel a few blocks from the attempted theft. (That's why valet keys don't have the chips installed; valets need to drive the car only short distances.)
One estimate suggests that since their introduction in the late 1990s, vehicle immobilizers have resulted in a 90 percent decrease in auto thefts nationwide.
But can this system be defeated? Yes.
Keyless ignition systems allow you the convenience of starting your car with the touch of a button, without removing the chip from your pocket or purse or backpack. Like vehicle immobilizers, keyless ignition systems work only in the presence of the proper chip. Unlike remote keyless entry systems, they are passive, don't require a battery and have much shorter ranges (usually six feet or less). And instead of sending a signal, they rely on a signal being emitted from the car itself.
Given that the car is more or less broadcasting its code and looking for a response, it seems possible that a thief could try different codes and see what the responses are. Last fall, the authors of a study from Johns Hopkins University and the security company RSA carried out an experiment using a laptop equipped with a microreader. They were able to capture and decrypt the code sequence, then disengage the alarm and unlock and start a 2005 Ford Escape SUV without the key. They even provided an online video of their "car theft."
But if you think that such a hack might occur only in a pristine academic environment, with the right equipment, you're wrong.
Real-world examples
Meet Radko Soucek, a 32-year-old car thief from the Czech Republic. He's alleged to have stolen several expensive cars in and around Prague using a laptop and a reader. Soucek is not new to auto theft--he has been stealing cars since he was 11 years old. But he recently turned high-tech when he realized how easily it could be done.
Ironically, what led to his downfall was his own laptop, which held evidence of all his past encryption attempts. With a database of successful encryption strings already stored on his hard drive, he had the ability to crack cars he'd never seen before in a relatively short amount of time.
And Soucek isn't an isolated example. Recently, soccer player David Beckham had not one, but two, antitheft-engineered BMW S5 SUVs stolen. The most recent theft occurred in Madrid, Spain. Police believe an auto theft gang using software instead of hardware pinched both of Beckham's BMWs.
Real-world examples
