Gizmo's S3 8L round two...
Gizmo20VT May 28, 2013
  1. <tuffty/>
    20,890
    3,701
  2. Gizmo20VT
    Gizmo20VT Active Member
    294
  3. PDBoosted
    PDBoosted Active Member
    242
    No they are the standard A3 lights... The projector globe is much larger on mine than on the S3's... The clip I used was roughly the same size as the plastic ones and would sit the same distance as the plastic ones so I'm happy! Also I don't have motors to adjust the light level so that must make a difference.
  4. Gizmo20VT
    294
    Other headlight finished up this weekend, stopped at my local dealership to collect some small bits and bobs that are missing :D
    Yesterday at Sidey's house we did boost leak tests and I found my TIP has a tear in it... At the bottom where it tightens onto the scroll so need to get a replacement for that...
  5. Kuvi-S3
    Kuvi-S3 Active Member
    175
    49
    Nice cap!:icon_thumright: I have the exact same one
    Gizmo20VT likes this.
  6. Gizmo20VT
    294
    Not much happening currently as we just purchased our first house and moving in month end! Will finally have a garage to work in :arco:
    Got some small updates for now, Installed most of the AEM watermeth kit, Tank is located in the rear quater similar to what miggz did and controller and arm switch in the lower dash panel under the steering. I layed the festo piping in the car... I just need to do FMIC then I can wire up the pump and install the nozzle.
    Test fit
    Brackets
    Plumming
    Used the old rear sub connector block so I could remove the lower panel with no hassles
    Lower panel reinstalled
    Also remove the Preamp out the stock woofer enclosure an put it into a casing I had lying around to keep the rear speakers alive.
    Then ill be replacing the Vibe Liteair splits located in the front with some SPL Dynamics SD5.2 so A-pillars will be redone.
    Sidey likes this.
  7. Sidey
    Sidey Active Member
    284
    153
    43
    Awesome work as always bud.
  8. Kuvi-S3
    175
    49
    Top stuff bud. And congrats on the house man.
  9. Gizmo20VT
    294
    Thanks guys :D
    So moved into our new home on the 1st of this month, and finally got around to finishing up my WMI installation, Pump installed just need to wire it up which is tonight mission. Might also rotate the pump 180 degrees tonight.
    I used engine cover brackets and bolted it down in the other rear quater panel, Some pics...
    will finish up tonight then I just need to wait for FMIC to install the nozzle :D!
    PDBoosted likes this.
  10. PDBoosted
    242
  11. Sidey
    Sidey Active Member
    284
    153
    43
    Awesome work as always, love the attention to detail.
  12. Gizmo20VT
    294
    Ye dude, in no rush :) Still have a set of these to install and another blower intime...
    Kuvi-S3 and PDBoosted like this.
  13. Gizmo20VT
    294
    Shot boy! When we doing rear diff?
  14. MIGGZ
    MIGGZ nanananananananan BATMAN
    1,461
    304
    very neat dude! thinking of maybe moving the pump to the boot as well cos of thee race tank now
  15. Sidey
    Sidey Active Member
    284
    153
    43
    Yeah we need to make a plan soon bud.
  16. Gizmo20VT
    294
    Thanks dude! I wanted to mount in engine bay but after going over the instructions for Snow, AEM and Devils-own I decided rather to keep them as close as possible as they mentioned if you mount the pump in the front you would need a additional solenoid to feed it.
    MIGGZ likes this.
  17. MIGGZ
    1,461
    304
    yeah when i originally did mine they also said i might need a solenoid but after Carl said he never needed one i decided to just go with it, the delay without the solenoid is like 1 to 2 seconds so i just lived with it. iv also installed a 1 way valve in the line between nozzle and pump
  18. Gizmo20VT
    294
    This weekend was pretty much car weekend :D Put in some good hours on the engine bay even thou it still looks the same lol!
    First up removed most of the PCV system to start with the catch can install and gave the intake and injectors a good scrub, also replaced intake gasket, personally I think its the wrong head on my car :lmfao:
    Injectors & Manifold all fresh
    Then it was time to relocate the N249 so opened the coilpack harness up and pull the N249 wires back, mounted and out of the way.
    Fuel lines replaced and kinda look oem :p
    Installed my powerflex bushes on dogbone quick
    My car has had lifter noise when warm since I have purchased her, So Sidey came over yesterday to aid while we serviced the Intake lifters and having a few beers... Getting my new gaskets today and Torx set and I broke two of mine trying to remove the cam caps :keule:Pretty fun job
    Busy stripping the lifters apart
    Time to oil and reassemble, Tonight I shall retorque the cam caps and start smoothing my valve cover before it goes in for powder coating :D
    More updates laters
  19. Ashley =1.8T=
    Ashley =1.8T= Errrr
    173
    Das good ya! Nice jersey btw :icon_thumright:
  20. Gizmo20VT
    294
    Keeps me warm and makes me look Saxy, I have my famous two tone pants on aswell LOL!
  21. Kuvi-S3
    175
    49
    Awesome work as always dude
  22. Gizmo20VT
    294
    Thanks bud :D
  23. PDBoosted
    242
    Nice work as always bud...
    PS I'm glad you didn't have to sell her!
  24. Gizmo20VT
    294
    Thanks man, you and me both! Almost regreted buying house...
  25. Gizmo20VT
    294
    After doing lifters I got stuck into the valve cover and started smoothing it out, removing all the studs and valve cover brakets. Will send the intake, valve cover, strut brace and Throttle body in next week to power coat.
    Will be using Red and sandpaper matt black.
    Will update when done :)
    Scullies likes this.
  26. Gizmo20VT
    294
    And hopefully monday I have another parcel arriving which was paid for today! Can not wait!!!! :yahoo:
    MIGGZ likes this.
  27. Kuvi-S3
    175
    49
    Going to look awesome!
  28. PDBoosted
    242
  29. Sidey
    Sidey Active Member
    284
    153
    43
    Looking good brother, Gonna be even better with the new package fitted.
  30. Kuvi-S3
    175
    49
    Guys, hows about an update on this "new package" or is it top secret for now?
  31. Gizmo20VT
    294
    Thanks buddy
    Dankie Chom!
    Lol its nothing huge, and wont make me go faster :p
  32. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    :ninja:
  33. Scullies
    Scullies Well-Known Member
    1,543
    657
    If it doesn't make you go faster or stop quicker then there is nothing to see here :p............:laugh:
  34. PDBoosted
    242
    I know what it is:tapedshut: Going to be awesome once fitted!
  35. Ashley =1.8T=
    Ashley =1.8T= Errrr
    173
    +1
  36. Gizmo20VT
    294
    Just had these delivered :D! Pretty stocked to install them
    BC BR Coilovers
    Sidey and I will tackle them one night after work quick!
    Ashley =1.8T= likes this.
  37. Ashley =1.8T=
    Ashley =1.8T= Errrr
    173
    Finally got them :) love these :)
  38. Airs
    Airs Active Member
    144
    81
    i just got a set of these for my TT im building, they are an awesome piece of kit arnt they, cant wait to get to use them :)
  39. Gizmo20VT
    294
    Ye they are epic dude, keen to see how the ride will be vs my old AP coils
  40. Airs
    Airs Active Member
    144
    81
    yeah they are, i dont really have much to compare them to other then my cheap fk setup on the bora, but that things is constantly slammed so no comparison really lol
