Glove box - cool box
Discussion in 'A4/A4 cabriolet/S4 forum(B6 chassis)' started by samuelt, Oct 20, 2006.
  1. samuelt
    samuelt Member
    May 27, 2006
    383
    hi all
    Is it easy to retro-fit the bits to change the glovebox into the cool box? Has anyone done this to there A4?
  2. Advert Guest Advertisement
  3. Nelson_R32
    Nelson_R32 Member
    Dec 25, 2004
    305
  4. dstech
    dstech Member
    Dec 3, 2003
    247
    I've done it without buying the box itself. I'm sure the box helps keep it a little cooler and catches moisture, but if you want to go the route I went, then here's the writeup I did:
    http://www.audiworld.com/tech/int48.shtml
    Keep in mind this was for a LHD USA SPEC car. I'm not sure if RHD cars have different parts but I'm sure there is some difference in part numbers.
  5. samuelt
    samuelt Member
    May 27, 2006
    383
    thanks guys two great responses on how i could do this. I think i will go with dstech's sudgestions and great instructions. I only plan to use the cool box on my 2 weeks holiday in France as last year was a disater of melted chocolate and warm cola. So the full install would probably rob me of to much of the glove box for the other 50 weeks. Anyone got the UK part numbers??
  6. PetrolDave
    PetrolDave Well-Known Member
    Nov 25, 2003
    1,559
    85
    Air Hose 8E2 816 311
    Outlet 8E0 820 701 4PK
    And for those of you that want to fit the cool box as well that's 8E2 862 807 A 6PS
    But we warned that if you fit the cool box as well you have to replace the light fitting in the glovebox because the cool box obscures the original one. You have to cut a rectangular hole in the side of the glovebox and fit this light fitting 8E0 947 415. I did mine in about 10 minutes with a Dremel-type mini disc cutter and a file. Scary in a 2 day old RS4!
  7. The911SC
    The911SC Active Member
    Sep 28, 2003
    1,035
    yep sounds a good mod although I thought you couldnt turn it off and also not fitting the 'cool box' part causes moisture and nasty mildew to grow??
  8. dstech
    dstech Member
    Dec 3, 2003
    247
    You can turn it off because the hose outlet has a manual valve. As for as moisture goes just be smart and put a rag or towels around your cold drink if you put it in the glovebox. The insert really isn't that much more expensive but since I don't use mine that much I don't see the value in buying it.
  9. Defratos
    Defratos YouÂ’re Dethpicable!!
    May 26, 2004
    2,232
    Hey do they have the for the S3? :ermm:
  10. Block 405
    Block 405 Member
    Aug 28, 2006
    64
    I have my ipod and Alpine Ipod cable in the glove box. Would fitting the box above affect electonic equipment such that?
  11. tbcuprat
    tbcuprat Member
    May 23, 2006
    45
    Very good point. I have the multichanger in there too.
    Any suggestions to keep the moisture levels down without the coolbox.
  12. Caesium
    Caesium My BM is fixed!
    May 26, 2004
    4,879
    There won't be any moisture induced from the A/C unit, it actually drys the air before pumping it into the cabin.
    The VW Passat has a cool glovebox, but has the same lining as the standard Audi one. Its not as cool as you'd think, only as cold as the air from your vents would be.
    Its unlikely that mould would grow unless you are one dirty git that never cleans your car!
  13. scoTTy
    scoTTy Active Member
    Jan 2, 2003
    1,962
    Mould growth has been found on quite a few cars that this has been done on. If you're gonna do it then I'd recommend getting the new inner.
