Golfer's Extremely low build
Golfer1991 Dec 10, 2013
  1. Golfer1991
    Golfer1991 Member
    60
    Hi Guys,
    Never had the opportunity to show you off correctly my Audi S3.
    I live in Switzerland and here is quite difficult to pass MOTs with modifications, so for the moment my car isn't so speedy as yours there lol.
    This is just after I bought it, about 2 years ago:
    It was newly resprayed and about 6 months later we got a big Hailstone storm.
    I've had about 120 "holes" only on roof and many more on the rest of the car, so decided to have a big change!
    This is how it became after:
    479728_523794037668542_1303262478_n.jpg 482541_523794267668519_1496066694_n.jpg 600827_523794261001853_578037223_n.jpg 401797_523794171001862_1176682386_n.jpg 947100_523793971001882_77992732_n.jpg
    I'm really happy with this color, it's Papaya Orange and proudly the unique with this color on a S3 8L in Switzerland :D
    Let's get on with the specs now:
    Engine:
    2.0 TFSIs Coil packs
    BMC Air Filter
    V3 Relentless Manifold
    Trackslag Uprated charge pipe
    Silicone hoses all over
    42 Draft Design 3" Downpipe with 200 cell kat (actually down due to homologation problems)
    Milltek resonated cat-back
    Exterior:
    OZ Racing Ultraleggera 19x8 with 225/35 Bridgestone S001 Tyres
    6 pot Brembo Z18 from Porsche Cayenne and 334x32 brake discs (actually down due to homologations problems :( )
    Rear wishbone removed
    Black side lights
    Carbon Fiber B-Pillar
    Carbon Fiber door trims
    Interior:
    Depo Boost Gauge
    Audi R8 Steering wheel (will be mounted next weeks)
    Audi A4 2010 RNS-E (modified to suit in S3s dash)
    This is actually what I have, but managing to do a serious build in the next few months!
    This is what I'm going to do:
    Engine block rebore to suit 82mm pistons
    Stroke 92.8 Crankshaft
    CP Pistons 82mm 9.5:1
    Bosch 550cc Injectors
    Beach Buggy Turbo Hybrid
    Badger5 ported Chinafold
    Conrods
    toyosport FMIC
    New Downpipe and 200 cell cat (a homologated one for Switzerland)
    New Oil pump, chain and tensioner
    Southbend Stage 2 daily Clutch and single mass flywheel
    All other small bits like gaskets and seals
    If I forgot something useful for my build any help or suggestions are much appreciated!
    And sorry for my basical English!
    JOSEA3T, superkarl, Alex C and 5 others like this.
  2. bigray
    bigray Active Member
    144
    53
    really nice this bud i really like the orange aswell,
  3. Sham101
    Sham101 Member
    286
    20
    mint
  4. S3 zombie
    S3 zombie New Member
    19
    Welcome..very nice indeed! What offset wheel and spacer combination are using to clear the 18z calipers?
  5. Golfer1991
    Golfer1991 Member
    60
    They are 19x8 ET35 with 13mm spacers ;)
    That's enough to clear the calipers.
  6. ManuGD
    ManuGD New Member
    24
    Looks great! The colour and those wheels & brakes...:eyebrows:
    I like the tiny front license plate you have in Switzerland, too, lol
  7. Golfer1991
    Golfer1991 Member
    60
    Yeah that's not bad, it's not so invasive! lol
    Got in Winter Mode today! this is how it looks now:
    s3dave likes this.
  8. CarbonBlack
    CarbonBlack Member
    :thumbsup: same colour as my hair lolol
  9. superkarl
    superkarl MAN OF STEEL
    9,425
    2,385
    Your car is the tits!Keep up the great work
  10. Golfer1991
    Golfer1991 Member
    60
    Just a bit worried about the remap actually...
    Here in Switzerland and even in Italy there's no one with just the half of knowledge in the 1.8T engine like Badger5 or R-Tech.
    I know also isn't easy to do such a remap in the UK and send it over to Switzerland without the opportunity to put the car on a dyno.
    I will in any case ask to Bill what he thinks, but will be hard to set up the car correctly :(
  11. Squirrelofdoom
    Squirrelofdoom Member
    672
    23
    nom nom nom nom nom nom nom nom nom
  12. Golfer1991
    Golfer1991 Member
    60
    Was thinking in changing my exhaust valves while I'm doing the build.
    Is it a worth mod or I can simply keep the OEM ones?
    I suppose my power range will be between 320 and 350hp.
    And if yes, Supertech valves are what I was looking for, would be better the Stainless ones or the Inconel ones?
    (I know the Inconel are better, but are they really needed?)
    Thank guys :)
  13. Golfer1991
    Golfer1991 Member
    60
    Santa arrived today :D
    s3dave likes this.
  14. Freek
    Freek New Member
    26
    nice car! i love the wheels and brakes.
    and i think with a stroker and a BBT hybrid, you will have a bit more than 320-350 hp.
  15. <tuffty/>
    21,001
    3,764
    Stainless are for normally aspirated applications... use inconel... they are designed for turbo applications
    Its a high rev limit that will require a full valve train tbh... if you are not going for a big turbo then the std valve train will be fine for the 7.2 to 7.5k rev limit that is typical for smaller framed turbo's
    Things to watch out for are valve guide wear and tired stem seals... as you are having the bottom end rebult at the very least its worth getting the guides checked and replaced if needed (normally exhaust guides) and get the valves lapped back in to refresh the seal... use new stem seals and cam seals and the head will be done
  16. Golfer1991
    Golfer1991 Member
    60
    I will probably go big turbo in the future, when the car will be just for track days as with Swiss laws I can't go so big with the build :(
    I will get also an AEB cylinder head, so of course all will be checked!
    My fear were to put back on a set of valves that have actually 14 years and about 90k miles on it, I know the intake ones aren't a problem but the exhaust ones are more prone to wear during the time, this is why I was considering just Supertech's exhaust valves!
  17. Golfer1991
    Golfer1991 Member
    60
    New Parts are slowly coming! :D
  18. Marshall878
    Marshall878 Member
    134
    30
    Oooooft thats nice.
  19. s3clarke
    s3clarke Money grabbing s3!
    677
    35
    spot on mate :drool:
