Genuine rs4 rims 19"
reepers13 Jan 28, 2011
  1. reepers13
    reepers13 Member
    53
    Been offered a set for the sport.. Will they fit straight on (standard suspension)
    what they worth with curbing and needing 2new tyres
    thanks
  2. swarcup
    swarcup Well-Known Member
    1,326
    40
    I dought they fit as the offset is different, this is to suit the wider arches the rs4 has
  3. reepers13
    reepers13 Member
    53
    I think they are 8.5j et48
  4. C17LJR
    C17LJR Member VCDS Map User
    513
    my fat fives are (18"x) 8.5" et45 and fit no problem
    these should fit fine but you'll be better spacing them a bit
  5. CHRIS555
    CHRIS555 DOPE with added OCD
    1,970
    10
    Double check they are genuine RS4 ones and not another wheel made for the "A4" rather than the RS4 - Audi have a nack of producing wide rims for the RS models then slimmer ones as an option purchase on the A models. The genuine RS4 ones are the ones you want and are the nuts!
  6. CHRIS555
    1,970
    10
    The tyre size on the genuine ones will be 245x45x19 (or maybe 255!)
    Just checked and Audi did offer an "S Line" version and these are 8.5 wide and are not worth as much as the real RS4 ones.
  7. CHRIS555
    1,970
    10
    Sorry to keep posting! Th genuine RS4'S will easily get £1000 in good condition, knock a couple of hundred off for curbing - but these prices are without tyres!!
  8. reepers13
    reepers13 Member
    53
    Update-
    Went and tries them on, fit fine however markings on the inside of rims were 8x19 et35 and said not oem... So they must be reps!!!
  9. CHRIS555
    1,970
    10
  10. brownie 25
    brownie 25 Member
    383
    9
    so how can you tell if they are genuine rs4
  11. CHRIS555
    1,970
    10
    If you call Audi they will be able to give you a part number - this is stamped inside the wheel
  12. reepers13
    reepers13 Member
    53
    If they say "not OEM" that's a big clue as I learnt lol
  13. pjmspeedy
    pjmspeedy Dude, what's mine say ?
    1,058
    I always thought that genuine RS4 rims won't fit because of the width and that they are dished so they would stick too far out!
  14. CHRIS555
    1,970
    10
    +1
  15. quattrojames
    14,060
    583
    Genuine RS4 wheels are 19 x 9" ET29.
    9" wheels with an offset of 29 will stick out way past the bodywork.
  16. reepers13
    reepers13 Member
    53
    I agree but there are a few listed as genuines on eBay as 8.5x19 et48?????
  17. quattrojames
    14,060
    583
    They'll be RS4 "style" wheels.
    Probably genuine in the respect that they're oem wheels, but not genuine RS4 wheels.
    Like I have RS6 wheels, which are in fact RS6 "style" wheels in that they're 18 not 19" like the RS6's had.
    Knowledge is power ;)
