Glow Plug Controller Issues?
dinothetiger Dec 29, 2009
  1. dinothetiger
    dinothetiger New Member
    12
    Hi Guys does anyone have any ideas what this error code means:
    1 Fault Found:
    19794 - Control Circuit for Glow Plug Controller 1: Electrical Malfunction
    P3338 - 000 - -
    Freeze Frame:
    RPM: 0 /min
    Torque: 72.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.16 V
    Bin. Bits: 11000100
    Temperature: 27.9°C
    Bin. Bits: 01010000
    Readiness: 0 0 0 0 0
    I cannot find it anywhere. I am having starting problems occasionally.
    Any help would be much appreciated. :shrug:
  2. navnayyar
    navnayyar Member
    756
    i have same fault!
    Address 01: Engine Labels: 03G-906-016-BKD.lbl
    Control Module Part Number: 03G 906 016 G HW: 028 101 136 4
    Component and/or Version: R4 2,0L EDC 0000SG 5705
    Software Coding: 0000072
    Work Shop Code: WSC 00066 001 57865
    1 Fault Found:
    17056 - Cylinder 2 Glow Plug Circuit (Q11): Electrical Fault
    P0672 - 000 - -
    Freeze Frame:
    RPM: 0 /min
    Torque: 164.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 11.48 V
    Bin. Bits: 11000100
    Temperature: 6.3°C
    Bin. Bits: 00110000
    I didnt think much of it and thought it was a previous fault and not been reset. I then reset the whole thing and came up with the same thing:
    Part No SW: 03G 906 016 G HW: 028 101 136 4
    Component: R4 2,0L EDC 0000SG 5705
    Revision: 12345678 Serial number: AUX7Z0CNFN5008
    Coding: 0000072
    Shop #: WSC 00066 001 57865
    1 Fault Found:
    P0672 - 000 - -
    Freeze Frame:
    RPM: 0 /min
    Torque: 148.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 11.63 V
    Bin. Bits: 11000100
    Temperature: 7.2°C
    Bin. Bits: 00110000
    Does anyone know what this fault means? do i need new glow plugs?
    I do not have any problems at the moment, but i dont want it to become a bigger problem later.
    cheers guys
  3. SAiLO
    SAiLO Well-Known Member VCDS Map User
    1,078
    62
    I had it on cylinder 3 glow plug. From what I found on the other VAG-related forums it might be the wiring connected to the particular glow plug or the glow plug itself may need replacing.
  4. NHN
    29,521
    1,765
    1st thing I'd do is check the loom for any wires damaged, if nothing apparent then replace the glowplug.
  5. SAiLO
    1,078
    62
    Is it difficult to replace the glowplugs? Do I need any special tools?
