GFB DV+ diverter valve kit
A3SBQ Sep 29, 2013
  1. A3SBQ
    A3SBQ A3 SportBack 2TFSI quattro DSG
    470
    74
    Hi guys
    A while back I stumbled upon this. Not sure if it has been written about here, so I am putting it up for you.
    The product info can be read here
    http://www.gfb.com.au/dv-plus-diverter-valve-for-late-model-vag-and-euro-applications
    I have bought it my self and it works. I had the old G version DV running on K04 APR setup. The stock DV work ok but was leaking and made a lot of sound.
    this baby does make the system sealed and no sound is released and I am having the Carbonio intake.
    There has been made two editions to this DV+ valve. Make sure to get the rev. Version with new spring.
    You can read more in my thread started at golfmk6.com forum. (More info on the TSI engine then here)
    GFB DV+ Diverter Valve Kit - anyone tested this? - VW GTI MKVI Forum / VW Golf R Forum / VW Golf MKVI Forum / VW GTI Forum - Golfmk6.com
    You can buy it here.
    GFB DV+ Diverter Valve Kit - 2.0 TFSI/2.0TSI - A3 (8P) - Audi - Shop By Car
    Now go out and buy it. You've never have DV problems ever.
    PS. The OEM rev. Piston DV leaks too.
  2. OVRA3
    OVRA3 Well-Known Member
    1,079
    80
    I don't see how the rev g leaks unless it's torn? It has a diaphragm so shouldn't leak. Correct me if I am wrong
  3. A3SBQ
    470
    74
    They all leaks at the contact points. Not on the valve it self. So i have heard / read / understand.
    So if you are running the "G" model like me and the diaphragm is not ruptured it will leak. The same will the piston style to.
    This is due to high or higher pressure and the DV will give inn.
    If you read the thread I have linked in you'll understand more.
  4. A3SBQ
    470
    74
  5. geforce189
    geforce189 Member
    53
    AMD started stocking these a few months ago. I had one fitted just as mine was starting to rupture. No complaints to date
  6. geforce189
    geforce189 Member
    53
  7. A3SBQ
    470
    74
    Geforce189 you are right. The Rev.1 came out a few month back. The rev.2 cam 2 weeks ago.
    Call AMD to ship you the new spring. It's it important for holding the boost.
    It is a free upgrade.
  8. geforce189
    geforce189 Member
    53
    Nice! Thanks for the tip off! Will do...
