glove box hinge repaired! thanks to quattro james!
vorsprung dork Apr 29, 2011
  1. vorsprung dork
    vorsprung dork Member
    256
    fixed my glovebox hinge today thanks to quattro james thread! took about 45 mins! only thing i did differant was getting the pins out! as hard as i tried i couldnt get the pins out according to the instructions in the thread! so i turned the glovebox on its side and used a centre punch to drive out the righthand pin! this is easy and accesable the left hand pin is not so i drilled a small hole in the trim to fit the punch in! the hole is about 3 mm and can be seen with the door open! but to be honist if you were to notice it you neeb to be a trainspotter! if you try this fix yourself you will see what im on about when you remove the glovebox!!!!!!!! thank you james saved me £££££££££££
  2. quattrojames
    14,060
    583
    Glad it helped you mate.
