Glove box light retro fit and puddle light information
pns2007 Oct 26, 2009
  1. Anthony566
    Anthony566 Active Member
    732
    111
    43
    Yeah that's the one I used ... I have some photos to load.
  2. andyam
    andyam Active Member
    485
    Is yours working?
  3. Anthony566
    732
    111
    43
    Yes works just fine.
    I took a permanent power feed from the left strip in the passenger side fuse box.
  4. jamin128
    jamin128 Member
    208
    Did you ever get round to retrofitting the vanity mirror lights?
  5. D J Robo
    D J Robo New Member
    Hi lads nice thread so hope I'm not jumping in !!! I was fitting some retro door/puddle lights to my Q5 I used your codes changed the 4th digit to C the front doors work but rear ones don't is there a different code for the rear doors regards David
    01 11 02 20 40 01 44 00 04
    01 1C 02 20 40 01 44 00 04
  6. D J Robo
    D J Robo New Member
    Hi scotty still trying to get rear door/puddle lights working , I put the code in above for both front and rear , front ones worked but rear ones don't
    what dos it mean modules 62 left rear 72 right rear where do they go can you show pic or something desperate now lol kind regards David
  7. R4+
    R4+ New Member
    20
    Hello. I just finished doing the door puddle/warning lights + illuminated door handles on my 2012 a4 b8 facelift avant. I could not do the ambiante door pocket lighting as my door modules only have the half shaded box and no pin 3 (rear door 16 pin) or pin 8 (front door 32 pin) in the modules.
    Did you connect your rear light into the right pins? Mines are as stated:
    -front modules 32 pin:
    Pin 3, door illuminated handles +12v
    Pin 16, puddle/warning lights +12v
    Pin 8, ambiante lighting +12v (N/A)
    Pin 5, earth, just solder lights earth together on this brown wire.
    -rear modules 16 pin:
    Pin 1, illuminated door handles +12v
    Pin 3, ambiante lighting +12v (N/A)
    Pin 12, warning/puddle light +12v
    Pin 13, earth, just solder together lights earth on this brown wire.
    Then just go into each door controler and check the tick box for whatever lights you added to your car.
    For the door handles i used 1 bright red 12v 5mm LED for each door handles. I drilled on the top of the handles where the original oem would be. Just sandpaper the led to diffuse the light. It looks great at night. I hope this will help you.
    Kevin_w90 likes this.
  8. D J Robo
    D J Robo New Member
    All working fine now puddle lights, illuminated door handle lights and door pocket lights :nogarors4:
  9. Cokki
    Cokki New Member
    hello,I have audi Q3, I need to know who and 'encoding Pin 8, ambiante lighting + 12v
    My configuration actually is 011C02201C00000000
  10. R4+
    R4+ New Member
    20
    I dont know the coding for a Q3, but on my A4 B8, when you use the "long coding helper" in each door module, you just have to tick some boxes to add the ambiante lighting.
  11. MikeSel^
    MikeSel^ Moderator Staff Member Moderator Team Navarra TFSI Owners Group Gold Supporter Audi S3 quattro Manual
    1,153
    614
    Would be good to see some pictures of the new lights on action :)
  12. R4+
    R4+ New Member
    20
    I will try to take some pictures this week end of the door lights at night.
    I really like this retrofit and I am happy to be able to adjust the background lighting from the mmi even if I only have the concert radio. I will have to keep an eye now on ebay for some 2nd hand door modules as I would like to add the door pocket illumination. The other lights like the cup holder and the vanity lights don't really interest me.
  13. R4+
    R4+ New Member
    20
    Here are some pictures: a4-6.jpg a4-7.jpg a4-5.jpg a4-4.jpg a4-2.jpg a4-1.jpg a4-3.jpg
  14. R4+
    R4+ New Member
    20
    The door handles illumination comes on as soon as you unlock the car. The footwell lights brighten up fully when the doors are opened. Once the doors are closed the footwell lights dim down to your mmi setting. The door handles stay on even with the ignition off. A bit like the hazard light switch. The door warning & puddles lights come on whenever the door is opened. The glovebox light retrofit was easy, I just followed the tutorial. I used an audi repair wire for the ATO fuse. This combined with the 2x audi connectors and the clothe tape made the job look like factory work. The light switch / break was already on the glovebox. The best retrofiting result for me so far is the door handles illuminations. You can only see the glow of the LED's, even when seating you could not tell the difference from a factory job. You would have to kneel down to spot the difference.
  15. GaryDe
    GaryDe Active Member
    105
    77
    This looks really good.
    My next mods after getting coilovers and my fl rear lights coded.
  16. Kevin_w90
    Kevin_w90 Kevin VCDS Map User
    59
    I fitted door handle illumination using all oem parts and to be honest the glow from this is so dim you hardly notice them. Definitely a fan of your door handles, much more effective
  17. R4+
    R4+ New Member
    20
    Thanks for the comments. I found must of the infos in the forum or online, and I just gathered whatever suited me best.
  18. Spacer
    Spacer Member
    68
    Where do you buy the parts for the glovebox light?
  19. jdp1962
    jdp1962 Grumpy Old Moderator Staff Member Moderator TFSI Owners Group Team V6 Gold Supporter Team Tornado Audi S4 quattro Black Edition s tronic
    8,499
    3,059
    We have a forum sponsor who is a specialist in car lighting. Contact @t8ups, he'll look after you. :)
    Spacer and t8ups like this.
  20. t8ups
    t8ups Site Sponsor Site Sponsor VCDS Map User
    2,079
    768
    I'm here to help lighting wise all :)
    Spacer likes this.
  21. Marc Harding
    Marc Harding New Member
    Hi all, yes I was a bit peeved when I discovered that the glovebox light was an option when new, and not on my car. Long story, but although I live in London, I took the car back to Autotechnics in north Dorset and they did the fitting for me, would recommend them. And on a different subject, if your TFSI engine runs its fans like crazy after you switch the engine off… it’s supposed to. It cooling down the turbo. Maybe that’s on another thread, but it’s not a fault.
  22. Caisley
    Caisley New Member
    Just signed up and can’t see the images any help ?
