Glovebox damper fault
petrieboy Mar 26, 2008
  1. petrieboy
    petrieboy New Member
    my glovebox has suddenly lost it's dampened action. now when you open it, it falls open suddenly rather than opening gently.
    ive popped off the side panel revealing what i think is the damper (see pic) but theres nothing obviously wrong with it. am i looking at the right thing, or am i going to have to remove the whole glovebox?
  2. bonerp
    bonerp Member
    180
    thats the blighter.
    normally need a good oiling!!! Dunno how they work tho. Take it off and strip it to see whats wrong - if its broke anyway, why not?
  3. J7USS
    J7USS Shuddup Foooool!!
    3,737
    77
    Yep thats it, I sprayed mine with WD40 lastnight when I finally fixed my Broken Hinge (courtesy of the Andy Mac knowledge tried n tested - great fix by the way), Makes a lovely sucking noise now tho.
    If you do take you glovebox out, be very careful, these things are flimsy if its open, slight knock could Faccckkk your hinges!
    I bet they (damper) aint expensive if a new one is required though.
  4. wallacr
    wallacr Member
    260
    I paid just approx £117 from Audi for a glovebox with room for a CD changer, so thankfully they aren't too expensive if you ever need to replace one.
    Only reason I bought another, was to have the space to mount the CD changer.
    Rich
  5. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
    Trouble is you can't get just the damper from Audi - only a complete glovebox!!!
  6. J7USS
    3,737
    77
    Bloody'ell,stupid aint it!
    I got quoted nearly £350 from my dealer :huh: when I asked about a glovebox!
  7. bonerp
    bonerp Member
    180
    try a mini moto steering damper lol!
  8. arthurfuxake
    1,308
    Are you sure? The damper has it's own part number, I can look it up on etka tonight if you want, then just pop into audi parts and order the damper.
  9. Slinger
    Slinger Member
    146
  10. arthurfuxake
    1,308
    The damper part no. is: 8E2 880 324.
    The hinge pin part no. is: 8E0 880 802. This is just a small pin which holds the damper onto the glovebox lid, you could probably re-use your old pin.
  11. PetrolDave
    1,559
    85
    I'll go stand in the corner with a pointed hat on my head!
  12. arthurfuxake
    1,308
    Not too quickly Dave, just because I've found the part number doesn't mean that Audi will sell it as an individual part, but it won't hurt pestering them for it.
  13. malcolm1sim
    malcolm1sim Member
    42
    Hi Guys,
    Should all B6s' have a damped glove box lid?
    Mine has not since new. A4 3.0Q 02 Plate.
    Cheers for now.
  14. PetrolDave
    1,559
    85
    AFAIK yes.
  15. malcolm1sim
    malcolm1sim Member
    42
    Thanks PD
  16. malcolm1sim
    malcolm1sim Member
    42
    Hi All,
    In partic PD.
    Yes I have got one and yes it does not work!
    There is some evidence of fluid leak - guess that is why.
    Off to Audi, as soon a smortgage is arranged!!!
    Malcolm
