Glove box damper and pin cost?
gkf9 Oct 13, 2011
  1. gkf9
    gkf9 Member
    256
    Anyone give me an idea.
    Part no's
    Damper part no.*
    8E2880324
    8E0880802 pin.*
  2. gkf9
    gkf9 Member
    256
    Just the damper and pin, not the glovebox.
  3. Mike B
    Mike B Well-Known Member
    1,114
    40
    Did this a few months ago cost about£12 but check that it works OK cos the first work stiffened up so I had to take it off and get another ,This one only just works after I used WD40 onit
  4. alpesh26
    alpesh26 Active Member TeamMisano
    424
    45
    I got quoted about £19! I said no, and pinched the one out of my dads B6 before he sold it :)
  5. T0m
    T0m Active Member
    516
    26
    I put WD40 on mine and after a while it still stiffens up found putting a small hole in the top of the damper makes it work a treat!
  6. gkf9
    gkf9 Member
    256
    £19 yeap that's a bit steep, not paying anymore than £15! Wish I had someone I could nick one off :)
  7. gkf9
    gkf9 Member
    256
    Where abouts do you put the hole?
  8. quattrojames
    14,060
    583
    A silicon spray will last longer than WD40. I trimmed a small amount from the rubber ring inside the damper, this helps it slide up and down with less resistance.
  9. T0m
    T0m Active Member
    516
    26
    The opposite end to where the little arm comes out of the damper fella!
  10. andywil13
    andywil13 Active Member It's my birthday
    380
    68
    If someone has bought one of these glovebox dampers, can they post where from, and how much as really want to order one.
  11. Mike B
    1,114
    40
    Got mine from Audi
  12. quattrojames
    14,060
    583
    That would seem the logical choice....
  13. gkf9
    gkf9 Member
    256
    Just bought one 5mins ago from Audi £20
  14. Daniel97
    Daniel97 Member
    137
    sorry to bump this ..
    just fixed mine .. sort of .. but can the pins be bought by themselves? don't need a dampener just the pin!
    And how do i loosen off the resistance so the glovebox opens freely?
  15. alpesh26
    424
    45
  16. Daniel97
    Daniel97 Member
    137
    Not sure what size pin and nut i need though :mad: lol .. can the damper come out without removing the glovebox?
  17. alpesh26
    424
    45
    I had to take the glove box out of my b7 because the hinge snapped, so I took my damper off whilst it was all out. You should be able to remove the damper with the glove box in situ, but if not its only 5 bolts holding the glove box in (3 inside at the top and 2 underneath). Only takes 5 mins to get out and you'll need an 8mm socket.
    I used wd40 inside my damper and shaved the o ring. If you go down this route, Don't put too much wd40 inside it or it will make a weird noise when the rod moves. The noise went away after a bit though
    I'll try and have a look in the garage tomorrow if I can find what my dad used to replace the pin and let you know the sizes.
  18. quattrojames
    14,060
    583
    The part number for the pin is here:
    8E0880802
    It's always worth looking in the Part Number Sticky before asking for part numbers, I've spent quite a lot of time with useful user contributions making that into a hopefully worthwhile resource.
    To ease up the damper movement have a read of this:
    http://www.audi-sport.net/vb/a4-a4-...wners-do-today-save-yourself-over-%A3150.html
  19. Daniel97
    Daniel97 Member
    137
    Thanks James
  20. tre_audi
    tre_audi New Member
    10
    AUDI A4 glove box removal and hinge repair DIY
  21. LEE69
    LEE69 07 170 DSG Team Dolphin Grey Audi A3
    2,296
    402
    Top advice, mine is damn smooth now :)
