Glow Plug light constantly on on my A3 1.9 TDI. Help please?
buel Oct 30, 2013
  1. buel
    buel Member
    188
    Hi,
    Tonight I noticed that the glow plug light on my dashboard is constantly on. Please can I ask is this serious and what can it be?
  2. buel
    buel Member
    188
    Hello, anyone please?
  3. <tuffty/>
    21,256
    3,880
    Need to scan for fault codes in the first instance... not many people on 8L own TDi's so knowledge is a little thin... the ones that do aren't on the forum as much as the 1.8t guys so you are going to have to be patient I'm afraid...
    If the glow plug light is on then there should be an associated fault code... scan and post up the results...
  4. buel
    buel Member
    188
    Hi,
    Thank you for that!
  5. niallh
    niallh Member VCDS Map User
    213
    mines been on twice, once when there was an actual fault with a glow plug but also when my brake sensor switch was faulty
  6. buel
    buel Member
    188
    Hi and thanks for that, Why would the glow plug sensor come on if the brake sensor switch was faulty? Aren't they seperate things?
  7. buel
    buel Member
    188
  8. BeeKay
    BeeKay Member
    68
    check your break lights i know this light comes on when they go , and niallh was right to say the break sensor switch too , got to fix mine soon too delayed it abit too much lol
  9. buel
    buel Member
    188
    Hi,
    Brake lights fine but the error reader got the code:
    'Quantity adjuster upper limit reached P1562'
    Does this mean anything please?
  10. buel
    buel Member
    188
    The car does not start and an AA mechanic has said that there is no fuel getting through. Could this be connected to the flashing Glow plug light please?
  11. <tuffty/>
    21,256
    3,880
    17970/P1562/005474 - Ross-Tech Wiki
    17970/P1562/005474 - Quantity Adjuster (N146): Upper Limit Reached
    Possible Symptoms
    Malfunction Indicator Light (MIL) ON
    Reduced Power
    Engine jerking
    Possible Causes
    Fuse(s) faulty
    Wiring and/or Connector(s) from/to Quantity Adjuster (N146) faulty
    Quantity Adjuster (N146) not adjusted
    Quantity Adjuster (N146) blocked/faulty
    Possible Solutions
    Check Fuse(s)
    Check Wiring and/or Connector(s) from/to Quantity Adjuster (N146)
    Check/Adjust Quantity Adjuster (N146)
    Check/Replace Injection Pump
    Notes
    On the 1.9L ALH TDI engine:
    The Quantity Adjuster (N146) should ohm test between 0.5 and 2.5 Ω.
    With the coolant above 85° C, MVB 001, Field 3 should read between 1.45 to 2.0 Volts.
    Not sure what a quantity adjuster is (not really familiar with derv's) but suspect this is a fuelling issue?
    Did you have any luck in the diesel section?
  12. buel
    buel Member
    188
    Hi Tuffty,
    Thank you so much for that. Strangely, I did not have one reply in the diesel section.
    In answer to your question, yes, the AA man said that there was no fuel getting through.
    Would I be correct in assuming that this is basically a fuel pump problem so perhaps try a second hand one?
    I read earlier that they tend to have a lifespan of around 150,000 miles? This car is on 155,000 so maybe this would also point towards this?
  13. Airs
    Airs Active Member
    144
    81
    Hi buel, i take it that you have 1 of the pre pd engines with this kind of pump on
    Google Image Result for http://farm3.static.flickr.com/2722/4137626096_ac36a39e27.jpg
    the mechanical fuel pumps on those engines are prone to giving up, if you say its covered that many miles and never been replaced, you may be in need of a new 1, you could also try emptying the fuel filter or changing it for a new 1, id possibly try filter first as its the cheaper option
    hope this helps :)
  14. buel
    buel Member
    188
    Hi Airs,
    Thanks so much for that. Yes the car is an ASV 110hp pre-pd engine. I take it you mean the injector pump do you? Just one question I would like to ask, my mechanic friend looked at the car today and said that there was no fuel in the fuel line between the fuel filter and the injector pump so he wanted me to find out if my car has a fuel pump in the tank that he thinks I should start with before going ahead and buying a replacement injector pump? (He hasn't got time to check it today you see).
    Please can I ask does my car have this?
    Personally, I think that being as the error code pointed towards the injector pump and the fact that the ESP light has been flashing kind of points towards the injector pump?
    Any thoughts on this?
  15. buel
    buel Member
    188
    Wow this is confusing! My mechanic friend says that there are 3 fuel pumps on the car, one in the tank and TWO on the engine? Is this correct please?
