Genius required
bob2312 Dec 21, 2013
  1. bob2312
    bob2312 Member
    42
    1 Central locking stopped working remotely,2 Rear doors don't lock or even show up on dashboard display when opened ,3 When any of doors opened no interior light , 4 Alarm stopped working, only goes off when I have locked doors with key then after unlocking goes off about 20 seconds later,5 The doors have stopped locking when in motion, 6 When I lock the doors with key only the drivers door opens and have to turn on ignition to get front passengers to open,apart from these minor issues car drives perfectly,had at Garage 4 times he thinks the rear locks have gone and is trying to source some replacements, just had serviced and mot so £250 pounds lighter someone out there must have an ides,thanks
  2. quattrojames
    14,050
    574
    Have you had it scanned for fault codes?
    I would suspect maybe the alarm siren batteries have leaked and fried the PCB, or the comfort and convenience module under the front passenger seat has got wet. Check the carpet to make sure it's dry there, are the drain holes under the battery free?
    Or it could be a multitude of fault microswitches?
  3. IanFM
    IanFM Active Member quattro Audi A5 TDi
    452
    81
    I don't suppose you/the garage have scanned with vcds?
  4. Jimmy TDI
    Jimmy TDI Pro Tinkerer Audi A4 Audi Avant Owner Group TDi
    1,320
    262
    I'd go with door locks, or ccm mate.
    I have VAG-COM if you want a scan doing to see what comes up to get a better idea? It would be better than going in blind so to speak, as that can soon lead to wasted money.
  5. swarcup
    swarcup Well-Known Member
    1,326
    40
    Check the wires that go from door to car for breaks, pull back the black rubber boot and check
  6. 666markyboy
    666markyboy Well-Known Member
    1,201
    49
    I would go with broken wires inside where the doors hinge or bad connections in the plugs that are in the same area... they can cause lots of different problems... intermittent speaker's, central locking, door light's, puddle lights, interior lights... all go trough this ... I've done repairs on 3 B6's all with broken wires inside the rubber gaiter at the hinges
  7. bob2312
    bob2312 Member
    42
    Thanks for all your suggestions,will pass them on ,it has had a diagnostic but it was all error codes but did not indicate what was going wrong
  8. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
    We might be able to help more if you posted the FULL VCDS scan results.
  9. bob2312
    bob2312 Member
    42
    Posted them under How many error codes on Nov 11 no idea how to link to another post I have done
  10. desertstorm
    desertstorm Moderator Staff Member Moderator VCDS Map User quattro Audi A4 Audi Avant Owner Group TDi
    5,357
    2,329
  11. desertstorm
    5,357
    2,329
  12. quattrojames
    14,050
    574
    Agreed, plug all those codes into the wiki and see what they diagnose. Here are three straight away that will point towards your issues, broken wires in the door hinge are a good place to start by the looks of it.
    Have you checked to see if the carpet is wet yet?
    For example: 1333 -
    1559:
    1331:
  13. bob2312
    bob2312 Member
    42
    Carpet is dry and no moisture in door either
  14. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,172
    150
    There's alot of padding under that carpet. I'd get it lifted and properly check for water.
  15. 666markyboy
    1,201
    49
    I would check inside those rubber gaiters at the door hinges first before I started ripping up carpets... honestly it's a really common problem for the wires to break
  16. quattrojames
    14,050
    574
    Agreed, and from the fault codes I've referenced for you it's the most likely issue.
