Glow plug problem costing me a fortune trying to find cause
chale989 Feb 8, 2013
  1. chale989
    chale989 Member
    79
    Ok so i have a 2005 2.0 tdi but when i turn the key the glow plug light will not go out.
    I have 2 options , turn the key 15-20 times or sit and wait for 5-10 minutes and the light will go off itself.
    I have so far replaced all 4 glow plugs , put in a brand new battery and had the key re programmed.
    Any Ideas anyone?
    Once the engine is warm, if i turn it off and then turn key then the lights will go straight off. Its usually when engine has been standing for longer then 10 minutes.
  2. chale989
    chale989 Member
    79
    Guys i really need advice. Ive had diagnostics ran 3 times from 3 different places and nothing shows
  3. Sidhu88
    Sidhu88 Active Member
    808
    76
    U sure its the glow plugs? As in, isit a solid light or does it flash? If it flashes could be a maf or lambda issue, mine would flash before hittin limp mode when my maf was on its way out. Also one time the turbo was having a once over we ran the car with no intake pipe on the turbo and it flashed continuously too.
  4. Sidhu88
    808
    76
    Also what plugs did u replace it with? Oem?
  5. Lewis583
    956
    91
    I'm guessing you have had the car scanned with a decent diag tool? VCDS would be preferable. Fault codes?
  6. mike foster
    3,967
    Glow plug wiring harness has been known to cause intermittent problems.
  7. chale989
    chale989 Member
    79
    Plugs were replaced by bosch ones that were reccomended.
    Scans have been done by audi , the aa and a vw speciliast garage.
    How much is a new glow plugs wiring harness?
    The light stays light, not flashing.
    $once engine is on then there are no issues what so ever. No limp mode or any warning lights
  8. BradV6
    BradV6 Member
    84
    Can the glow plug relay cause a problem? I remember something like this on my MK4 golf
  9. 964kevin
    964kevin Member
    109
    What triggers the Glow Plug to come on? thats where I would be looking.... Temp sensors etc.
    Kevin
  10. chale989
    chale989 Member
    79
    There are no triggers what so ever. Just sit and wait 5 mins or so and it a click noise happens and then it will go off.
  11. mike foster
    3,967
    Glow plug wiring harness is approx. £100
  12. NHN
    29,417
    1,740
    Yeap I would test glowplug loom as known to be a problem on some, clicking is probably relay for the glowplug system would need to check schematics to confirm.
