Ghost chips???
imported_YOGi Oct 4, 2004
  1. imported_YOGi
    imported_YOGi Guest
    Not really ghosts but i heard that you can get an engine remap that is completely untracable by a computer or a person! Is this true, if so im very interested. /ubbthreads/images/graemlins/groovy.gif
    Who can do these re-maps?
    Thanks YOGi
  2. garethj
    garethj Member
    396
    Not completely untraceable but your average Audi Stealer wouldn't be able to detect most remaps with their standard diagnostics kit.
  3. Ess_Three
    Ess_Three Active Member
    5,383
    [ QUOTE ]
    [/ QUOTE ]
    Not so...
    Any dealer with the diagnostic gear can immediately tell it's been re-mapped by monitoring the requested vs actual boost levels.
    You can do this with either the Bosch official gear or a VAG Com. It's not rocket science.
    If your local dealer wants to shaft you by proving it's chipped - they can / will.
    Normally however, they make so much money on warranty stuff that they are known to not look very hard to see it it's chipped.
    Don't be fooled into thinking you can't detect an 'undetectable' remap...
    With the car at standstill the extra boost won't be evident, or if you can return it to stock boost levels (APR, REVO etc) but if you have it chipped and leave it chipped, they can tell.
  4. imported_gek
    imported_gek Guest
    Just to back up what Ess Three said, I had this reply from Revo when I asked the very same question:
    The only way to detect it in VAG COM would be to datalog certain blocks, for example if you were to look at requested boost or MAF values it would be obvious that the car is non-standard.
    It is by no means invisable, although it is undetectable to current dealer diagnostic equipment... unless datalogged in performance mode.
  5. dickys3
    2,963
    23
    The only option I think to make it truly undetectable is to use the Dual System technique or AmD's One-click method (When it comes out for the S3/A3).
    Using this method you can completely remove the "chipped code" and replace it with the "original map". The code gets downloaded to a dongle type effort and your original code gets copied back to the ECU.
    Sounds good in theory.
    Rich.
  6. StephaneS
    StephaneS Member
    379
    what about NA engines?
  7. DavidR
    DavidR Active Member
    1,296
    [ QUOTE ]
    [/ QUOTE ]
    More difficult, but not impossible. I wouldn't have thought that many dealers would check the na cars, the gains are small and therefore consequential increased wear is small. I suppose you could cross reference ingition timing, injector duty and suchlike, but the changes will be quite subtle, and probbably inconclusive.
  8. dickys3
    2,963
    23
    [ QUOTE ]
    [/ QUOTE ]
    Same rules apply I think. The new mini (NA) can be tuned using the one-click device. Take a look on AmD's website and look under Tuning...Mini
    Rich.
  9. Ess_Three
    5,383
    [ QUOTE ]
    [/ QUOTE ]
    Spot on Dave...
    The obvious differences are maximum ignition advance used at a pre-determined rev point...but you have to REALLY know what you are looking for, and as you rightly say, the differences are so subtle that it will hardly be conclusive.
    No surprise really...you only get 5-10 BHP gain from modern NA chip-tuning.
