Going Stage 2+
gilberto Jun 5, 2013
  1. Kelza
    Kelza MODERATOR Staff Member Moderator Audi RS3
    3,078
    606
    Heres one of mine ;)
  2. gilberto
    gilberto Member
    156
    Car made 353 bhp and 289lbft, tuner said there was alot more torque to be made but didnt want to take any chances with the clutch. Feels rapid now!!
  3. S.
    S. Save the manuals Team Ibis TFSI Owners Group Audi S3 quattro Manual
    2,094
    581
    RS3-KEL why do you have that power dip between 4500 and 5000 rpm's? is it clutch slip?
    i don't know what figures mine has but it feels quick :D
  4. gilberto
    gilberto Member
    156
    Needed a new o ring on the fuel pump as the original one couldn't handle the increase in fuel pressure. Was a bit worried when fuel was leaking into the engine bay.
  5. Kelza
    3,078
    606
    Hi S, its could have been as there was aways a dip , but tbh i should have stuck the sachs clutch in as i do miss that raw power ,from the s3 ,the rs3 is more calm through the dsg box ,no doubt a map will sort it out..;)
    S. likes this.
  6. S.
    2,094
    581
    that seems reasonable :D
    mine wasn't on rollers since stage2 since the stock clutch was giving up, but few days ago had a play with r8 v8 and i was surprised (not as much as the guy in r8) :D
    Kelza likes this.
  7. Kelza
    3,078
    606
    Funny thing is when i put her back to standard she was a dream to drive ,and no loss of power ,felt really tight lol
  8. gilberto
    gilberto Member
    156
    What was your Revo settings?
  9. Kelza
    3,078
    606
    Hi will need to dig them out :)
  10. gilberto
    gilberto Member
    156
    I've just gone for the Loba/Sachs SMF set up, but noticed it comes with no release bearing, where can i get one?
    Will i need my map tweaked to run more torque or will the car automatically run more torque with the new clutch set up?
    Thanks again.
    James
  11. S.
    2,094
    581
    release bearing from audi. or maybe garage can source it for you.
    ideally, map would need tweaking. as it won't produce more torque without that.
  12. gilberto
    gilberto Member
    156
    Whats everyones Revo settings for Stage 2+ in terms of boost, timing and fuel?
  13. S.
    2,094
    581
    hey there,
    each car has different settings, for example my settings may not be good for your car, but it's an good starting point if you have nervs and time to do logging and tweaking.
    i have tried two: one set by revo which is b9t4f9, and another one b8t5f7.
  14. gilberto
    gilberto Member
    156
    Thanks for that, I'm on B7,T4 & F9. What setting would need changing to make better torque figures when the new clutch goes in?
  15. S.
    2,094
    581
    don't really know mate. i've had map update after new clutch so all has been done at the garage.
    you can play with the boost and fueling but with timming you need to be careful and log everything to check if it in the safe limits,
    i think it's best to ask garage.
  16. gilberto
    gilberto Member
    156
    Yeah I'll ask them to look at the map again when the clutch goes in.
  17. coreythorny
    coreythorny Active Member
    463
    74
    Don't forget to bed the clutch in mate
  18. gilberto
    gilberto Member
    156
    Chaps, is there a difference between the Revo Stage 2 & 2+ software or is it dependant on boost, timing and fueling settings?
  19. S3Alex
    10,858
    4,844
    Stg2+ software is fuel pump specific,i.e. it requires an uprated HPFP,and that,plus the software,fills out a lot of the dip in midrange torque that you otherwise get at Stg2.
  20. S.
    2,094
    581
    ^^ what he said :D
    S3Alex likes this.
  21. gilberto
    gilberto Member
    156
    Cheers, looks like Stage 2 went on the last time i was in for a tune but 2+ is going on tomorrow with the new clutch.:icon_thumright:
  22. S3Alex
    10,858
    4,844
    As I said,you need the uprated HPFP for Stg2+,and it does make a difference,although it's the beginning of the slippery slope to really expensive mods.
    The car will take a few days worth of driving to adapt fully,but the increase in midrange torque is noticeable right away.
  23. gilberto
    gilberto Member
    156
    Yeah i've already got the HPFP fitted but i was told that they only put the stage 2 software on last time it was in for a map (when i also had ITG, Milltek and HPFP fitted at the same time)
  24. S3Alex
    10,858
    4,844
    Then when you go back there's going to be a bigger grin on your face!
  25. gilberto
    gilberto Member
    156
    When fitting the new Rev D Diverter Valve, is it a case of just bolting in the new DV, do you have to worry about tweeking the map? will any fault codes be picked up after changing?
  26. RedDejavu
    RedDejavu Well-Known Member
    1,806
    337
    nobody mentioned that lower engine mounts would need changing to something stiffer:].
  27. gilberto
    gilberto Member
    156
    Does that make the cabin noise increase?
  28. RedDejavu
    1,806
    337
    apparentley not if you choose road use version, track only version would have made all bit noiser as they are really harsh.
  29. gilberto
    gilberto Member
    156
    So i've just managed to change my rev g diverter valve for the rev d. Easy job even for a complete novice!
    The rev g looks in surprisingly good condition. I'm still getting a flutter sound when accelerating hard in 3rd and 4th. Is this something to worry about or is it what's called compressor surge?
    Here's a few photos of the condition of the rev g:
  30. Reload
    Reload Bird is the Word!
    367
    50
    I noticed the flutter sound when I replaced my old DV with a Rev D, absolutely nothing to be concerned about
  31. XFi
    XFi In need of a V8.
    491
    47
    My rev G was also in perfect condition but I changed it for piece of mind. Mine does this at stage one also.
  32. gilberto
    gilberto Member
    156
    Do you get the flutter under hard acceleration and on gear change?
  33. XFi
    491
    47
    I have compressor stall or fluttering but only between 3 & 4000 rpm. Also had it on my previous 8L S3 once I added an aftermarket intake. Compressor stall isn't a great thing for a turbo at all.
  34. gilberto
    gilberto Member
    156
    Sounds similar. Good to hear i'm not the only one. cheers.
  35. gilberto
    gilberto Member
    156
    Here's some pictures of my Stage 2+ dyno results 355 bhp & 334 lbft.
    S3Alex likes this.
  36. Dean_T
    Dean_T Active Member
    645
    139
    43
    So how big is the smile on your face with the extra oomph now?
  37. gilberto
    gilberto Member
    156
    Yeah it's pretty rapid now. Just need to think about brakes and suspension now.
  38. S3Alex
    10,858
    4,844
    kW v3 and either DaveB brakes,or AP/Brembo/RS brakes would fit the bill nicely.
  39. gilberto
    gilberto Member
    156
    I emailed Dave B but he never got back, ideally need a set up that fits over the standard wheel. Any ideas?? I'd prefer a drilled disk set up.
  40. RedDejavu
    1,806
    337
    TTRS brakes are good
