Glow plug light flashing
Cruz Aug 31, 2009
  1. Cruz
    Cruz Member
    74
    The glow plug light has just started flashing on my 2.5 tdi whilst the car is running. I take it this is like an engine management light?
    The engine is still running very smooth and i havn't really noticed any reduction in power. Will a vag com scan identify why the light is flashing?????
    I have recently had the car seviced if this is of any help.
  2. Nez
    Nez Member
    598
    Check your Glow plugs maybe they need a change :)
  3. dieselfitter251
    dieselfitter251 Blow ma own trumpet?
    1,120
    She starting ok mate? Taking longer for the glow pulg light to go off when you switch on the ignition?
  4. Cruz
    Cruz Member
    74
    Still starts fine and no difference to the length of time the light stays on prior to starting.
  5. PW-Motorsport
    PW-Motorsport Member
    396
    Get it on vag com, as it can be a few things...
  6. Cruz
    Cruz Member
    74
    Would you say it was still ok to drive until i get it checked as i havn't noticed any difference in performance?
  7. Simon66
    Simon66 Member
    67
    Brake light bulb may be blown
  8. Cruz
    Cruz Member
    74
    Funny you should say that but the brake light bulb did blow the other day but the glowplug light started flashing since the bulb was replaced
  9. Simon66
    Simon66 Member
    67
    is the new bulb in properly.
  10. Cruz
    Cruz Member
    74
    BTW, the glowplug light doesn't start flashing until the engine has been running for about 30 secs
  11. aragorn
    18,542
    865
    Perhaps it takes 30 secs for you to press the brake for the first time? :p
    As people have said, vagcom time.
  12. Cruz
    Cruz Member
    74
    Yep, i think your right. I will try and get it done tomorrow
  13. Siena
    Siena Active Member
    2,626
    Brake / clutch pedal switch.
  14. Cruz
    Cruz Member
    74
    Could you explain in a little more detail please?
    cheers
  15. Siena
    Siena Active Member
    2,626
    ^^^ The brake lamp switch is more than just a component for activating the brake lamps, or the autocheck system (where fitted) upon start up.
    Both the clutch and brake pedal switches are tied into the engine management, and fuelling / enrichment. Failure of either of these switches, particularly the brake one on diesel models will activate the glow plug lamp.
  16. Cruz
    Cruz Member
    74
    Will a vagcom scan identify if this is the problem
    cheers
  17. Siena
    Siena Active Member
    2,626
    ^^^ It should, yes.
  18. aragorn
    18,542
    865
    if it doesnt appear in the fault code list, one of the measuring channels shows the current position of the brake and clutch switches as seen by the ECU.
    You can compare these with the actual positions and see which is faulty.
    The switch might just need adjusted
  19. Cruz
    Cruz Member
    74
    Well i went to my local vag specialist this morning and they suggested that i replace the brake pedal switch. So off i went fitted a new switch but the light still flashed.
    Then i thought check the fuses!
    And guess what that's all it was
  20. RadCap
    RadCap Member
    33
    There will be a reason the fuse went though.
    Just keep an eye on everything :icon_thumright:
  21. Yarsir
    Yarsir New Member
    14
    Sorry to bring this back up.
    I'm having the same issue with my 06 A4 Tdi
    My wifes called me twice in the last week or so on her journey to and from work saying this orange curly light is flashing on the dash.
    The cars performance is in no way affected. After googling around the most common cause seems to be a faulty brake light switch.
    I'll have get it tested with a vagcom lead, hopefully nothing too costly.
  22. Mrfwon
    Mrfwon New Member
    Hi, this is my first post here.
    After searching around today looking for some pointers, I stumbled across this thread. Anyway, I have just recently experienced similar issues to the ones mentioned above with regards to the glow plug indicator lamp flashing while driving (it would start flashing after 30 seconds or so, regardless of whether the brake pedal was pressed or not).
    I'm not sure if anyone else has experienced the same as this, but while the glow plug indicator lamp started flashing today, the ESP light also came on, and wouldn't go off, not even if I turned the engine off, and then back on again, as some have suggested.
    I followed the advice posted by a couple of people here with regards to the fuses, they all seemed ok, so on to the brake lights. Low and behold, both rear brake lights were broken (the central LED on the tail gate was working fine).
    Quick trip to Halford to buy some replacement bulbs, fitted in minutes, and bingo, both warning lights have gone off completely, and the ESP button now works fine too.
    My Audi is an 03 1.9TDI 130 Avant Sport (estate) if that helps?
    Thanks for the advice by the way, it was a great help today! :salute:
  23. sinclair
    sinclair New Member
    Driving down the motorway and engine management light came on and the glow/coil light. Read your post and thought you were joking but checked my brake lights and they wern't working! Changed for £6.20 including fitting and hey presto...all lights on dashboard now out! Thanks for your advice, probably saved me a fortune
  24. Neilb1
    Neilb1 Member
    178
    mine just did the same but the buld has been blown for a week but it just decided to come on tonight, anyway changed both bulbs tonight so need to see how it goes tomorrow now,
    now i have the issure of reversing lights staying on new switch sat in the kitchen so that will be changed this week
  25. vik
    vik New Member
    Hi all i am new to this post and just owned my dream car an Audi A4 2.0 TDI SE S-Line REG IN Jan 2008 and i have noticed on some occasions my glow light in the dash appears with loss of power (meaning its not very responses as other times and can still drive).
    To get rid of the light i have to park up switch off the car and on again its back to normal with full power and response. Would anyone know why this is and the cause of this. Early this year i received a letter from Audi regarding a recall which my father took in and they checked the injectors and said its fine, should i of had changed them or just left them.
    Any help much appreciated.
  26. jbh
    jbh TDi lover
    1,412
    168
    Hi there Vik I would get your car put on to vcds and have it scanned.
    I have had the glow plug light flash on 2 different cars. on my old Passat it gave me a fualt code that lead me to a vlave in the pump on my wife's sharan it was the brake light switch.
    where about are you? maybe theres a local member that could scan your car for you.
    James
  27. vik
    vik New Member
    James many thanks for replying. I am originally from the UK London near Harrow but currently working abroad in Stockholm, Sweden.
    I brought this motor from Car Giant in Sept 2012 after many years of wanting to own an Audi i finally got my dream car but the experience hasn't turned out to be good so far. I have this light come on many times when i was driving to Europe from London where i had to pull over and switch off and on and back to normal.
    I got this light today twice within few mins but is fine now randomly it will come on. I have done some research and some say brake light switch but finding it hard to believe how this has anything to do with the light which comes on my dash. Some say ECU BOX, Glow plug or most the EGR part.
    I am clueless. ANy help be great.
  28. Rwareham
    Rwareham New Member
    Great thread:) £1.79 for new bulb. Job done. Thanks for the advice would of never suspected a bulb out to cause this!
