generic and custom remap
abdus Jul 29, 2007
  1. abdus
    abdus Top Gear VCDS Map User
    1,827
    sorry to sound stupid, can somebody explain the difference...please. Thanks
  2. DPM
    DPM Site Sponsor Site Sponsor
    5,013
    205
    A generic is basically the same map for every 1.8T 150 engine or every 1.9TDi 130 engine, just examples, and once it's loaded that's it done. A custom remap is different for every car no matter what engine. It can be tweaked and changed to how the custom wants it and also depending on what other modifications the car has. Hope this helps.
  3. GSB1
    GSB1 Member
    283
    My description would be......
    Generic:
    A map developed by someone (quite possibly neither the person nor the company applying it), on a test mule car, is applied to your car and off you go. Any difference or issue between your car(s) and the car the map was developed on are not addressed.
    Custom:
    A starting point map is applied to you car and then tweaked real time by a tuner either on the road or on a dyno. This map takes advantage of any other modifications your engine has and can be tweaked so that the optimum performance for YOUR car is achieved whilst keep ing all relevant parameters safe.
    The end result my be parameters altered so you actually run a less tuned car than a generic map, but that is all your example can safely handle or it may be the case you have a good'un and the timing can be wound on safely, running sweet air/fuel and you get that little bit extra power for your money.
  4. abdus
    1,827
    thanks for the replies.
    so a custom remap is better?
    is Revo a custom remap?
  5. MikeA3
    MikeA3 Active Member VCDS Map User
    1,178
    revo is generic - the only plus side to revo IMO is that you can change between the standard setting and the revo setting
  6. abdus
    1,827
    so which is better then?
  7. god_thats_quick
    2,507
    A custom map because it's for your specific engine.
  8. abdus
    1,827
    anyone with good past experience with custom remaps and recommend the tuner. Thanks
  9. DPM
    5,013
    205
    Where are you based?
  10. abdus
    1,827
    Welling, Kent...near Dartford
  11. MikeA3
    1,178
    I went to superchips HQ for my tailored map on my TDI a while back - only downside is that they are just outside oxford which may be too far for you to travel.
    Other companies that seem to get good reviews are (in no particular order)
    DPM
    Jabbasport
    AMD (although they are now part of big boys toys and apparently quality has gone right downhill)
    Awesome GTI
    Superchips
    Custom Code
    Star Performance
    and probably a load of others I can't remember
  12. abdus
    1,827
    i wouldn't mind travelling for a good service
  13. D-Tech Performance
    D-Tech Performance D-Tech Performance - Dom
    162
    Personally i wouldnt go custom unless you have modifications past a filter and exhaust
