Glow plugs fault on VCDS
imy2k Aug 14, 2013
  1. imy2k
    imy2k Member
    30
    Hi all :) Ever since I've owned my car I've been getting these faults via VCDS for the glowplugs and cleared them many times :
    17055 - Cylinder 1 Glow Plug Circuit (Q10): Electrical Fault
    P0671 - 000 - -
    Freeze Frame:
    RPM: 882 /min
    Torque: 46.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 14.29 V
    Bin. Bits: 11000100
    Temperature: 8.1°C
    Bin. Bits: 10110000
    17056 - Cylinder 2 Glow Plug Circuit (Q11): Electrical Fault
    P0672 - 000 - -
    Freeze Frame:
    RPM: 882 /min
    Torque: 46.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 14.29 V
    Bin. Bits: 11000100
    Temperature: 8.1°C
    Bin. Bits: 10110000
    17057 - Cylinder 3 Glow Plug Circuit (Q12): Electrical Fault
    P0673 - 000 - -
    Freeze Frame:
    RPM: 882 /min
    Torque: 46.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 14.29 V
    Bin. Bits: 11000100
    Temperature: 8.1°C
    Bin. Bits: 10110000
    17058 - Cylinder 4 Glow Plug Circuit (Q13): Electrical Fault
    P0674 - 000 - -
    Freeze Frame:
    RPM: 882 /min
    Torque: 46.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 14.29 V
    Bin. Bits: 11000100
    Temperature: 8.1°C
    Bin. Bits: 10110000
    I think its time to stop ignoring them and do something about them. Any advise on what to do ? shall I get them changed or tested for voltage . My mechanic mentioned a relay that could be gone but this was on the top of his head.
    Thanks all
  2. AudiMafia
    AudiMafia Member
    403
    13
    Hi, If the car starts up fine when cold then you don't need to worry as it means nothing, had the same reading on my car for couple of years and it only cleared when i changed the EGR valve I don't know if it's got something to do with it or was a coincidence.
  3. NHN
    29,577
    1,779
    That points to the injector loom which also houses the glowplug connections, so yes get it checked out as 1-2 to go yes possibly, but all 4 points to a common denominator, loom.
  4. 1inchwarrior
    1inchwarrior Member
    40
    Hi I read that you were having a fault with all four of your glow plugs, i have this vcds error too and was wondering of you ever got it sorted?
  5. NHN
    29,577
    1,779
    Have you read the thread yet?
  6. 1inchwarrior
    1inchwarrior Member
    40
    Yes I read the thread, you mentioned that it points to the loom?
    Am I being blind and imy2k mentioned that he resolved the problem somewhere?
    It doesn't seem to be effecting my driving quality at all and I never have a problem starting the car and so I was wondering if it was worth doing anything about it.
  7. NHN
    29,577
    1,779
    Its only relevant on diesels when the weather is cold, so it probably wont make any difference now, come winter it maybe an issue for you.
