Golf mk4 drivers foot well water ingress
aky20 Mar 5, 2011
  1. aky20
    aky20 Member
    69
    Hi All,
    My uncle currently has a V reg VW Golf 5 door 1.6 but seems to be getting water ingress from the drivers door somewhere, which is leaving the drivers foot well soaking wet and the water is running to the rear. My initial thoughts were the plastic membrane behind the door panel has been punctured but on pictures of the door panel I have seen online I can’t see one.
    Has anyone else experienced the same problem or is aware of what the issue is and how I can go about resolving this.
    Your assistance is greatly appreciated !!!
    :yum:
  2. S3-SiB
    S3-SiB Member
    35
    Common problem, its coming in through the pollen filter. So check it out.
  3. MOOSH
    MOOSH Member
    253
    Comes in the doors as well, the fix is remove the trim and seal round the inner frame which holds the window regulator. Do all 4 doors mate.
  4. S3-SiB
    S3-SiB Member
    35
    Other thing it may be, which I have seen from my experience is, between the door and wing (by the hinge) there is a rubber parts with a hole on it that will drape one way. This is a drainage route for water from the roof to come off. Some people run a cable through and block it, others turn it upside down out of curiosity, without knowing its function and end up with water now sipping into the footwell rather than straight out and down the outside body of the car.
  5. Tekara
    Tekara New Member
    20
    Didnt realise Mk5's were that bad
