Glovebox ipod connecter help?
Peterhendo May 3, 2013
  1. Peterhendo
    Peterhendo Member
    40
    image.jpg Okay so i put the ipod into this put it falls out wen driving and it doesent even work anyways do i need a cable or anything??
  2. NHN
    29,328
    1,708
    Does the connector line up ok & assume you're pressing cd on head unit to play?
  3. Peterhendo
    Peterhendo Member
    40
    It goes in but is fairly loose wen i accelerate or brake it falls out and yes pressing cd tried every button nothing happens
  4. S3AMK20VT
    S3AMK20VT Member
    170
    "do you need a cable" you mean the one that connects the ipod to back of the headunit? YES
  5. Peterhendo
    Peterhendo Member
    40
    I mean like put one end of cable into the ipod then plug that onto the connector in glovebox
  6. S3AMK20VT
    S3AMK20VT Member
    170
    and the connector in the glovebox is connected to the back of the deck?
  7. phil_w
    phil_w Active Member VCDS Map User Audi A4 Audi Avant Owner Group S-line owners group Team Brill Red
    591
    54
    Regards the falling out bit - from the factory different little plastic adapters came in a bag that were to add pressure fit to different models of iPod - you've got one inserted in the front of the photo which is probably for a thicker, older model.
    Could just be faulty unit for the other issue, or no connection from the rear to headunit but I'm sure that would be peculiar...
  8. phil_w
    591
    54
    Forgot to ask what iPod you are plugging in?
  9. Peterhendo
    Peterhendo Member
    40
    Yea back of the deck and its the old ipod video
  10. phil_w
    591
    54
    Ipod video should be fine - it's the newer ones that can't be charged etc with that style of iPod adapter
  11. phil_w
    591
    54
    Difficulty is that when its in the slot you can't see the screen to tell if the iPod is doing anything. A successfull plug-in results in the audi logo appearing on the iPod screen. An iPod extension cable would be the way to check that out but sounds to me like a duff audi iPod prep
  12. A3Kent
    A3Kent Well-Known Member Team Daytona Audi A3 S-line owners group TDi
    1,570
    249
    Get an iPod extension cable off eBay for next to nothing, that's what I had when I had that iPod connection before I changed it to AMI. Make sure it passes audio though as there are lots of data only ones on eBay.
