Glove box bulb not working. And yes i have tried changing the bulb.
latta1989 Mar 23, 2011
  1. latta1989
    latta1989 Member
    147
    Anyone have any ideas why this is?
  2. Mike071288
    Mike071288 Active Member
    287
    26
    the fuse?
  3. kite
    kite Member VCDS Map User
    676
    The switch is built-into the damper, have you checked it ?
  4. latta1989
    latta1989 Member
    147
    Interior lights fuse is fine if that's the correct fuse. Didn't see any others that could be the fuse for it.
    Need to check the damper but as I think it has disconnected too.
  5. 1animal1
    9,976
    you tried opeing the glovebox?
  6. 1animal1
    9,976
  7. latta1989
    latta1989 Member
    147
    Haha surprisingly yes! Lol.
    Need to check the damper situation 2moz.
  8. FranA3
    FranA3 events moderator Regional Rep Gold Supporter Audi A3 Team Brill Red
    7,216
    303
    the damper on mine has broken so no light will come on how is you damper still ok and connected all ok its a common thing for it to snap off loads of a3's ive seen have done
  9. latta1989
    latta1989 Member
    147
    Just had a quick look there and I can see the problem. I Was aware my damper was broke in some way b
    the actual damper itself is fine just the but that attaches it to the gb has snapped. When I pull it out by hand the bulb comes on!
    I guess I could maybe drill a couple of holes on each snapped part and loop some wire through them to keep them together unless anyone has done somethin easier in the past?
    Or the parts for a whole new damper are cheap?
  10. mike foster
    3,967
    Brake element with switch - part no :- 8K2 880 324 approx £20
    That's for a rhd vehicle.
  11. NHN
    29,281
    1,692
    Just repair it mate, remove glovebox, superglue the parts together 1st to hold static, then epoxy the joints, done this many times to A3's/A4's for clients & my previous/current cars, not had 1 issue or report failed again, add some spray grease into the brake element, clean grease out until you're happy with the speed it drops with.
  12. FranA3
    7,216
    303
    i thought so as thats exactly whats wrong with mine mate very common thing on a3's , will have to give that a go nige i superglued it before but it snapped within a week my mate in work said drill a few holes in the damper body to let out some of the air that is causing it to stick will that work ok or should i do it the way you have suggested nige?
  13. NHN
    29,281
    1,692
    Well superglue alone wont do it mate & the hole drilling doesnt help, needs lubricating as the friction between the 2 parts is to much, needs greasing & epoxy.
  14. FranA3
    7,216
    303
    cheers nige will sort it out sometime this week as its realy annoying not having a light and the damper on my glovebox lol
  15. mike foster
    3,967
    I didn't even know there was a light in the glovebox - mine hasn't !!!lol
  16. FranA3
    7,216
    303
    you sure i thought it was a standard fit thing , mind you some cars havent even got a boot light
  17. NHN
    29,281
    1,692
    Mike's been down the pub, ignore him until the morning :p
  18. mike foster
    3,967
    lmfao !!
    Wrong - had a glass or two in the house !!lol
    Seriously - there isn't even a cut out for a light in my car - 2006 sportback. Was the light fitted as some kind of comfort pack ?
  19. FranA3
    7,216
    303
    explains all lol
  20. FranA3
    7,216
    303
    thats weird man what model of a3 is yours then ?
  21. mike foster
    3,967
    Er -2006 2.0tdi 140 sportback ?
  22. NHN
    29,281
    1,692
    LMFAO, Mike, you have a pub in your house lol.
    Interior light pack maybe.
    PS. Cable on route.
  23. FranA3
    7,216
    303
    lmfao , mine is a sport and yours is a .......
  24. mike foster
    3,967
    Cheers matey (there I go again - another glass ) !!
  25. NHN
    29,281
    1,692
    His is a sport------------back lmfao
  26. mike foster
    3,967
    5 Door ! lol
    Think Nige maybe right - I don't have the interior light pack.
  27. NHN
    29,281
    1,692
    Another job for you then hiccup Mike
  28. FranA3
    7,216
    303
    lol
  29. latta1989
    latta1989 Member
    147
    Lol!
    And just to say i fixed it today so far all working fine.
    Very DIY job with a few bits i had lying around.
    Lets just say it involved a drill, 2 paperclips, a bit of strimmer wire and a pair of pliers lol.
    Done the trick!
  30. NHN
    29,281
    1,692
    Did you have your horse tied up lmfao
  31. FranA3
    7,216
    303
    lol how did you use them dude ?
  32. latta1989
    latta1989 Member
    147
    No the horse was out in the field :p
    Just drilled 2 holes in the very end of the snapped part, which is attached to the damper, at each side, then two where it should be attached. looped the paperclips through and twisted them. Bit fiddly. Didnt think superglue alone would hold up but im going to stick some of that on too
  33. FranA3
    7,216
    303
    happy days then as long as it works then cant moan at that eh
  34. latta1989
    latta1989 Member
    147
    Yeh just thought of a total **** but simple way to do it.
    My mates brother is a mechanic and he has stuff that kinda melts and bonds plastic back together (dont know what it actually is) and that would probs have been the best way to fix it.
    Used it to fix a bit of my taillight housing i snapped when i was pulling them off to change a bulb.
  35. FranA3
    7,216
    303
    fair do's if it works then there's nowt wrong with that bud
