Glove box hinge bracket
A7788 Aug 16, 2012
  1. A7788
    A7788 Member
    162
    Hi all,
    Been looking at DIY glove box fixes and although there are many good guides I see most of the guys in the US use a steel bracket (Audi B6 S4/A4 DIY: Glove Box Hinge Repair) Has anyone on here made these at all, or know of where I can buy a set?
    I haven't got the facility or time (but mostly patience) to be able to make these so wondering if anyone on here can help?
    or if there is a better way of fixing this, I'm all ears :)
  2. quattrojames
    14,068
    585
    You'll not be able to buy a purpose made bracket, as far as I'm aware at least.
    The bracket can be shaped from an angled shelf bracket very simply. It will take you long to remove the glovebox etc than make the bracket. If you want to spend money then a new glovebox is the only way really.
  3. A7788
    A7788 Member
    162
    Thank you! Just found your thread on fixing it - sorry was being lazy :p
    I'll give it a go this weekend.
  4. Greeny233
    Greeny233 It's all about the V8. Team V8 Team Silver Audi S4 Audi Avant Owner Group
    1,094
    385
    I tried this method but the bracket tended to flex slightly and the glove box never shut properly. I also tried epoxy resin but it just broke again after a couple of weeks.
    In the end I just bit the bullet and ordered a new lid through TPS and a new damper, cost about £100 and it now works perfectly.
  5. quattrojames
    14,068
    585
    Mine's been on nearly three years now and I've had no problems.
  6. A7788
    A7788 Member
    162
    Thank you, I'll let you know the outcome.
  7. Dubbers1
    Dubbers1 Top Gear VCDS Map User
    270
    68
    I drilled mine through then pressed a dowel through with a load of epoxy resin and mine is holding strong, been over a year
    I also disconnected the hinge damper as this had gotten stiff which is what I think causes the hinge to break
  8. quattrojames
    14,068
    585
    if you look at my started threads, you'll see one titled "Do this today and save yourself £100" or similar, its shows you how to lubricate and trim the O ring in the damper to prevent this happening.
    I'll link to it when I get home if needs be. I think if you remove the damper there would be no mechanism in place to soften the drop of the lid, which might make it more vulnerable to further breakage.
  9. Dubbers1
    270
    68
    Yer I did see that, just couldnt be bothered so I just lower it gently
    And to be honest the only time I use it is to change a CD in the changer which is rare
  10. tre_audi
    tre_audi New Member
    10
    AUDI A4 glove box removal and hinge repair DIY
