Getting in a frozen cabriolet
Rudedaubin Jan 17, 2013
  1. Rudedaubin
    Rudedaubin Member
    78
    9
    As above , what methods are you all using to get the doors open on your cabs?
  2. lewie
    lewie Member
    285
    Run a credit card between the front windows and rubber(around the bottom)
  3. gen.heinz guderian
    gen.heinz guderian Well-Known Member
    1,346
    126
    Try silicon grease on the seals all around the doors roof and boot. Worked well on my Merc Convertible,doubt they had been done in a very long time as it was getting damp inside.
  4. Rudedaubin
    Rudedaubin Member
    78
    9
    I'll try the credit card in the morning , does this allow the window to drop properly as I've found mine sticking to the roof too.
    Silicon grease? Not heard of this before,will it not smear over the glass or does it dry/cure?
  5. gen.heinz guderian
    1,346
    126
    I gave the seals a good coating, left it for a day then wiped off the excess, hasnt left much on the window. Will clean the glass again when the snow clears.
  6. hades-
    9,481
    646
    as above silicon grease i did mine in the summer
    do it every 6 mth
  7. crazy88
    crazy88 Loving the anonymity
    4,939
    437
    I need to do mine (avant not convertible) as my doors are ridiculous in the mornings at the moment. I'm sure i'll either snap the handle off or drop the child one day trying to open a frozen door :)
  8. Rudedaubin
    Rudedaubin Member
    78
    9
  9. Cabbyfan
    Cabbyfan Active Member
    840
    34
    Audi de-icer as a last resort.
  10. VagCabby
    VagCabby Active Member
    513
    78
    I use auto glum vinyl and rubber treatment, I think that's the name of it. Seems to keep the seals nice and fresh and prevents the doors sticking in the cold
  11. gen.heinz guderian
    1,346
    126
    I tried silicone spray but dint seem very good. I bought Regin Silicone Grease from a plumbers merchants .
  12. fallmonk
    fallmonk Turbo Sport
    1,868
    Would Vasiline not do the same?
    I used it on mine seams ok , altho drys out looks ****.
