Getting Flashed at with headlights Dipped!!!
charlieenz Nov 9, 2012
  1. charlieenz
    charlieenz New Member
    9
    Hi guys,
    First time post! - We just bought a 2006 A3 Quottro 3.2 and I'm getting flashed by drivers with the lights on dip.
    Is there an easy adjustment as I don't think my model has the tumble adjuster I read about fitted.
    I also have no access or experience with vag -com.
    Maybe they just like my new car (but I somehow doubt it).
    There is a little push button just under the dash illumination thumb wheel but I have no Idea what that's for.
    The car had no owners manual.
    Charlie in New Zealand.
  2. hades-
    hades- Yorkshire & Humber Rep. Regional Rep VCDS Map User
    9,480
    646
    have you got xeons ?
  3. charlieenz
    9
    Not sure but i'm guessing so - They are very bright and white.
    There is bugger all difference in distance when going from low to hi.
    Especially with someone in the back seats.
  4. hades-
    9,480
    646
    best to take it to the mot place and have them on the machine and adjusted
  5. voorhees
    voorhees Moderator Staff Member Moderator DSG
    16,120
    1,963
    Silly question alert but when you have been flashed are you driving on a bumpy road ?
  6. MTRL
    MTRL Split Grill!
    459
    52
    Is it men or women flashing at you?
    _G_, OVRA3 and ilim like this.
  7. charlieenz
    9
    I noticed when I was driving my other car (CX9 which is high seated) in front of the audi, it would flash bright in the rear vision mirror as it went over bumps and they weren't exactly big bumps. (sealed main road)
    I was hoping this would be sorted by lowering the low beam setting.
  8. charlieenz
    9
    Wouldn't look if it was men!
  9. martinivw
    martinivw :)
    442
    24
    :lmfao:
  10. MrLapou
    MrLapou Well-Known Member
    1,233
    121
    If your car has little wheel inside next to headlamp switch to adjust the beam level (consult owners manual) then you do not xenon.
    With xenons, adjustment will need VCDS or a garage with similar to make the adjustment.
  11. SL11CKK
    SL11CKK Active Member
    686
    35
    Its another matter if its got an HID kit.
  12. charlieenz
    9
    Definitely no adjustment wheel so I guess its a trip to the garage!
    Thanks everyone.
  13. Artimus
    Artimus Shortback
    2,005
    476
    is it possible they might have broken or loose mounts\clips allowing them to flap up\down on uneven surfaces, and that's why people are flashing you?
  14. Jack_Of_All_Trades
    Jack_Of_All_Trades New Member
    27
    I got arrested for flashing :ninja:
  15. charlieenz
    9
    I rung the Audi specialists and they said they had never adjusted headlights with an VCDS and there should be a screw to adjust them.
    I am worried they aren't as specialist as they think!
  16. dzTT
    dzTT Active Member
    333
    29
    I've had this several times recently as well, but its usually by the idiots the drive with there sidelights and fog lights on :uhm: a quick flash back of the full beam usually stops them flashing again.
