Getting exterior mirrors to tilt (dip) when in reverse
warren_S5 Aug 14, 2009
  1. warren_S5
    warren_S5 Moderator Staff Member Moderator VCDS Map User
    7,210
    2,487
    Question:
    I don't have VAGCOM to check this, but does anyone know if I was to go and pay a specialist to adjust a setting in VAGCOM, can they recode my EXTERNAL mirrors to tilt downwards (dipping I guess) when I engage reverse gear.
    As the A3 is so high sided it is hard to see how close your wheels are to the kerb, and I am working somewhere where you park in individual bayed spaces which are surrounded on both sides by high kerbs. I don't want to kerb the new rims just yet!!
    I have the heated / folding / dimming exterior mirrors for the record (don't know if that effects what functionality they have).
    Also I need to get my speech recognition sorted as my car cannot understand any of my voice commands at present, and I have a VERY plain (non dialect) UK accent. Before fitting the RNS_E no issues at all, so can only assume the settings have changed and I've not compensated for them!
    Note to self, must save up and buy VAGCOM :banghead:
    Cheers in advance
    W
  2. edition
    edition Active Member
    1,426
    Yes that would be good!
    X5's and stuff have this and its tres usefull.
  3. S3RYE
    S3RYE Interior Next!!
    3,448
    70
    yeh im defo interested in this too... would be helpful as i always try to get as close as possible to kerb.. consiquently havin to manually dip mirror every time.. Really annoying when forget to change it back, get iin your car next time go to use mirror and its facing the road :wacko:
  4. mhill
    mhill Member
    323
    Im sure someone on here has mentioned it allrerady
  5. warren_S5
    7,210
    2,487
    did a search and couldn't find 'owt
  6. ST09
    ST09 Member
    319
    17
  7. kaz219
    kaz219 Active Member VCDS Map User
    1,808
    Im going to try that on mine - fingers crossed but according to the link, you need memory seats!
    Will let you lot know how it goes!
  8. warren_S5
    7,210
    2,487
    That's it, I'm going to buy VAG com next month. Was going to get my windows tinted, but it can wait. Thanks for the tip above, be interesting to see if it works.
  9. drsilviuro
    drsilviuro Member
    121
    It doesn't work. You need memory seats... I did the coding and nothing happens.
  10. VRStu
    VRStu Just Looking VCDS Map User
    1,073
    Yep I agree it's Memory seats only.
  11. Staz
    Staz is a retronaut Staff Member Moderator VCDS Map User
    6,206
    66
    I was trying this yesterday actually :confused:
    If you tell the CAN that you have memory seats it just throws up a DTC that it can't talk to them.
    Doesn't work sorry.
  12. kaz219
    1,808
    Dont work as below :(
  13. warren_S5
    7,210
    2,487
    Many thanks for the tips, shame it didn't work
  14. drsilviuro
    drsilviuro Member
    121
    Did yesterday a scan on Mk5 GTI wich has this option (tilt when reverse) and has NO memory seats (double checked).
    The only thing that he's got is folding mirrors and memory seats checked in coding...
    Whould be interesting to see if someone with folding mirrors to do the coding on 8P.
  15. Khufu
    Khufu Well-Known Member
    5,704
    31
    did you make a printout of the scan, or take note of the modules version?
  16. NHN
    29,423
    1,740
    The MK5 has this feature, the 8P the premium brand (yeah fecking right) doesnt have this, also the MK5 has the led under mirror feature which I'm modding on my 8P
  17. drsilviuro
    drsilviuro Member
    121
    Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
    Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
    Component: Bordnetz-SG H54 2202
    Revision: 00H54000 Serial number: 00000007803739
    Coding: E78F0F2700041500471400001400000000097F075C000100000000000000
    Shop #: WSC 00000 785 00200
    Part No: 1K1 955 119 E
    Component: Wischer 161107 021 0501
    Coding: 00038805
    Shop #: WSC 00000
    Part No: 1K0 955 559 AF
    Component: RLS 261107 046 0204
    Coding: 00208933
    Shop #: WSC 00000
    No fault code found.
